hello yes i saw the update earlier today come up for the esp32 boards.
however. i think i should be clear about what i'm doing here. i'm using the builtin 'AnalodReadSerail' sketch within Examples>Basics and I am on IDE 2.2.1
here is the erros now
FQBN: esp32:esp32:lilygo_t_display
Using board 'lilygo_t_display' from platform in folder: C:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13
Using core 'esp32' from platform in folder: C:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13
loading library from c:\Users\chris\Documents\Arduino\libraries\LCD5110_Graph: invalid library: no header files found
loading library from c:\Users\chris\Documents\Arduino\libraries\LCD5110_Graph_Demo: invalid library: no header files found
loading library from c:\Users\chris\Documents\Arduino\libraries\PlayRtttl-2.0.1: invalid library: no header files found
loading library from c:\Users\chris\Documents\Arduino\libraries\TTGO-T-Display-master: invalid library: no header files found
loading library from c:\Users\chris\Documents\Arduino\libraries\Time: invalid library: no header files found
loading library from c:\Users\chris\Documents\Arduino\libraries\Timezone: invalid library: no header files found
loading library from c:\Users\chris\Documents\Arduino\libraries\e-Paper-master: invalid library: no header files found
loading library from c:\Users\chris\Documents\Arduino\libraries\epd-library-arduino-master: invalid library: no header files found
loading library from c:\Users\chris\Documents\Arduino\libraries\nRF24l01: invalid library: no header files found
cmd /c if exist "C:\\Users\\chris\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2023817-13288-1iecd9z.kcnb\\AnalogReadSerial\\partitions.csv" COPY /y "C:\\Users\\chris\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2023817-13288-1iecd9z.kcnb\\AnalogReadSerial\\partitions.csv" "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51\\partitions.csv"
cmd /c if not exist "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51\\partitions.csv" if exist "C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\variants\\lilygo_t_display\\partitions.csv" COPY "C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\variants\\lilygo_t_display\\partitions.csv" "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51\\partitions.csv"
cmd /c if not exist "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51\\partitions.csv" COPY "C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\tools\\partitions\\default.csv" "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\chris\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2023817-13288-1iecd9z.kcnb\\AnalogReadSerial\\bootloader.bin" ( COPY /y "C:\\Users\\chris\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2023817-13288-1iecd9z.kcnb\\AnalogReadSerial\\bootloader.bin" "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51\\AnalogReadSerial.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\variants\\lilygo_t_display\\bootloader.bin" ( COPY "C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\variants\\lilygo_t_display\\bootloader.bin" "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51\\AnalogReadSerial.ino.bootloader.bin" ) ELSE ( "C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51\\AnalogReadSerial.ino.bootloader.bin" "C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\tools\\sdk\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.5.1
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\chris\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2023817-13288-1iecd9z.kcnb\\AnalogReadSerial\\build_opt.h" COPY /y "C:\\Users\\chris\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2023817-13288-1iecd9z.kcnb\\AnalogReadSerial\\build_opt.h" "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51\\build_opt.h"
cmd /c if not exist "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51\\build_opt.h" type nul > "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51\\build_opt.h"
cmd /c type nul > "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51/file_opts"
Detecting libraries used...
C:\Users\chris\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.5" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/newlib/platform_include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/freertos/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/freertos/port/xtensa/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/freertos/include/esp_additions -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_hw_support/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_hw_support/include/soc -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_hw_support/port/esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/heap/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/log/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/lwip/include/apps -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/lwip/include/apps/sntp -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/lwip/lwip/src/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/lwip/port/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/lwip/port/esp32/include/arch -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/soc/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/soc/esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/soc/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/hal/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/hal/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/hal/platform_port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_rom/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_rom/include/esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_rom/esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_common/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_system/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_system/port/soc -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_system/port/public_compat -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/xtensa/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/xtensa/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/driver/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/driver/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_pm/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_ringbuf/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/efuse/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/efuse/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/vfs/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_wifi/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_event/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_netif/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_eth/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/tcpip_adapter/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_phy/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_phy/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_ipc/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/app_trace/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_timer/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/mbedtls/port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/mbedtls/mbedtls/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/app_update/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/spi_flash/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bootloader_support/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/nvs_flash/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/pthread/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_gdbstub/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_gdbstub/xtensa -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_gdbstub/esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espcoredump/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espcoredump/include/port/xtensa -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/wpa_supplicant/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/wpa_supplicant/port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/ieee802154/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/console -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/asio/asio/asio/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/asio/port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/common/osi/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/include/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/common/api/include/api -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/api -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/cbor/port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/unity/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/unity/unity/src -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/cmock/CMock/src -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/coap/port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/coap/libcoap/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/nghttp/port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-tls -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_adc_cal/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_hid/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/tcp_transport/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_http_client/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_http_server/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_https_ota/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_https_server/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_lcd/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_lcd/interface -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/protobuf-c/protobuf-c -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/protocomm/include/common -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/protocomm/include/security -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/protocomm/include/transports -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/mdns/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_local_ctrl/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/sdmmc/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_serial_slave_link/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_websocket_client/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/expat/expat/expat/lib -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/expat/port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/wear_levelling/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/fatfs/diskio -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/fatfs/vfs -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/fatfs/src -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/freemodbus/freemodbus/common/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/idf_test/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/idf_test/include/esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/jsmn/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/json/cJSON -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/libsodium/port_include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/mqtt/esp-mqtt/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/openssl/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/perfmon/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/spiffs/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/ulp/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/wifi_provisioning/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/rmaker_common/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_diagnostics/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/rtc_store/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_insights/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/json_parser/upstream/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/json_parser/upstream -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/json_generator/upstream -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_schedule/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_rainmaker/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/gpio_button/button/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/qrcode/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/ws2812_led -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_littlefs/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/tool -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/typedef -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/image -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/math -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/nn -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/layer -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/detect -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/model_zoo -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp32-camera/driver/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp32-camera/conversions/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/fb_gfx/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_LILYGO_T_DISPLAY -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="LILYGO_T_DISPLAY" -DARDUINO_VARIANT="lilygo_t_display" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\chris\AppData\Local\Temp\arduino\sketches\C5AE6B3C636378A5B38297DC3D016B51/build_opt.h @C:\Users\chris\AppData\Local\Temp\arduino\sketches\C5AE6B3C636378A5B38297DC3D016B51/file_opts -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13\cores\esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13\variants\lilygo_t_display C:\Users\chris\AppData\Local\Temp\arduino\sketches\C5AE6B3C636378A5B38297DC3D016B51\sketch\AnalogReadSerial.ino.cpp -o nul
Generating function prototypes...
C:\Users\chris\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++ -DHAVE_CONFIG_H -DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE -DIDF_VER="v4.4.5" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/newlib/platform_include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/freertos/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/freertos/include/esp_additions/freertos -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/freertos/port/xtensa/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/freertos/include/esp_additions -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_hw_support/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_hw_support/include/soc -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_hw_support/port/esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/heap/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/log/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/lwip/include/apps -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/lwip/include/apps/sntp -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/lwip/lwip/src/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/lwip/port/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/lwip/port/esp32/include/arch -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/soc/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/soc/esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/soc/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/hal/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/hal/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/hal/platform_port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_rom/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_rom/include/esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_rom/esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_common/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_system/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_system/port/soc -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_system/port/public_compat -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/xtensa/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/xtensa/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/driver/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/driver/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_pm/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_ringbuf/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/efuse/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/efuse/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/vfs/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_wifi/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_event/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_netif/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_eth/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/tcpip_adapter/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_phy/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_phy/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_ipc/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/app_trace/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_timer/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/mbedtls/port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/mbedtls/mbedtls/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/app_update/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/spi_flash/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bootloader_support/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/nvs_flash/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/pthread/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_gdbstub/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_gdbstub/xtensa -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_gdbstub/esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espcoredump/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espcoredump/include/port/xtensa -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/wpa_supplicant/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/wpa_supplicant/port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/ieee802154/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/console -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/asio/asio/asio/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/asio/port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/common/osi/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/include/esp32/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/common/api/include/api -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/common/btc/profile/esp/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/api -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/cbor/port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/unity/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/unity/unity/src -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/cmock/CMock/src -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/coap/port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/coap/libcoap/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/nghttp/port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-tls -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-tls/esp-tls-crypto -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_adc_cal/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_hid/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/tcp_transport/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_http_client/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_http_server/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_https_ota/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_https_server/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_lcd/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_lcd/interface -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/protobuf-c/protobuf-c -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/protocomm/include/common -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/protocomm/include/security -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/protocomm/include/transports -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/mdns/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_local_ctrl/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/sdmmc/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_serial_slave_link/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_websocket_client/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/expat/expat/expat/lib -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/expat/port/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/wear_levelling/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/fatfs/diskio -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/fatfs/vfs -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/fatfs/src -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/freemodbus/freemodbus/common/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/idf_test/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/idf_test/include/esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/jsmn/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/json/cJSON -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/libsodium/port_include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/mqtt/esp-mqtt/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/openssl/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/perfmon/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/spiffs/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/ulp/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/wifi_provisioning/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/rmaker_common/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_diagnostics/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/rtc_store/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_insights/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/json_parser/upstream/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/json_parser/upstream -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/json_generator/upstream -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_schedule/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_rainmaker/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/gpio_button/button/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/qrcode/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/ws2812_led -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp_littlefs/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/tool -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/typedef -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/image -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/math -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/nn -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/layer -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/detect -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp-dl/include/model_zoo -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp32-camera/driver/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/esp32-camera/conversions/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/include/fb_gfx/include -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/sdk/esp32/qio_qspi/include -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_LILYGO_T_DISPLAY -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="LILYGO_T_DISPLAY" -DARDUINO_VARIANT="lilygo_t_display" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @C:\Users\chris\AppData\Local\Temp\arduino\sketches\C5AE6B3C636378A5B38297DC3D016B51/build_opt.h @C:\Users\chris\AppData\Local\Temp\arduino\sketches\C5AE6B3C636378A5B38297DC3D016B51/file_opts -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13\cores\esp32 -IC:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13\variants\lilygo_t_display C:\Users\chris\AppData\Local\Temp\arduino\sketches\C5AE6B3C636378A5B38297DC3D016B51\sketch\AnalogReadSerial.ino.cpp -o C:\Users\chris\AppData\Local\Temp\110805370\sketch_merged.cpp
C:\Users\chris\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\chris\AppData\Local\Temp\110805370\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.5\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/log/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/console" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -Wall -Werror=all -Wextra -Os -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_LILYGO_T_DISPLAY -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"LILYGO_T_DISPLAY\"" "-DARDUINO_VARIANT=\"lilygo_t_display\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51/build_opt.h" "@C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51/file_opts" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\cores\\esp32" "-IC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\variants\\lilygo_t_display" "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51\\sketch\\AnalogReadSerial.ino.cpp" -o "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51\\sketch\\AnalogReadSerial.ino.cpp.o"
Compiling libraries...
Compiling core...
cmd /c echo -DARDUINO_CORE_BUILD > "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51/file_opts"
Using precompiled core: C:\Users\chris\AppData\Local\Temp\arduino\cores\254aafff7193900235d0e76f73ab295c\core.a
cmd /c type nul > "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51/file_opts"
Linking everything together...
"C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" "-Wl,--Map=C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51/AnalogReadSerial.ino.map" "-LC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/lib" "-LC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/ld" "-LC:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/sdk/esp32/qio_qspi" -T esp32.rom.redefined.ld -T memory.ld -T sections.ld -T esp32.rom.ld -T esp32.rom.api.ld -T esp32.rom.libgcc.ld -T esp32.rom.newlib-data.ld -T esp32.rom.syscalls.ld -T esp32.peripherals.ld -mlongcalls -Wno-frame-address -Wl,--cref -Wl,--gc-sections -fno-rtti -fno-lto -Wl,--wrap=esp_log_write -Wl,--wrap=esp_log_writev -Wl,--wrap=log_printf -u ld_include_hli_vectors_bt -u _Z5setupv -u _Z4loopv -u esp_app_desc -u pthread_include_pthread_impl -u pthread_include_pthread_cond_impl -u pthread_include_pthread_local_storage_impl -u pthread_include_pthread_rwlock_impl -u include_esp_phy_override -u ld_include_highint_hdl -u start_app -u start_app_other_cores -u __ubsan_include -Wl,--wrap=longjmp -u __assert_func -u vfs_include_syscalls_impl -Wl,--undefined=uxTopUsedPriority -u app_main -u newlib_include_heap_impl -u newlib_include_syscalls_impl -u newlib_include_pthread_impl -u newlib_include_assert_impl -u __cxa_guard_dummy -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -Wl,--start-group "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51\\sketch\\AnalogReadSerial.ino.cpp.o" "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\cores\\254aafff7193900235d0e76f73ab295c\\core.a" -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lasio -lbt -lcbor -lunity -lcmock -lcoap -lnghttp -lesp-tls -lesp_adc_cal -lesp_hid -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lesp_https_server -lesp_lcd -lprotobuf-c -lprotocomm -lmdns -lesp_local_ctrl -lsdmmc -lesp_serial_slave_link -lesp_websocket_client -lexpat -lwear_levelling -lfatfs -lfreemodbus -ljsmn -ljson -llibsodium -lmqtt -lopenssl -lperfmon -lspiffs -lulp -lwifi_provisioning -lrmaker_common -lesp_diagnostics -lrtc_store -lesp_insights -ljson_parser -ljson_generator -lesp_schedule -lespressif__esp_secure_cert_mgr -lesp_rainmaker -lgpio_button -lqrcode -lws2812_led -lesp32-camera -lesp_littlefs -lespressif__esp-dsp -lfb_gfx -lasio -lcmock -lunity -lcoap -lesp_lcd -lesp_websocket_client -lexpat -lfreemodbus -ljsmn -llibsodium -lperfmon -lesp_adc_cal -lesp_hid -lfatfs -lwear_levelling -lopenssl -lspiffs -lesp_insights -lcbor -lesp_diagnostics -lrtc_store -lesp_rainmaker -lesp_local_ctrl -lesp_https_server -lwifi_provisioning -lprotocomm -lbt -lbtdm_app -lprotobuf-c -lmdns -ljson -ljson_parser -ljson_generator -lesp_schedule -lespressif__esp_secure_cert_mgr -lqrcode -lrmaker_common -lmqtt -lcat_face_detect -lhuman_face_detect -lcolor_detect -lmfn -ldl -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lesp_ringbuf -lefuse -lesp_ipc -ldriver -lesp_pm -lmbedtls -lapp_update -lbootloader_support -lspi_flash -lnvs_flash -lpthread -lesp_gdbstub -lespcoredump -lesp_phy -lesp_system -lesp_rom -lhal -lvfs -lesp_eth -ltcpip_adapter -lesp_netif -lesp_event -lwpa_supplicant -lesp_wifi -lconsole -llwip -llog -lheap -lsoc -lesp_hw_support -lxtensa -lesp_common -lesp_timer -lfreertos -lnewlib -lcxx -lapp_trace -lnghttp -lesp-tls -ltcp_transport -lesp_http_client -lesp_http_server -lesp_https_ota -lsdmmc -lesp_serial_slave_link -lulp -lmbedtls_2 -lmbedcrypto -lmbedx509 -lcoexist -lcore -lespnow -lmesh -lnet80211 -lpp -lsmartconfig -lwapi -lphy -lrtc -lesp_phy -lphy -lrtc -lesp_phy -lphy -lrtc -lxt_hal -lm -lnewlib -lstdc++ -lpthread -lgcc -lcxx -lapp_trace -lgcov -lapp_trace -lgcov -lc -Wl,--end-group -Wl,-EL -o "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51/AnalogReadSerial.ino.elf"
"C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5.1/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB --elf-sha256-offset 0xb0 -o "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51/AnalogReadSerial.ino.bin" "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51/AnalogReadSerial.ino.elf"
esptool.py v4.5.1
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
"C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/gen_esp32part.exe" -q "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51/partitions.csv" "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51/AnalogReadSerial.ino.partitions.bin"
cmd /c if exist "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51\\libraries\\Insights" "C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13/tools/gen_insights_package.exe" "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51" AnalogReadSerial.ino "C:\\Users\\chris\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2023817-13288-1iecd9z.kcnb\\AnalogReadSerial"
cmd /c IF 0==1 COPY /y "C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\openocd-esp32\\v0.11.0-esp32-20221026\\share\\openocd\\scripts\\board\\esp32-wrover-kit-3.3v.cfg" "C:\\Users\\chris\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2023817-13288-1iecd9z.kcnb\\AnalogReadSerial\\debug.cfg"
cmd /c IF 0==1 COPY /y "C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\tools\\ide-debug\\esp32.json" "C:\\Users\\chris\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2023817-13288-1iecd9z.kcnb\\AnalogReadSerial\\debug_custom.json"
cmd /c IF 0==1 COPY /y "C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\tools\\ide-debug\\svd\\esp32.svd" "C:\\Users\\chris\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2023817-13288-1iecd9z.kcnb\\AnalogReadSerial\\debug.svd"
"C:\\Users\\chris\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-size" -A "C:\\Users\\chris\\AppData\\Local\\Temp\\arduino\\sketches\\C5AE6B3C636378A5B38297DC3D016B51/AnalogReadSerial.ino.elf"
Sketch uses 266805 bytes (20%) of program storage space. Maximum is 1310720 bytes.
Global variables use 21520 bytes (6%) of dynamic memory, leaving 306160 bytes for local variables. Maximum is 327680 bytes.
"C:\Users\chris\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1/esptool.exe" --chip esp32 --port "COM16" --baud 921600 {upload.flags} --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size 4MB 0x1000 "C:\Users\chris\AppData\Local\Temp\arduino\sketches\C5AE6B3C636378A5B38297DC3D016B51/AnalogReadSerial.ino.bootloader.bin" 0x8000 "C:\Users\chris\AppData\Local\Temp\arduino\sketches\C5AE6B3C636378A5B38297DC3D016B51/AnalogReadSerial.ino.partitions.bin" 0xe000 "C:\Users\chris\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.13/tools/partitions/boot_app0.bin" 0x10000 "C:\Users\chris\AppData\Local\Temp\arduino\sketches\C5AE6B3C636378A5B38297DC3D016B51/AnalogReadSerial.ino.bin" {upload.extra_flags}
usage: esptool [-h]
[--chip {auto,esp8266,esp32,esp32s2,esp32s3beta2,esp32s3,esp32c3,esp32c6beta,esp32h2beta1,esp32h2beta2,esp32c2,esp32c6,esp32h2}]
[--port PORT] [--baud BAUD]
[--before {default_reset,usb_reset,no_reset,no_reset_no_sync}]
[--after {hard_reset,soft_reset,no_reset,no_reset_stub}]
[--no-stub] [--trace] [--override-vddsdio [{1.8V,1.9V,OFF}]]
[--connect-attempts CONNECT_ATTEMPTS]
{load_ram,dump_mem,read_mem,write_mem,write_flash,run,image_info,make_image,elf2image,read_mac,chip_id,flash_id,read_flash_status,write_flash_status,read_flash,verify_flash,erase_flash,erase_region,merge_bin,get_security_info,version}
esptool: error: argument operation: invalid choice: '{upload.flags}' (choose from 'load_ram', 'dump_mem', 'read_mem', 'write_mem', 'write_flash', 'run', 'image_info', 'make_image', 'elf2image', 'read_mac', 'chip_id', 'flash_id', 'read_flash_status', 'write_flash_status', 'read_flash', 'verify_flash', 'erase_flash', 'erase_region', 'merge_bin', 'get_security_info', 'version')
Failed uploading: uploading error: exit status 2
