Using ESP32 to move brushless motor using esc
Hi first of all i unable to move the motor and I'm not sure if my coding correct or not or there is another problem . Both my esc signal wire connected to esp32 gpio26 and 27. Below is my code.
#include <driver/ledc.h>
// Pin configuration
const int motorPin1 = 26;  // Pin connected to motor 1 ESC
const int motorPin2 = 27;  // Pin connected to motor 2 ESC
// LEDC settings for motor 1
const int ledcChannel1 = 0;      // LEDC channel for motor 1
const int ledcResolution1 = 12;  // LEDC resolution (bits) for motor 1
const int ledcFrequency1 = 50;   // LEDC frequency (Hz) for motor 1
// LEDC settings for motor 2
const int ledcChannel2 = 1;      // LEDC channel for motor 2
const int ledcResolution2 = 12;  // LEDC resolution (bits) for motor 2
const int ledcFrequency2 = 50;   // LEDC frequency (Hz) for motor 2
const int minPulseWidth = 1000;  // Minimum pulse width in microseconds
const int maxPulseWidth = 2000;  // Maximum pulse width in microseconds
  // Configure motor pins as outputs
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  // Configure LEDC timers for motor 1 and motor 2
  ledcSetup(ledcChannel1, ledcFrequency1, ledcResolution1);
  ledcSetup(ledcChannel2, ledcFrequency2, ledcResolution2);
  // Attach motor pins to the respective LEDC channels
  ledcAttachPin(motorPin1, ledcChannel1);
  ledcAttachPin(motorPin2, ledcChannel2);
  // Set motor 1 speed to maximum throttle
  setMotorSpeed(motorPin1, maxPulseWidth);
  // Set motor 2 speed to maximum throttle
  setMotorSpeed(motorPin2, maxPulseWidth);
// Function to set the motor speed
void setMotorSpeed(int motorPin, int pulseWidth) {
  int ledcChannel;
  // Determine the LEDC channel based on the motor pin
  if (motorPin == motorPin1) {
    ledcChannel = ledcChannel1;
  } else if (motorPin == motorPin2) {
    ledcChannel = ledcChannel2;
    return;  // Invalid motor pin
  ledcWrite(ledcChannel, pulseWidth);
Do the hardware logic levels match?
You will have to provide a lot of more information if you want effective help.
Almost any ESC expects a specified servo-signal on power-on.
A lot of ESCs must be calibrated to min and max-values to know what each pulse-length of the servo-signal shall mean.
An ESP32 has a voltage of 3.3V. It might be that the ESC is not working properly with 3.3V but expects a 5V signal.
And these details are inside the manual of the ESC. So provide a link to where the manual can be downloaded or attach a PDF-file to a posting
Do you have a simple RC-servo for crosschecking if the servo-signal is created properly?
Do you have a digital multimeter that can measure frequency and duty-cycle?
Do you have a second microcontroller which you could use to check how the servo-signal looks like?
Did you connect ground of your ESP32 with the ground of the powersupply of your ESC?
Are you using a extra powersupply for your ESC? You can't supply the ESC from the ESP32. Your ESC MUST have their own power-supply that is capable to deliver the current your brushless-motor needs.
This current is pretty high even for small motors
Even if your brushless motor has a diameter of just 20 mm the current will be minimum 5A and can go up for bigger motors to 30A - 50A !!
best regards Stefan
could you provide a schematic?
