Hello, thank you for your quick replies, I have adjust my code and wiring to have the pins be used with the internal Pull-up resistors. Below is my entire code.
// Initialize
int RED_LED_1 = 3;
int GREEN_LED_1 = 4;
int BLUE_LED_1 = 5;
int RED_LED_2 = 6;
int GREEN_LED_2 = 9;
int BLUE_LED_2 = 10;
int RED_LED_3 = 23;
int GREEN_LED_3 = 22;
int BLUE_LED_3 = 21;
int BUTTON1 = 14; // Button that makes LED's go white
int BUTTON2 = 15; // Button that cycles through modes
int state;
int val_1;
int val_2;
int old_val_2;
int NumberofModes = 5;
int t = 10; // Time for delay
pinMode(RED_LED_1, OUTPUT);
pinMode(GREEN_LED_1, OUTPUT);
pinMode(BLUE_LED_1, OUTPUT);
pinMode(RED_LED_2, OUTPUT);
pinMode(GREEN_LED_2, OUTPUT);
pinMode(BLUE_LED_2, OUTPUT);
pinMode(RED_LED_3, OUTPUT);
pinMode(GREEN_LED_3, OUTPUT);
pinMode(BLUE_LED_3, OUTPUT);
pinMode(BUTTON1, INPUT_PULLUP);
pinMode(BUTTON2, INPUT_PULLUP);
state = 1 ;
val_1 = 0 ;
val_2 = 0 ;
old_val_2 = 0 ;
val_1 = digitalRead(BUTTON1);
if (val_1 == HIGH)
state = 1;
val_2 = digitalRead(BUTTON2); //Reads the value of the button and stores
if ((val_2 == HIGH) && (old_val_2 == LOW) && (state < NumberofModes))
state = state + 1;
// delay(10);
else if ((val_2 == HIGH) && (old_val_2 == LOW) && (state > (NumberofModes - 1)))
state = 1;
old_val_2 = val_2; // val_2 is now old val_2 so its stored
switch (state)
case 1:
Fade(); //Runs Function 1 - Rainbow Fade
case 2:
White(); //Runs Function 2 - White
case 3:
Random(); //Runs Function 3 - Random
case 4:
Merica_Static(); //Runs Function 3 - 'Merica Static
case 5:
Merica_Dynamic(); //Runs Function 3 - 'Merica Dynamic
void Fade() {
for ( int i = 255; i >= 0; i--) {
analogWrite(RED_LED_1, i); // fade up
analogWrite(GREEN_LED_1, 255 - i); // fade down
analogWrite(BLUE_LED_1, 0); // do nothing
analogWrite(RED_LED_2, i); // fade up
analogWrite(GREEN_LED_2, 255 - i); // fade down
analogWrite(BLUE_LED_2, 0); // do nothing
analogWrite(RED_LED_3, i); // fade up
analogWrite(GREEN_LED_3, 255 - i); // fade down
analogWrite(BLUE_LED_3, 0); // do nothing
delay(t);
analogWrite(RED_LED_1, 255 - i); // fade down
analogWrite(GREEN_LED_1, 0); // do nothing
analogWrite(BLUE_LED_1, i); // fade up
analogWrite(RED_LED_2, 255 - i); // fade down
analogWrite(GREEN_LED_2, 0); // do nothing
analogWrite(BLUE_LED_2, i); // fade up
analogWrite(RED_LED_3, 255 - i); // fade down
analogWrite(GREEN_LED_3, 0); // do nothing
analogWrite(BLUE_LED_3, i); // fade up
delay(t);
analogWrite(RED_LED_1, 0); // do nothing
analogWrite(GREEN_LED_1, i); // fade up
analogWrite(BLUE_LED_1, 255 - i); // fade down
analogWrite(RED_LED_2, 0); // do nothing
analogWrite(GREEN_LED_2, i); // fade up
analogWrite(BLUE_LED_2, 255 - i); // fade down
analogWrite(RED_LED_3, 0); // do nothing
analogWrite(GREEN_LED_3, i); // fade up
analogWrite(BLUE_LED_3, 255 - i); // fade down
delay(t);
void White() {
void Random(){
//R:0-255 G:0-255 B:0-255
colorRGB1(random(0,255),random(0,255),random(0,255));
colorRGB2(random(0,255),random(0,255),random(0,255));
colorRGB3(random(0,255),random(0,255),random(0,255));
void colorRGB1(int red, int green, int blue){
analogWrite(RED_LED_1,constrain(red,0,255));
analogWrite(GREEN_LED_1,constrain(green,0,255));
analogWrite(BLUE_LED_1,constrain(blue,0,255));
void colorRGB2(int red, int green, int blue){
analogWrite(RED_LED_2,constrain(red,0,255));
analogWrite(GREEN_LED_2,constrain(green,0,255));
analogWrite(BLUE_LED_2,constrain(blue,0,255));
void colorRGB3(int red, int green, int blue){
analogWrite(RED_LED_3,constrain(red,0,255));
analogWrite(GREEN_LED_3,constrain(green,0,255));
analogWrite(BLUE_LED_3,constrain(blue,0,255));
void Merica_Static() {
analogWrite(GREEN_LED_1, 255);
analogWrite(BLUE_LED_1, 255);
analogWrite(RED_LED_3, 255);
analogWrite(GREEN_LED_3, 255);
void Merica_Dynamic() {
for(int i=255; i >= 0; i--) {
// LED1 fade from white to red
analogWrite(GREEN_LED_1, 255-i);
analogWrite(BLUE_LED_1, 255-i);
// LED2 fade from red to blue
analogWrite(RED_LED_2, 255-i);
analogWrite(GREEN_LED_2, 255);
// LED3 fade from blue to white
delay(t*2);
// LED1 fade from red to blue
analogWrite(RED_LED_1, 255-i);
// LED2 fade from blue to white
// LED3 fade from white to red
analogWrite(GREEN_LED_3, 255-i);
analogWrite(BLUE_LED_3, 255-i);
delay(t*2);
// LED1 fade from blue to white
// LED2 fade from white to red
analogWrite(GREEN_LED_2, 255-i);
analogWrite(BLUE_LED_2, 255-i);
// LED3 fade from red to blue
delay(t*2);
Currently my wiring goes from my board, on pins 14 and 15, attach to a push button which connects the pins to GND when pressed.
The code still does not seem to work.
