Hi
I have incoming string from a sensor (Atlas Scientific)
#include <SoftwareSerial.h> //add the soft serial libray
#define rxpin 2 //set the RX pin to pin 2
#define txpin 3 //set the TX pin to pin 3
SoftwareSerial myserial(rxpin, txpin); //enable the soft serial port
String inputstring = ""; //a string to hold incoming data from the PC
String sensorstring = ""; //a string to hold the data from the Atlas Scientific product
boolean input_stringcomplete = false; //have we received all the data from the PC
boolean sensor_stringcomplete = false; //have we received all the data from the Atlas Scientific product
void setup(){ //set up the hardware
Serial.begin(38400); //set baud rate for the hardware serial port to 38400
myserial.begin(38400); //set baud rate for software serial port to 38400
inputstring.reserve(5); //set aside some bytes for receiving data from the PC
sensorstring.reserve(30); //set aside some bytes for receiving data from Atlas Scientific product
void serialEvent() { //if the hardware serial port receives a char
char inchar = (char)Serial.read(); //get the char we just received
inputstring += inchar; //add it to the inputString
if(inchar == '\r') {input_stringcomplete = true;} //if the incoming character is a <CR>, set the flag
void loop(){ //here we go....
if (input_stringcomplete){ //if a string from the PC has been recived in its entierty
myserial.print(inputstring); //send that string to the Atlas Scientific product
inputstring = ""; //clear the string:
input_stringcomplete = false; //reset the flage used to tell if we have recived a completed string from the PC
while (myserial.available()) { //while a char is holding in the serial buffer
char inchar = (char)myserial.read(); //get the new char
sensorstring += inchar; //add it to the sensorString
if (inchar == '\r') {sensor_stringcomplete = true;} //if the incoming character is a <CR>, set the flag
if (sensor_stringcomplete){ //if a string from the Atlas Scientific product has been received in its entirety
Serial.print(sensorstring); //use the hardware serial port to send that data to the PC
sensorstring = ""; //clear the string:
sensor_stringcomplete = false; //reset the flag used to tell if we have received a completed string from the Atlas Scientific product
The data that comes from the sensor is a string like "45.6723,9.0876,545.256 " and it represents "Total liters, Liter per minute, Liters per hour"
I want to take the "Total liters" value turn it into a float so I can send it through Modbus TCP into my HMI screen and display the value as a graph.
Then I want to take the "Liter per minute" value turn it into a float so I can send it through Modbus TCP into my HMI screen and display the value as a graph.
And at last take the " Liter per minute, Liters per hour" value turn it into a float so I can send it through Modbus TCP into my HMI screen and display the value as a graph.
I tried to use this code in my while loop
int i=0;
if (inchar == '\,')
valueone=atof(sensorstring.c_str());
And I got the fist value XD...
But I have a trouble getting the other ones... ![]()
Can any one help me for a code to do this?
I have been trying to use the "strtok" command to split my string up, but no luck.
Regards
Steini
