Help with button code
Hello, I am new to working with the Arduino, and I am having trouble with coding. What I'm trying to do is make a button that you hold and when you let go after holding for at least 10 seconds, it moves on to the main part of the code. I was thinking of using a while statement, but I'm not sure. Thanks!
int pin1 = 6;
int pin2 = 7;
int pin3 = 8;
int pin4 = 9;
int pin5 = 10;
int pin6 = 11;
int pin7 = 12;
int pin8 = 13;
int timer = 500;
// int cycle = 5400000;   for future use
const int buttonPin = 4;
int buttonState = 0;
  pinMode(pin1, OUTPUT);
  pinMode(pin2, OUTPUT);
  pinMode(pin3, OUTPUT);
  pinMode(pin4, OUTPUT);
  pinMode(pin5, OUTPUT);
  pinMode(pin6, OUTPUT);
  pinMode(pin7, OUTPUT);
  pinMode(pin8, OUTPUT);
  pinMode(buttonPin, INPUT);
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH) {
      digitalWrite(pin1, HIGH);
      digitalWrite(pin5, HIGH);
      delay(timer);
      digitalWrite(pin1, LOW);
      digitalWrite(pin5, LOW);
      digitalWrite(pin2, HIGH);
      digitalWrite(pin6, HIGH);
      delay(timer);
      digitalWrite(pin2, LOW);
      digitalWrite(pin6, LOW);
      digitalWrite(pin3, HIGH);
      digitalWrite(pin7, HIGH);
      delay(timer);
      digitalWrite(pin3, LOW);
      digitalWrite(pin7, LOW);
      digitalWrite(pin4, HIGH);
      digitalWrite(pin8, HIGH);
      delay(timer);
      digitalWrite(pin4, LOW);
      digitalWrite(pin8, LOW);
heyitskarl121:
Do you want the code to be doing anything while it's waiting for this long button press?
If the code doesn't need to do anything else but wait for the button press then you could use something like this.
void waitForLongButtonPress(byte button_Pin, unsigned long requiredPressTime, boolean activeState)
  unsigned long beginningActiveTime = millis();
  while (millis() - beginningActiveTime < requiredPressTime)
    if (digitalRead(button_Pin) != activeState)
To call the function use:
  waitForLongButtonPress(buttonPin, 10000UL, HIGH);
Instead of "10000UL" you could use a unsigned long constant set to the desired time.
If you want the code to execute other tasks while it waits for the button press then you'll need to keep track of the button's state and how long it had been since the button was first pressed.
BlinkWithoutDelay is probably a good place to start learning to monitor states.
DuaneDegn:
I don't want the code to do anything while its PRESSED, the user would hold the button, but once they let go, that's when the code would start, would you use a while statement? and thanks for the suggested read, ill go check it out
This snippet shows how to test that a button remains pressed for a certain time
btnVal = digitalRead(btnPin);
if (btnVal == HIGH) {    // assumes btn is LOW when pressed
   lastBtnPressMillis = millis();   // btn not pressed so reset clock
if (millis() - lastBtnPressMillis > = interval) {
   // button has been pressed for longer than interval
It is assumed to be within loop() or, perhaps, within a WHILE loop
...R
Ever heard of array's? They can make your life easier :wink:
Isn't this the EXACT same request for "Need Help With Button" from "heyitskarl121" on Nov 20th as ...
I just had a "light bulb" moment ...
Is this a Project or is this Homework?
