Solved ! ESP32 Error: no header files found & file does not exist
Hi!
Overnight, my Arduino IDE suddenly doesn't work. It comes with the errors below. I've tried reinstalling arduino but it doesn't work. The only thing I can see is that the path for e.g. the header files is not quite correct e.g.
C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\AsyncUDP: invalid library: no header files found
When I travel the path myself I find the header file in
C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\AsyncUDP\src
Can someone help me with this problem?
FQBN: esp32:esp32:esp32
Using board 'esp32' from platform in folder: C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10
Using core 'esp32' from platform in folder: C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\ArduinoOTA: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\AsyncUDP: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\BLE: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\BluetoothSerial: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\DNSServer: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\EEPROM: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\ESP32: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\ESPmDNS: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\Ethernet: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\FFat: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\FS: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\HTTPClient: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\HTTPUpdate: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\HTTPUpdateServer: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\I2S: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\Insights: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\LittleFS: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\NetBIOS: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\Preferences: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\RainMaker: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\SD: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\SD_MMC: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\SPI: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\SPIFFS: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\SimpleBLE: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\Ticker: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\USB: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\Update: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\WebServer: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\WiFi: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\WiFiClientSecure: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\WiFiProv: invalid library: no header files found
loading library from C:\Users\vilen\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.10\libraries\Wire: invalid library: no header files found
cmd /c if exist "C:\\Users\\vilen\\OneDrive\\Documents\\Arduino\\BlinkTester\\partitions.csv" COPY /y "C:\\Users\\vilen\\OneDrive\\Documents\\Arduino\\BlinkTester\\partitions.csv" "C:\\Users\\vilen\\AppData\\Local\\Temp\\arduino\\sketches\\696CD9669E42F64874DA8B3ABA435CFE\\partitions.csv"
cmd /c if not exist "C:\\Users\\vilen\\AppData\\Local\\Temp\\arduino\\sketches\\696CD9669E42F64874DA8B3ABA435CFE\\partitions.csv" if exist "C:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10\\variants\\esp32\\partitions.csv" "C:\\Users\\vilen\\AppData\\Local\\Temp\\arduino\\sketches\\696CD9669E42F64874DA8B3ABA435CFE\\partitions.csv"
cmd /c if not exist "C:\\Users\\vilen\\AppData\\Local\\Temp\\arduino\\sketches\\696CD9669E42F64874DA8B3ABA435CFE\\partitions.csv" COPY "C:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10\\tools\\partitions\\default.csv" "C:\\Users\\vilen\\AppData\\Local\\Temp\\arduino\\sketches\\696CD9669E42F64874DA8B3ABA435CFE\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\vilen\\OneDrive\\Documents\\Arduino\\BlinkTester\\bootloader.bin" ( COPY /y "C:\\Users\\vilen\\OneDrive\\Documents\\Arduino\\BlinkTester\\bootloader.bin" "C:\\Users\\vilen\\AppData\\Local\\Temp\\arduino\\sketches\\696CD9669E42F64874DA8B3ABA435CFE\\BlinkTester.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10\\variants\\esp32\\bootloader.bin" "C:\\Users\\vilen\\AppData\\Local\\Temp\\arduino\\sketches\\696CD9669E42F64874DA8B3ABA435CFE\\BlinkTester.ino.bootloader.bin" ) ELSE ( "C:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\3.0.0/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\vilen\\AppData\\Local\\Temp\\arduino\\sketches\\696CD9669E42F64874DA8B3ABA435CFE\\BlinkTester.ino.bootloader.bin" "C:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10\\tools\\sdk\\esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v3.0-dev
cmd /c if exist "C:\\Users\\vilen\\OneDrive\\Documents\\Arduino\\BlinkTester\\build_opt.h" COPY /y "C:\\Users\\vilen\\OneDrive\\Documents\\Arduino\\BlinkTester\\build_opt.h" "C:\\Users\\vilen\\AppData\\Local\\Temp\\arduino\\sketches\\696CD9669E42F64874DA8B3ABA435CFE\\build_opt.h"
cmd /c if not exist "C:\\Users\\vilen\\AppData\\Local\\Temp\\arduino\\sketches\\696CD9669E42F64874DA8B3ABA435CFE\\build_opt.h" type nul > "C:\\Users\\vilen\\AppData\\Local\\Temp\\arduino\\sketches\\696CD9669E42F64874DA8B3ABA435CFE\\build_opt.h"
cmd /c type nul > "C:\\Users\\vilen\\AppData\\Local\\Temp\\arduino\\sketches\\696CD9669E42F64874DA8B3ABA435CFE/file_opts"
Detecting libraries used...
"C:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.5\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/newlib/platform_include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/freertos/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/heap/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/log/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/lwip/include/apps" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/soc/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/soc/esp32" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/soc/esp32/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/hal/esp32/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/hal/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_rom/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_common/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_system/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp32/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/xtensa/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/driver/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/driver/esp32/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_pm/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/efuse/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/vfs/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_wifi/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_event/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_netif/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_eth/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_phy/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_ipc/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/app_trace/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_timer/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/app_update/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/spi_flash/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bootloader_support/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/nvs_flash/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/pthread/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espcoredump/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/ieee802154/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/console" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/asio/port/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/bt/esp_ble_mesh/api" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/cbor/port/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/unity/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/unity/unity/src" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/coap/port/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/nghttp/port/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp-tls" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_hid/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/tcp_transport/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_http_client/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_http_server/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_https_server/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_lcd/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/protocomm/include/common" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/protocomm/include/security" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/mdns/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/sdmmc/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/expat/port/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/wear_levelling/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/fatfs/diskio" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/fatfs/vfs" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/fatfs/src" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/idf_test/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/jsmn/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/json/cJSON" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/libsodium/port_include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/openssl/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/perfmon/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/spiffs/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/ulp/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/rmaker_common/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_diagnostics/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/rtc_store/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_insights/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/json_parser/upstream" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/json_generator/upstream" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_schedule/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/gpio_button/button/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/qrcode/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/ws2812_led" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp-dl/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/include/fb_gfx/include" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10/tools/sdk/esp32/qio_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Og -g3 -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\vilen\\AppData\\Local\\Temp\\arduino\\sketches\\696CD9669E42F64874DA8B3ABA435CFE/build_opt.h" "@C:\\Users\\vilen\\AppData\\Local\\Temp\\arduino\\sketches\\696CD9669E42F64874DA8B3ABA435CFE/file_opts" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10\\cores\\esp32" "-IC:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.10\\variants\\esp32" "C:\\Users\\vilen\\AppData\\Local\\Temp\\arduino\\sketches\\696CD9669E42F64874DA8B3ABA435CFE\\sketch\\BlinkTester.ino.cpp" -o nul
exec: "C:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++": file does not exist
Compilation error: exec: "C:\\Users\\vilen\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32-elf-g++": file does not exist
Your topic title states that it's solved. Do you mind sharing what caused the problem (if you know) and how you solved it?
Hi !! Yes of course. I don't quite know the underlying problem, but I have an idea what it might be. When I uninstalled and reinstalled the Arduino IDE the first time, I was surprised that it could remember all my settings. I therefore assumed that the uninstaller not had deleted all files even though everything looked deleted. I assumed that there must be some initialization files that I couldn't see and which was not deleted. I ran the uninstaller again and then I turned on "show hidden files, folders and drives" in the "File explorer". After some searching I found two folders. One called Arduino15 in the path C:\Users\vilen\AppData\Local and another in the folder Arduino IDE in the path C:\Users\vilen\AppData\Roaming. I deleted them both. Afterwards, I reinstalled the Arduino IDE again. My previous settings were now gone. I set up the Arduino IDE again and everything worked just fine now.
I assumed that it must be due some corrupted initializationfiles or some broken paths in the initializationfiles that link incorrectly to the files.
I assumed that on the basis that the uninstaller could not find the files too and delete them. And on the first reinstallation, I think, the installer saw the files but did not overwrite them and thereby the problem consist due to e.g. a wrong path.
That's my guess, but I don't know if that's the real reason.
Hope you can use it :wink:
