Is this the best way to switch a high voltage DC contactor?
Hi all,
I need to switch multiple DC contactors on and off using Arduino.
I have not found any single component that can switch the contactor directly from the Arduino's output, due to voltage and current requirements/limits.
As such I am looking at a 4-step approach where each device switches the next:
arduino digital output pin (3.3v?) > optoisolator (12v) > solid state relay (12v) > contactor (100v)
I'll be running 4 of these from one Arduino so need to consider the cumulative current draw when active.
To my extreme beginner eye, it feels a little convoluted to have so many steps, am I missing something or is this perfectly valid?
Thank you very much
You might not need the solid state relay, depending on details not provided in your post.
Post links to technical information on each of the hardware items.
Are you saying that you have a contactor with a 100V coil or that the contactor switches 100V
Identical to the one you posted 2 days ago?
And what are those secret requirements/limits?
Thank you, here's the info/links to the components I'm looking at.
Arduino: Teensy 4.0
Maximum Digital output 3.3v/4mA ?
Optoisolator:
3.3v input, presumably low current draw since it's using optoisolators? (I will likely try and find one of these with more info available)
can control a 12v output.
Using two types of solid state relay:
SSR-DD41F - I need to control three of these
*it's the DD41F version I'm looking at, the page may load a different variant.
*appears to need 3v min to switch
and
Panasonic AQZ107D - I need to control one of these.
https://industry.panasonic.com/global/en/products/control/relay/photomos/number/aqz107d
*looks like the typical switching voltage of this relay is 1.4-4v, with typical current 6.5ma. If the Teensy 4.0 can deliver 4mA max on its output pins it seemed that this would be overstressing it? (PLEASE correct my understanding if wrong, it's shaky at best)
The contactors are TE
EV200AAANA
They have a max inrush current rating of 3.8A, it's been problematic to find a solid state DC relay that is rated for this current + safety margin while having a low enough switching requirement.
Sorry, it's switching a 100vDC circuit, the coil voltage rating is 9-36v
You might also see if the documentation duty cycle matches your requirements.
Ah, thank you. Duty cycle of any specific component, or all the switching ones if I can find a spec? Much appreciated.
Aside from one of the contactor circuits, which will switch on/off twice, the rest will only need to switch once in about a 20 minute timeframe.
You could use just common (optoisolated) relay module for that. Most of them can switch 12V DC.
I don't know what you mean with "single component" though.
Thank you - that would be a board which has the optoisolators AND mechanical relays on it, correct? Something like this?
By single component I meant I couldn't find a solid state relay that was capable of switching the 100vDC load I need, without requiring a 'trigger' voltage/current that was more than the Arduino could supply natively.
This is like drinking from a fire hose for me though so my understanding is basic at best.
Yes, arduino can control contactor through that relay module. Obviously you don't need 8 channel one for one contactor.
The duty cycle of the solenoid switch. That is the only device you have that generates heat when in active use. The coil generates heat that must be allowed to escape or it will build until something gets too hot. The contacts have resistance and get hot, so the heat needs to disparate somehow. Likely the terminals and connecting wire will act as heat sinks.
That leaves the coil heat. The specifications for the switch will give the duty cycle which is the ratio of time on making heat to time off to allow cooling. Too much time powered on will eventually cause failure of some sort.
Got it, thank you for the explanation!
I've searched through the datasheet for my contactor but I couldn't find anything related to duty. I saw some timing information on the open/close speed. (I linked it below)
It does have a coil economizer that (if I am tracking) greatly reduces the current required to keep it open once it's opened. Is it possible that feature would allow it to remain energized 'indefinitely', or is that impossible?
https://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=adm_kilovac_ev200&DocType=Data%20Sheet&DocLang=English&DocFormat=pdf&PartCntxt=1618002-7
Then the next best thing is the estimated life of the switch graph based on current and number of cycles.
A common mosfet module with surface mount fets would do the job of driving the coil.
The relay seems to be a starter motor type, for very short duration use only.
A mechanical relay like that will almost certainly burn out with continuous use.
An inductor (relay coil) has no inrush current.
Leo..
