Hi. I am using Arduino IDE and a ESP32.
In the code below 'water_temp' is a global variable located in a .h file declared as a int water_temp. The other variables in the code are: int upper_limit, and int lower_limit .
The variables are used also by some other functions.
The code below gives an error from the compiler.
: error: the value of 'water_temp' is not usable in a constant expression
case (water_temp> upper_limit):
What can i do correct this?
Do i need to declare the variable differently?
Any help is appreciated.
Thank you.
regards
switch(water_temp)
//do
case (water_temp> lower_limit):
//do
default:
//do
The value for the case statement must be a compile-time constant integer.
Sorry code is too big to post:
Hi.
Sorry i do not understand the answer.
Can you clarify please.
Regards
watercondition = 0;
if (watertemp<min) watercondition=-1;
if (watertemp>max) watercondition=1;
switch (watercondition) {
case 0:
case -1:
case 1:
switch(variable) {
case XXX:
XXX must be a compile-time constant integer:
Integer: ... -4, -3, -1, 0, 1, 2, 3, 4 ....
Constant: It can't change as the program is executing.
Compile-Time: It's value must be known when you press the "Verify" button.
gcjr
April 20, 2023, 5:35pm
8
assuming you do have two separate upper limits: possibly critical and warning, test for the critical limit first and then the warning limit
if (water_temp> upper_limit)
else if (water_temp> lower_limit)
If if/else instead of switch/case.
Hi.
Thank you for helping me.
This works OK now!
Ewgards
Better would be like this:
const int good = 0;
const int tooLow = -1;
const int tooHigh = 1;
int waterCondition = good;
if (watertemp<min) waterCondition = tooLow;
if (watertemp>max) waterCondition = tooHigh;
switch (waterCondition) {
case good:
case tooLow:
case tooHigh:
Hello Francesco2017
I´ve found this solution
enum WaterTemp {tooLow, tooHigh, good};
uint8_t minTemp {20};
uint8_t maxTemp {40};
uint8_t curTemp {35};
curTemp = 15;
switch (curTemp < minTemp ? tooLow : curTemp > maxTemp ? tooHigh : good)
case tooLow: Serial.println("tooLow");
case tooHigh: Serial.println("tooHigh");
case good: Serial.println("good");
curTemp = 45;
curTemp = 30;
void loop() {}
Result:
tooLow
tooHigh
good
This is not true. Scroll down this code-section to see the number of the last line
1 10 20 30 40
2 01234567890123456789012345678901234567890123456789
3 10 20 30 40
4 01234567890123456789012345678901234567890123456789
5 10 20 30 40
6 01234567890123456789012345678901234567890123456789
7 10 20 30 40
8 01234567890123456789012345678901234567890123456789
9 10 20 30 40
10 01234567890123456789012345678901234567890123456789
11 10 20 30 40
12 01234567890123456789012345678901234567890123456789
13 10 20 30 40
14 01234567890123456789012345678901234567890123456789
15 10 20 30 40
16 01234567890123456789012345678901234567890123456789
17 10 20 30 40
18 01234567890123456789012345678901234567890123456789
19 10 20 30 40
20 01234567890123456789012345678901234567890123456789
21 10 20 30 40
22 01234567890123456789012345678901234567890123456789
23 10 20 30 40
24 01234567890123456789012345678901234567890123456789
25 10 20 30 40
26 01234567890123456789012345678901234567890123456789
27 10 20 30 40
28 01234567890123456789012345678901234567890123456789
29 10 20 30 40
30 01234567890123456789012345678901234567890123456789
31 10 20 30 40
32 01234567890123456789012345678901234567890123456789
33 10 20 30 40
34 01234567890123456789012345678901234567890123456789
35 10 20 30 40
36 01234567890123456789012345678901234567890123456789
37 10 20 30 40
38 01234567890123456789012345678901234567890123456789
39 10 20 30 40
40 01234567890123456789012345678901234567890123456789
41 10 20 30 40
42 01234567890123456789012345678901234567890123456789
43 10 20 30 40
44 01234567890123456789012345678901234567890123456789
45 10 20 30 40
46 01234567890123456789012345678901234567890123456789
47 10 20 30 40
48 01234567890123456789012345678901234567890123456789
49 10 20 30 40
50 01234567890123456789012345678901234567890123456789
51 10 20 30 40
52 01234567890123456789012345678901234567890123456789
53 10 20 30 40
54 01234567890123456789012345678901234567890123456789
55 10 20 30 40
56 01234567890123456789012345678901234567890123456789
57 10 20 30 40
58 01234567890123456789012345678901234567890123456789
59 10 20 30 40
60 01234567890123456789012345678901234567890123456789
61 10 20 30 40
62 01234567890123456789012345678901234567890123456789
63 10 20 30 40
64 01234567890123456789012345678901234567890123456789
65 10 20 30 40
66 01234567890123456789012345678901234567890123456789
67 10 20 30 40
68 01234567890123456789012345678901234567890123456789
69 10 20 30 40
70 01234567890123456789012345678901234567890123456789
71 10 20 30 40
72 01234567890123456789012345678901234567890123456789
73 10 20 30 40
74 01234567890123456789012345678901234567890123456789
75 10 20 30 40
76 01234567890123456789012345678901234567890123456789
77 10 20 30 40
78 01234567890123456789012345678901234567890123456789
79 10 20 30 40
80 01234567890123456789012345678901234567890123456789
81 10 20 30 40
82 01234567890123456789012345678901234567890123456789
83 10 20 30 40
84 01234567890123456789012345678901234567890123456789
85 10 20 30 40
86 01234567890123456789012345678901234567890123456789
87 10 20 30 40
88 01234567890123456789012345678901234567890123456789
89 10 20 30 40
90 01234567890123456789012345678901234567890123456789
91 10 20 30 40
92 01234567890123456789012345678901234567890123456789
93 10 20 30 40
94 01234567890123456789012345678901234567890123456789
95 10 20 30 40
96 01234567890123456789012345678901234567890123456789
97 10 20 30 40
98 01234567890123456789012345678901234567890123456789
99 10 20 30 40
100 01234567890123456789012345678901234567890123456789
101 10 20 30 40
102 01234567890123456789012345678901234567890123456789
103 10 20 30 40
104 01234567890123456789012345678901234567890123456789
105 10 20 30 40
106 01234567890123456789012345678901234567890123456789
107 10 20 30 40
108 01234567890123456789012345678901234567890123456789
109 10 20 30 40
110 01234567890123456789012345678901234567890123456789
111 10 20 30 40
112 01234567890123456789012345678901234567890123456789
113 10 20 30 40
114 01234567890123456789012345678901234567890123456789
115 10 20 30 40
116 01234567890123456789012345678901234567890123456789
117 10 20 30 40
118 01234567890123456789012345678901234567890123456789
119 10 20 30 40
120 01234567890123456789012345678901234567890123456789
121 10 20 30 40
122 01234567890123456789012345678901234567890123456789
123 10 20 30 40
124 01234567890123456789012345678901234567890123456789
125 10 20 30 40
126 01234567890123456789012345678901234567890123456789
127 10 20 30 40
128 01234567890123456789012345678901234567890123456789
129 10 20 30 40
130 01234567890123456789012345678901234567890123456789
131 10 20 30 40
132 01234567890123456789012345678901234567890123456789
133 10 20 30 40
134 01234567890123456789012345678901234567890123456789
135 10 20 30 40
136 01234567890123456789012345678901234567890123456789
137 10 20 30 40
138 01234567890123456789012345678901234567890123456789
139 10 20 30 40
140 01234567890123456789012345678901234567890123456789
141 10 20 30 40
142 01234567890123456789012345678901234567890123456789
143 10 20 30 40
144 01234567890123456789012345678901234567890123456789
145 10 20 30 40
146 01234567890123456789012345678901234567890123456789
147 10 20 30 40
148 01234567890123456789012345678901234567890123456789
149 10 20 30 40
150 01234567890123456789012345678901234567890123456789
151 10 20 30 40
152 01234567890123456789012345678901234567890123456789
153 10 20 30 40
154 01234567890123456789012345678901234567890123456789
155 10 20 30 40
156 01234567890123456789012345678901234567890123456789
157 10 20 30 40
158 01234567890123456789012345678901234567890123456789
159 10 20 30 40
160 01234567890123456789012345678901234567890123456789
161 10 20 30 40
162 01234567890123456789012345678901234567890123456789
163 10 20 30 40
164 01234567890123456789012345678901234567890123456789
165 10 20 30 40
166 01234567890123456789012345678901234567890123456789
167 10 20 30 40
168 01234567890123456789012345678901234567890123456789
169 10 20 30 40
170 01234567890123456789012345678901234567890123456789
171 10 20 30 40
172 01234567890123456789012345678901234567890123456789
173 10 20 30 40
174 01234567890123456789012345678901234567890123456789
175 10 20 30 40
176 01234567890123456789012345678901234567890123456789
177 10 20 30 40
178 01234567890123456789012345678901234567890123456789
179 10 20 30 40
180 01234567890123456789012345678901234567890123456789
181 10 20 30 40
182 01234567890123456789012345678901234567890123456789
183 10 20 30 40
184 01234567890123456789012345678901234567890123456789
185 10 20 30 40
186 01234567890123456789012345678901234567890123456789
187 10 20 30 40
188 01234567890123456789012345678901234567890123456789
189 10 20 30 40
190 01234567890123456789012345678901234567890123456789
191 10 20 30 40
192 01234567890123456789012345678901234567890123456789
193 10 20 30 40
194 01234567890123456789012345678901234567890123456789
195 10 20 30 40
196 01234567890123456789012345678901234567890123456789
197 10 20 30 40
198 01234567890123456789012345678901234567890123456789
199 10 20 30 40
200 01234567890123456789012345678901234567890123456789
201 10 20 30 40
202 01234567890123456789012345678901234567890123456789
203 10 20 30 40
204 01234567890123456789012345678901234567890123456789
205 10 20 30 40
206 01234567890123456789012345678901234567890123456789
207 10 20 30 40
208 01234567890123456789012345678901234567890123456789
209 10 20 30 40
210 01234567890123456789012345678901234567890123456789
211 10 20 30 40
212 01234567890123456789012345678901234567890123456789
213 10 20 30 40
214 01234567890123456789012345678901234567890123456789
215 10 20 30 40
216 01234567890123456789012345678901234567890123456789
217 10 20 30 40
218 01234567890123456789012345678901234567890123456789
219 10 20 30 40
220 01234567890123456789012345678901234567890123456789
221 10 20 30 40
222 01234567890123456789012345678901234567890123456789
223 10 20 30 40
224 01234567890123456789012345678901234567890123456789
225 10 20 30 40
226 01234567890123456789012345678901234567890123456789
227 10 20 30 40
228 01234567890123456789012345678901234567890123456789
229 10 20 30 40
230 01234567890123456789012345678901234567890123456789
231 10 20 30 40
232 01234567890123456789012345678901234567890123456789
233 10 20 30 40
234 01234567890123456789012345678901234567890123456789
235 10 20 30 40
236 01234567890123456789012345678901234567890123456789
237 10 20 30 40
238 01234567890123456789012345678901234567890123456789
239 10 20 30 40
240 01234567890123456789012345678901234567890123456789
241 10 20 30 40
242 01234567890123456789012345678901234567890123456789
243 10 20 30 40
244 01234567890123456789012345678901234567890123456789
245 10 20 30 40
246 01234567890123456789012345678901234567890123456789
247 10 20 30 40
248 01234567890123456789012345678901234567890123456789
249 10 20 30 40
250 01234567890123456789012345678901234567890123456789
251 10 20 30 40
252 01234567890123456789012345678901234567890123456789
253 10 20 30 40
254 01234567890123456789012345678901234567890123456789
255 10 20 30 40
256 01234567890123456789012345678901234567890123456789
257 10 20 30 40
258 01234567890123456789012345678901234567890123456789
259 10 20 30 40
260 01234567890123456789012345678901234567890123456789
261 10 20 30 40
262 01234567890123456789012345678901234567890123456789
263 10 20 30 40
264 01234567890123456789012345678901234567890123456789
265 10 20 30 40
266 01234567890123456789012345678901234567890123456789
267 10 20 30 40
268 01234567890123456789012345678901234567890123456789
269 10 20 30 40
270 01234567890123456789012345678901234567890123456789
271 10 20 30 40
272 01234567890123456789012345678901234567890123456789
273 10 20 30 40
274 01234567890123456789012345678901234567890123456789
275 10 20 30 40
276 01234567890123456789012345678901234567890123456789
277 10 20 30 40
278 01234567890123456789012345678901234567890123456789
279 10 20 30 40
280 01234567890123456789012345678901234567890123456789
281 10 20 30 40
282 01234567890123456789012345678901234567890123456789
283 10 20 30 40
284 01234567890123456789012345678901234567890123456789
285 10 20 30 40
286 01234567890123456789012345678901234567890123456789
287 10 20 30 40
288 01234567890123456789012345678901234567890123456789
289 10 20 30 40
290 01234567890123456789012345678901234567890123456789
291 10 20 30 40
292 01234567890123456789012345678901234567890123456789
293 10 20 30 40
294 01234567890123456789012345678901234567890123456789
295 10 20 30 40
296 01234567890123456789012345678901234567890123456789
297 10 20 30 40
298 01234567890123456789012345678901234567890123456789
299 10 20 30 40
300 01234567890123456789012345678901234567890123456789
301 10 20 30 40
302 01234567890123456789012345678901234567890123456789
303 10 20 30 40
304 01234567890123456789012345678901234567890123456789
305 10 20 30 40
306 01234567890123456789012345678901234567890123456789
307 10 20 30 40
308 01234567890123456789012345678901234567890123456789
309 10 20 30 40
310 01234567890123456789012345678901234567890123456789
311 10 20 30 40
312 01234567890123456789012345678901234567890123456789
313 10 20 30 40
314 01234567890123456789012345678901234567890123456789
315 10 20 30 40
316 01234567890123456789012345678901234567890123456789
317 10 20 30 40
318 01234567890123456789012345678901234567890123456789
319 10 20 30 40
320 01234567890123456789012345678901234567890123456789
321 10 20 30 40
322 01234567890123456789012345678901234567890123456789
323 10 20 30 40
324 01234567890123456789012345678901234567890123456789
325 10 20 30 40
326 01234567890123456789012345678901234567890123456789
327 10 20 30 40
328 01234567890123456789012345678901234567890123456789
329 10 20 30 40
330 01234567890123456789012345678901234567890123456789
331 10 20 30 40
332 01234567890123456789012345678901234567890123456789
333 10 20 30 40
334 01234567890123456789012345678901234567890123456789
335 10 20 30 40
336 01234567890123456789012345678901234567890123456789
337 10 20 30 40
338 01234567890123456789012345678901234567890123456789
339 10 20 30 40
340 01234567890123456789012345678901234567890123456789
341 10 20 30 40
342 01234567890123456789012345678901234567890123456789
343 10 20 30 40
344 01234567890123456789012345678901234567890123456789
345 10 20 30 40
346 01234567890123456789012345678901234567890123456789
347 10 20 30 40
348 01234567890123456789012345678901234567890123456789
349 10 20 30 40
350 01234567890123456789012345678901234567890123456789
351 10 20 30 40
352 01234567890123456789012345678901234567890123456789
353 10 20 30 40
354 01234567890123456789012345678901234567890123456789
355 10 20 30 40
356 01234567890123456789012345678901234567890123456789
357 10 20 30 40
358 01234567890123456789012345678901234567890123456789
359 10 20 30 40
360 01234567890123456789012345678901234567890123456789
361 10 20 30 40
362 01234567890123456789012345678901234567890123456789
363 10 20 30 40
364 01234567890123456789012345678901234567890123456789
365 10 20 30 40
366 01234567890123456789012345678901234567890123456789
367 10 20 30 40
368 01234567890123456789012345678901234567890123456789
369 10 20 30 40
370 01234567890123456789012345678901234567890123456789
371 10 20 30 40
372 01234567890123456789012345678901234567890123456789
373 10 20 30 40
374 01234567890123456789012345678901234567890123456789
375 10 20 30 40
376 01234567890123456789012345678901234567890123456789
377 10 20 30 40
378 01234567890123456789012345678901234567890123456789
379 10 20 30 40
380 01234567890123456789012345678901234567890123456789
381 10 20 30 40
382 01234567890123456789012345678901234567890123456789
383 10 20 30 40
384 01234567890123456789012345678901234567890123456789
385 10 20 30 40
386 01234567890123456789012345678901234567890123456789
387 10 20 30 40
388 01234567890123456789012345678901234567890123456789
389 10 20 30 40
390 01234567890123456789012345678901234567890123456789
391 10 20 30 40
392 01234567890123456789012345678901234567890123456789
393 10 20 30 40
394 01234567890123456789012345678901234567890123456789
395 10 20 30 40
396 01234567890123456789012345678901234567890123456789
397 10 20 30 40
398 01234567890123456789012345678901234567890123456789
399 10 20 30 40
400 01234567890123456789012345678901234567890123456789
401 10 20 30 40
402 01234567890123456789012345678901234567890123456789
403 10 20 30 40
404 01234567890123456789012345678901234567890123456789
405 10 20 30 40
406 01234567890123456789012345678901234567890123456789
407 10 20 30 40
408 01234567890123456789012345678901234567890123456789
409 10 20 30 40
410 01234567890123456789012345678901234567890123456789
411 10 20 30 40
412 01234567890123456789012345678901234567890123456789
413 10 20 30 40
414 01234567890123456789012345678901234567890123456789
415 10 20 30 40
416 01234567890123456789012345678901234567890123456789
417 10 20 30 40
418 01234567890123456789012345678901234567890123456789
419 10 20 30 40
420 01234567890123456789012345678901234567890123456789
421 10 20 30 40
422 01234567890123456789012345678901234567890123456789
423 10 20 30 40
424 01234567890123456789012345678901234567890123456789
425 10 20 30 40
426 01234567890123456789012345678901234567890123456789
427 10 20 30 40
428 01234567890123456789012345678901234567890123456789
429 10 20 30 40
430 01234567890123456789012345678901234567890123456789
431 10 20 30 40
432 01234567890123456789012345678901234567890123456789
433 10 20 30 40
434 01234567890123456789012345678901234567890123456789
435 10 20 30 40
436 01234567890123456789012345678901234567890123456789
437 10 20 30 40
438 01234567890123456789012345678901234567890123456789
439 10 20 30 40
440 01234567890123456789012345678901234567890123456789
441 10 20 30 40
442 01234567890123456789012345678901234567890123456789
443 10 20 30 40
444 01234567890123456789012345678901234567890123456789
445 10 20 30 40
446 01234567890123456789012345678901234567890123456789
447 10 20 30 40
448 01234567890123456789012345678901234567890123456789
449 10 20 30 40
450 01234567890123456789012345678901234567890123456789
451 10 20 30 40
452 01234567890123456789012345678901234567890123456789
453 10 20 30 40
454 01234567890123456789012345678901234567890123456789
455 10 20 30 40
456 01234567890123456789012345678901234567890123456789
457 10 20 30 40
458 01234567890123456789012345678901234567890123456789
459 10 20 30 40
460 01234567890123456789012345678901234567890123456789
461 10 20 30 40
462 01234567890123456789012345678901234567890123456789
463 10 20 30 40
464 01234567890123456789012345678901234567890123456789
465 10 20 30 40
466 01234567890123456789012345678901234567890123456789
467 10 20 30 40
468 01234567890123456789012345678901234567890123456789
469 10 20 30 40
470 01234567890123456789012345678901234567890123456789
471 10 20 30 40
472 01234567890123456789012345678901234567890123456789
473 10 20 30 40
474 01234567890123456789012345678901234567890123456789
475 10 20 30 40
476 01234567890123456789012345678901234567890123456789
477 10 20 30 40
478 01234567890123456789012345678901234567890123456789
479 10 20 30 40
480 01234567890123456789012345678901234567890123456789
481 10 20 30 40
482 01234567890123456789012345678901234567890123456789
483 10 20 30 40
484 01234567890123456789012345678901234567890123456789
485 10 20 30 40
486 01234567890123456789012345678901234567890123456789
487 10 20 30 40
488 01234567890123456789012345678901234567890123456789
489 10 20 30 40
490 01234567890123456789012345678901234567890123456789
491 10 20 30 40
492 01234567890123456789012345678901234567890123456789
493 10 20 30 40
494 01234567890123456789012345678901234567890123456789
495 10 20 30 40
496 01234567890123456789012345678901234567890123456789
497 10 20 30 40
498 01234567890123456789012345678901234567890123456789
499 10 20 30 40
500 01234567890123456789012345678901234567890123456789
501 10 20 30 40
502 01234567890123456789012345678901234567890123456789
503 10 20 30 40
504 01234567890123456789012345678901234567890123456789
505 10 20 30 40
506 01234567890123456789012345678901234567890123456789
507 10 20 30 40
508 01234567890123456789012345678901234567890123456789
509 10 20 30 40
510 01234567890123456789012345678901234567890123456789
511 10 20 30 40
512 01234567890123456789012345678901234567890123456789
513 10 20 30 40
514 01234567890123456789012345678901234567890123456789
515 10 20 30 40
516 01234567890123456789012345678901234567890123456789
517 10 20 30 40
518 01234567890123456789012345678901234567890123456789
519 10 20 30 40
520 01234567890123456789012345678901234567890123456789
521 10 20 30 40
522 01234567890123456789012345678901234567890123456789
523 10 20 30 40
524 01234567890123456789012345678901234567890123456789
525 10 20 30 40
526 01234567890123456789012345678901234567890123456789
527 10 20 30 40
528 01234567890123456789012345678901234567890123456789
529 10 20 30 40
530 01234567890123456789012345678901234567890123456789
531 10 20 30 40
532 01234567890123456789012345678901234567890123456789
533 10 20 30 40
534 01234567890123456789012345678901234567890123456789
535 10 20 30 40
536 01234567890123456789012345678901234567890123456789
537 10 20 30 40
538 01234567890123456789012345678901234567890123456789
539 10 20 30 40
540 01234567890123456789012345678901234567890123456789
541 10 20 30 40
542 01234567890123456789012345678901234567890123456789
543 10 20 30 40
544 01234567890123456789012345678901234567890123456789
545 10 20 30 40
546 01234567890123456789012345678901234567890123456789
547 10 20 30 40
548 01234567890123456789012345678901234567890123456789
549 10 20 30 40
550 01234567890123456789012345678901234567890123456789
551 10 20 30 40
552 01234567890123456789012345678901234567890123456789
553 10 20 30 40
554 01234567890123456789012345678901234567890123456789
555 10 20 30 40
556 01234567890123456789012345678901234567890123456789
557 10 20 30 40
558 01234567890123456789012345678901234567890123456789
559 10 20 30 40
560 01234567890123456789012345678901234567890123456789
561 10 20 30 40
562 01234567890123456789012345678901234567890123456789
563 10 20 30 40
564 01234567890123456789012345678901234567890123456789
565 10 20 30 40
566 01234567890123456789012345678901234567890123456789
567 10 20 30 40
568 01234567890123456789012345678901234567890123456789
569 10 20 30 40
570 01234567890123456789012345678901234567890123456789
571 10 20 30 40
572 01234567890123456789012345678901234567890123456789
573 10 20 30 40
574 01234567890123456789012345678901234567890123456789
575 10 20 30 40
576 01234567890123456789012345678901234567890123456789
577 10 20 30 40
578 01234567890123456789012345678901234567890123456789
579 10 20 30 40
580 01234567890123456789012345678901234567890123456789
581 10 20 30 40
582 01234567890123456789012345678901234567890123456789
583 10 20 30 40
584 01234567890123456789012345678901234567890123456789
585 10 20 30 40
586 01234567890123456789012345678901234567890123456789
587 10 20 30 40
588 01234567890123456789012345678901234567890123456789
589 10 20 30 40
590 01234567890123456789012345678901234567890123456789
591 10 20 30 40
592 01234567890123456789012345678901234567890123456789
593 10 20 30 40
594 01234567890123456789012345678901234567890123456789
595 10 20 30 40
596 01234567890123456789012345678901234567890123456789
597 10 20 30 40
598 01234567890123456789012345678901234567890123456789
599 10 20 30 40
600 01234567890123456789012345678901234567890123456789
601 10 20 30 40
602 01234567890123456789012345678901234567890123456789
603 10 20 30 40
604 01234567890123456789012345678901234567890123456789
605 10 20 30 40
606 01234567890123456789012345678901234567890123456789
607 10 20 30 40
608 01234567890123456789012345678901234567890123456789
609 10 20 30 40
610 01234567890123456789012345678901234567890123456789
611 10 20 30 40
612 01234567890123456789012345678901234567890123456789
613 10 20 30 40
614 01234567890123456789012345678901234567890123456789
615 10 20 30 40
616 01234567890123456789012345678901234567890123456789
617 10 20 30 40
618 01234567890123456789012345678901234567890123456789
619 10 20 30 40
620 01234567890123456789012345678901234567890123456789
621 10 20 30 40
622 01234567890123456789012345678901234567890123456789
623 10 20 30 40
624 01234567890123456789012345678901234567890123456789
625 10 20 30 40
626 01234567890123456789012345678901234567890123456789
627 10 20 30 40
628 01234567890123456789012345678901234567890123456789
629 10 20 30 40
630 01234567890123456789012345678901234567890123456789
631 10 20 30 40
632 01234567890123456789012345678901234567890123456789
633 10 20 30 40
634 01234567890123456789012345678901234567890123456789
635 10 20 30 40
636 01234567890123456789012345678901234567890123456789
637 10 20 30 40
638 01234567890123456789012345678901234567890123456789
639 10 20 30 40
640 01234567890123456789012345678901234567890123456789
641 10 20 30 40
642 01234567890123456789012345678901234567890123456789
643 10 20 30 40
644 01234567890123456789012345678901234567890123456789
645 10 20 30 40
646 01234567890123456789012345678901234567890123456789
647 10 20 30 40
648 01234567890123456789012345678901234567890123456789
649 10 20 30 40
650 01234567890123456789012345678901234567890123456789
651 10 20 30 40
652 01234567890123456789012345678901234567890123456789
653 10 20 30 40
654 01234567890123456789012345678901234567890123456789
655 10 20 30 40
656 01234567890123456789012345678901234567890123456789
657 10 20 30 40
658 01234567890123456789012345678901234567890123456789
659 10 20 30 40
660 01234567890123456789012345678901234567890123456789
661 10 20 30 40
662 01234567890123456789012345678901234567890123456789
663 10 20 30 40
664 01234567890123456789012345678901234567890123456789
665 10 20 30 40
666 01234567890123456789012345678901234567890123456789
667 10 20 30 40
668 01234567890123456789012345678901234567890123456789
669 10 20 30 40
670 01234567890123456789012345678901234567890123456789
671 10 20 30 40
672 01234567890123456789012345678901234567890123456789
673 10 20 30 40
674 01234567890123456789012345678901234567890123456789
675 10 20 30 40
676 01234567890123456789012345678901234567890123456789
677 10 20 30 40
678 01234567890123456789012345678901234567890123456789
679 10 20 30 40
680 01234567890123456789012345678901234567890123456789
681 10 20 30 40
682 01234567890123456789012345678901234567890123456789
683 10 20 30 40
684 01234567890123456789012345678901234567890123456789
685 10 20 30 40
686 01234567890123456789012345678901234567890123456789
687 10 20 30 40
688 01234567890123456789012345678901234567890123456789
689 10 20 30 40
690 01234567890123456789012345678901234567890123456789
691 10 20 30 40
692 01234567890123456789012345678901234567890123456789
693 10 20 30 40
694 01234567890123456789012345678901234567890123456789
695 10 20 30 40
696 01234567890123456789012345678901234567890123456789
697 10 20 30 40
698 01234567890123456789012345678901234567890123456789
699 10 20 30 40
700 01234567890123456789012345678901234567890123456789
701 10 20 30 40
702 01234567890123456789012345678901234567890123456789
703 10 20 30 40
704 01234567890123456789012345678901234567890123456789
705 10 20 30 40
706 01234567890123456789012345678901234567890123456789
707 10 20 30 40
708 01234567890123456789012345678901234567890123456789
709 10 20 30 40
710 01234567890123456789012345678901234567890123456789
711 10 20 30 40
712 01234567890123456789012345678901234567890123456789
713 10 20 30 40
714 01234567890123456789012345678901234567890123456789
715 10 20 30 40
716 01234567890123456789012345678901234567890123456789
717 10 20 30 40
718 01234567890123456789012345678901234567890123456789
719 10 20 30 40
720 01234567890123456789012345678901234567890123456789
721 10 20 30 40
722 01234567890123456789012345678901234567890123456789
723 10 20 30 40
724 01234567890123456789012345678901234567890123456789
725 10 20 30 40
726 01234567890123456789012345678901234567890123456789
727 10 20 30 40
728 01234567890123456789012345678901234567890123456789
729 10 20 30 40
730 01234567890123456789012345678901234567890123456789
731 10 20 30 40
732 01234567890123456789012345678901234567890123456789
733 10 20 30 40
734 01234567890123456789012345678901234567890123456789
735 10 20 30 40
736 01234567890123456789012345678901234567890123456789
737 10 20 30 40
738 01234567890123456789012345678901234567890123456789
739 10 20 30 40
740 01234567890123456789012345678901234567890123456789
741 10 20 30 40
742 01234567890123456789012345678901234567890123456789
743 10 20 30 40
744 01234567890123456789012345678901234567890123456789
745 10 20 30 40
746 01234567890123456789012345678901234567890123456789
747 10 20 30 40
748 01234567890123456789012345678901234567890123456789
749 10 20 30 40
750 01234567890123456789012345678901234567890123456789
751 10 20 30 40
752 01234567890123456789012345678901234567890123456789
753 10 20 30 40
754 01234567890123456789012345678901234567890123456789
755 10 20 30 40
756 01234567890123456789012345678901234567890123456789
757 10 20 30 40
758 01234567890123456789012345678901234567890123456789
759 10 20 30 40
760 01234567890123456789012345678901234567890123456789
761 10 20 30 40
762 01234567890123456789012345678901234567890123456789
763 10 20 30 40
764 01234567890123456789012345678901234567890123456789
765 10 20 30 40
766 01234567890123456789012345678901234567890123456789
767 10 20 30 40
768 01234567890123456789012345678901234567890123456789
769 10 20 30 40
770 01234567890123456789012345678901234567890123456789
771 10 20 30 40
772 01234567890123456789012345678901234567890123456789
773 10 20 30 40
774 01234567890123456789012345678901234567890123456789
775 10 20 30 40
776 01234567890123456789012345678901234567890123456789
777 10 20 30 40
778 01234567890123456789012345678901234567890123456789
779 10 20 30 40
780 01234567890123456789012345678901234567890123456789
781 10 20 30 40
782 01234567890123456789012345678901234567890123456789
783 10 20 30 40
784 01234567890123456789012345678901234567890123456789
785 10 20 30 40
786 01234567890123456789012345678901234567890123456789
787 10 20 30 40
788 01234567890123456789012345678901234567890123456789
789 10 20 30 40
790 01234567890123456789012345678901234567890123456789
791 10 20 30 40
792 01234567890123456789012345678901234567890123456789
793 10 20 30 40
794 01234567890123456789012345678901234567890123456789
795 10 20 30 40
796 01234567890123456789012345678901234567890123456789
797 10 20 30 40
798 01234567890123456789012345678901234567890123456789
799 10 20 30 40
800 01234567890123456789012345678901234567890123456789
801 10 20 30 40
802 01234567890123456789012345678901234567890123456789
803 10 20 30 40
804 01234567890123456789012345678901234567890123456789
805 10 20 30 40
806 01234567890123456789012345678901234567890123456789
807 10 20 30 40
808 01234567890123456789012345678901234567890123456789
809 10 20 30 40
810 01234567890123456789012345678901234567890123456789
811 10 20 30 40
812 01234567890123456789012345678901234567890123456789
813 10 20 30 40
814 01234567890123456789012345678901234567890123456789
815 10 20 30 40
816 01234567890123456789012345678901234567890123456789
817 10 20 30 40
818 01234567890123456789012345678901234567890123456789
819 10 20 30 40
820 01234567890123456789012345678901234567890123456789
821 10 20 30 40
822 01234567890123456789012345678901234567890123456789
823 10 20 30 40
824 01234567890123456789012345678901234567890123456789
825 10 20 30 40
826 01234567890123456789012345678901234567890123456789
827 10 20 30 40
828 01234567890123456789012345678901234567890123456789
829 10 20 30 40
830 01234567890123456789012345678901234567890123456789
831 10 20 30 40
832 01234567890123456789012345678901234567890123456789
833 10 20 30 40
834 01234567890123456789012345678901234567890123456789
835 10 20 30 40
836 01234567890123456789012345678901234567890123456789
837 10 20 30 40
838 01234567890123456789012345678901234567890123456789
839 10 20 30 40
840 01234567890123456789012345678901234567890123456789
841 10 20 30 40
842 01234567890123456789012345678901234567890123456789
843 10 20 30 40
844 01234567890123456789012345678901234567890123456789
845 10 20 30 40
846 01234567890123456789012345678901234567890123456789
847 10 20 30 40
848 01234567890123456789012345678901234567890123456789
849 10 20 30 40
850 01234567890123456789012345678901234567890123456789
851 10 20 30 40
852 01234567890123456789012345678901234567890123456789
853 10 20 30 40
854 01234567890123456789012345678901234567890123456789
855 10 20 30 40
856 01234567890123456789012345678901234567890123456789
857 10 20 30 40
858 01234567890123456789012345678901234567890123456789
859 10 20 30 40
860 01234567890123456789012345678901234567890123456789
861 10 20 30 40
862 01234567890123456789012345678901234567890123456789
863 10 20 30 40
864 01234567890123456789012345678901234567890123456789
865 10 20 30 40
866 01234567890123456789012345678901234567890123456789
867 10 20 30 40
868 01234567890123456789012345678901234567890123456789
869 10 20 30 40
870 01234567890123456789012345678901234567890123456789
871 10 20 30 40
872 01234567890123456789012345678901234567890123456789
873 10 20 30 40
874 01234567890123456789012345678901234567890123456789
875 10 20 30 40
876 01234567890123456789012345678901234567890123456789
877 10 20 30 40
878 01234567890123456789012345678901234567890123456789
879 10 20 30 40
880 01234567890123456789012345678901234567890123456789
881 10 20 30 40
882 01234567890123456789012345678901234567890123456789
883 10 20 30 40
884 01234567890123456789012345678901234567890123456789
885 10 20 30 40
886 01234567890123456789012345678901234567890123456789
887 10 20 30 40
888 01234567890123456789012345678901234567890123456789
889 10 20 30 40
890 01234567890123456789012345678901234567890123456789
891 10 20 30 40
892 01234567890123456789012345678901234567890123456789
893 10 20 30 40
894 01234567890123456789012345678901234567890123456789
895 10 20 30 40
896 01234567890123456789012345678901234567890123456789
897 10 20 30 40
898 01234567890123456789012345678901234567890123456789
899 10 20 30 40
900 01234567890123456789012345678901234567890123456789
901 10 20 30 40
902 01234567890123456789012345678901234567890123456789
903 10 20 30 40
904 01234567890123456789012345678901234567890123456789
905 10 20 30 40
906 01234567890123456789012345678901234567890123456789
907 10 20 30 40
908 01234567890123456789012345678901234567890123456789
909 10 20 30 40
910 01234567890123456789012345678901234567890123456789
911 10 20 30 40
912 01234567890123456789012345678901234567890123456789
913 10 20 30 40
914 01234567890123456789012345678901234567890123456789
915 10 20 30 40
916 01234567890123456789012345678901234567890123456789
917 10 20 30 40
918 01234567890123456789012345678901234567890123456789
919 10 20 30 40
920 01234567890123456789012345678901234567890123456789
921 10 20 30 40
922 01234567890123456789012345678901234567890123456789
923 10 20 30 40
924 01234567890123456789012345678901234567890123456789
925 10 20 30 40
926 01234567890123456789012345678901234567890123456789
927 10 20 30 40
928 01234567890123456789012345678901234567890123456789
929 10 20 30 40
930 01234567890123456789012345678901234567890123456789
931 10 20 30 40
932 01234567890123456789012345678901234567890123456789
933 10 20 30 40
934 01234567890123456789012345678901234567890123456789
935 10 20 30 40
936 01234567890123456789012345678901234567890123456789
937 10 20 30 40
938 01234567890123456789012345678901234567890123456789
939 10 20 30 40
940 01234567890123456789012345678901234567890123456789
941 10 20 30 40
942 01234567890123456789012345678901234567890123456789
943 10 20 30 40
944 01234567890123456789012345678901234567890123456789
945 10 20 30 40
946 01234567890123456789012345678901234567890123456789
947 10 20 30 40
948 01234567890123456789012345678901234567890123456789
949 10 20 30 40
950 01234567890123456789012345678901234567890123456789
951 10 20 30 40
952 01234567890123456789012345678901234567890123456789
953 10 20 30 40
954 01234567890123456789012345678901234567890123456789
955 10 20 30 40
956 01234567890123456789012345678901234567890123456789
957 10 20 30 40
958 01234567890123456789012345678901234567890123456789
959 10 20 30 40
960 01234567890123456789012345678901234567890123456789
961 10 20 30 40
962 01234567890123456789012345678901234567890123456789
963 10 20 30 40
964 01234567890123456789012345678901234567890123456789
965 10 20 30 40
966 01234567890123456789012345678901234567890123456789
967 10 20 30 40
968 01234567890123456789012345678901234567890123456789
969 10 20 30 40
970 01234567890123456789012345678901234567890123456789
971 10 20 30 40
972 01234567890123456789012345678901234567890123456789
973 10 20 30 40
974 01234567890123456789012345678901234567890123456789
975 10 20 30 40
976 01234567890123456789012345678901234567890123456789
977 10 20 30 40
978 01234567890123456789012345678901234567890123456789
979 10 20 30 40
980 01234567890123456789012345678901234567890123456789
981 10 20 30 40
982 01234567890123456789012345678901234567890123456789
983 10 20 30 40
984 01234567890123456789012345678901234567890123456789
985 10 20 30 40
986 01234567890123456789012345678901234567890123456789
987 10 20 30 40
988 01234567890123456789012345678901234567890123456789
989 10 20 30 40
990 01234567890123456789012345678901234567890123456789
991 10 20 30 40
992 01234567890123456789012345678901234567890123456789
993 10 20 30 40
994 01234567890123456789012345678901234567890123456789
995 10 20 30 40
996 01234567890123456789012345678901234567890123456789
997 10 20 30 40
998 01234567890123456789012345678901234567890123456789
999 10 20 30 40
1000 01234567890123456789012345678901234567890123456789
1001 10 20 30 40
1002 01234567890123456789012345678901234567890123456789
1003 10 20 30 40
1004 01234567890123456789012345678901234567890123456789
1005 10 20 30 40
1006 01234567890123456789012345678901234567890123456789
1007 10 20 30 40
1008 01234567890123456789012345678901234567890123456789
1009 10 20 30 40
1010 01234567890123456789012345678901234567890123456789
1011 10 20 30 40
1012 01234567890123456789012345678901234567890123456789
1013 10 20 30 40
1014 01234567890123456789012345678901234567890123456789
1015 10 20 30 40
1016 01234567890123456789012345678901234567890123456789
1017 10 20 30 40
1018 01234567890123456789012345678901234567890123456789
1019 10 20 30 40
1020 01234567890123456789012345678901234567890123456789
1021 10 20 30 40
1022 01234567890123456789012345678901234567890123456789
1023 10 20 30 40
1024 01234567890123456789012345678901234567890123456789
1025 10 20 30 40
1026 01234567890123456789012345678901234567890123456789
1027 10 20 30 40
1028 01234567890123456789012345678901234567890123456789
1029 10 20 30 40
1030 01234567890123456789012345678901234567890123456789
1031 10 20 30 40
1032 01234567890123456789012345678901234567890123456789
1033 10 20 30 40
1034 01234567890123456789012345678901234567890123456789
1035 10 20 30 40
1036 01234567890123456789012345678901234567890123456789
1037 10 20 30 40
1038 01234567890123456789012345678901234567890123456789
1039 10 20 30 40
1040 01234567890123456789012345678901234567890123456789
1041 10 20 30 40
1042 01234567890123456789012345678901234567890123456789
1043 10 20 30 40
1044 01234567890123456789012345678901234567890123456789
1045 10 20 30 40
1046 01234567890123456789012345678901234567890123456789
1047 10 20 30 40
1048 01234567890123456789012345678901234567890123456789
1049 10 20 30 40
1050 01234567890123456789012345678901234567890123456789
1051 10 20 30 40
1052 01234567890123456789012345678901234567890123456789
1053 10 20 30 40
1054 01234567890123456789012345678901234567890123456789
1055 10 20 30 40
1056 01234567890123456789012345678901234567890123456789
1057 10 20 30 40
1058 01234567890123456789012345678901234567890123456789
1059 10 20 30 40
1060 01234567890123456789012345678901234567890123456789
1061 10 20 30 40
1062 01234567890123456789012345678901234567890123456789
1063 10 20 30 40
1064 01234567890123456789012345678901234567890123456789
1065 10 20 30 40
1066 01234567890123456789012345678901234567890123456789
1067 10 20 30 40
1068 01234567890123456789012345678901234567890123456789
1069 10 20 30 40
1070 01234567890123456789012345678901234567890123456789
1071 10 20 30 40
1072 01234567890123456789012345678901234567890123456789
1073 10 20 30 40
1074 01234567890123456789012345678901234567890123456789
1075 10 20 30 40
1076 01234567890123456789012345678901234567890123456789
1077 10 20 30 40
1078 01234567890123456789012345678901234567890123456789
1079 10 20 30 40
1080 01234567890123456789012345678901234567890123456789
1081 10 20 30 40
1082 01234567890123456789012345678901234567890123456789
1083 10 20 30 40
1084 01234567890123456789012345678901234567890123456789
1085 10 20 30 40
1086 01234567890123456789012345678901234567890123456789
1087 10 20 30 40
1088 01234567890123456789012345678901234567890123456789
1089 10 20 30 40
1090 01234567890123456789012345678901234567890123456789
1091 10 20 30 40
1092 01234567890123456789012345678901234567890123456789
1093 10 20 30 40
1094 01234567890123456789012345678901234567890123456789
1095 10 20 30 40
1096 01234567890123456789012345678901234567890123456789
1097 10 20 30 40
1098 01234567890123456789012345678901234567890123456789
1099 10 20 30 40
1100 01234567890123456789012345678901234567890123456789
1101 10 20 30 40
1102 01234567890123456789012345678901234567890123456789
1103 10 20 30 40
1104 01234567890123456789012345678901234567890123456789
1105 10 20 30 40
1106 01234567890123456789012345678901234567890123456789
1107 10 20 30 40
1108 01234567890123456789012345678901234567890123456789
1109 10 20 30 40
1110 01234567890123456789012345678901234567890123456789
1111 10 20 30 40
1112 01234567890123456789012345678901234567890123456789
1113 10 20 30 40
1114 01234567890123456789012345678901234567890123456789
1115 10 20 30 40
1116 01234567890123456789012345678901234567890123456789
1117 10 20 30 40
1118 01234567890123456789012345678901234567890123456789
1119 10 20 30 40
1120 01234567890123456789012345678901234567890123456789
1121 10 20 30 40
1122 01234567890123456789012345678901234567890123456789
1123 10 20 30 40
1124 01234567890123456789012345678901234567890123456789
1125 10 20 30 40
1126 01234567890123456789012345678901234567890123456789
1127 10 20 30 40
1128 01234567890123456789012345678901234567890123456789
1129 10 20 30 40
1130 01234567890123456789012345678901234567890123456789
1131 10 20 30 40
1132 01234567890123456789012345678901234567890123456789
1133 10 20 30 40
1134 01234567890123456789012345678901234567890123456789
1135 10 20 30 40
1136 01234567890123456789012345678901234567890123456789
1137 10 20 30 40
1138 01234567890123456789012345678901234567890123456789
1139 10 20 30 40
1140 01234567890123456789012345678901234567890123456789
1141 10 20 30 40
1142 01234567890123456789012345678901234567890123456789
1143 10 20 30 40
1144 01234567890123456789012345678901234567890123456789
1145 10 20 30 40
1146 01234567890123456789012345678901234567890123456789
1147 10 20 30 40
1148 01234567890123456789012345678901234567890123456789
1149 10 20 30 40
1150 01234567890123456789012345678901234567890123456789
1151 10 20 30 40
1152 01234567890123456789012345678901234567890123456789
1153 10 20 30 40
1154 01234567890123456789012345678901234567890123456789
1155 10 20 30 40
1156 01234567890123456789012345678901234567890123456789
1157 10 20 30 40
1158 01234567890123456789012345678901234567890123456789
1159 10 20 30 40
1160 01234567890123456789012345678901234567890123456789
1161 10 20 30 40
1162 01234567890123456789012345678901234567890123456789
1163 10 20 30 40
1164 01234567890123456789012345678901234567890123456789
1165 10 20 30 40
1166 01234567890123456789012345678901234567890123456789
1167 10 20 30 40
1168 01234567890123456789012345678901234567890123456789
1169 10 20 30 40
1170 01234567890123456789012345678901234567890123456789
1171 10 20 30 40
1172 01234567890123456789012345678901234567890123456789
1173 10 20 30 40
1174 01234567890123456789012345678901234567890123456789
1175 10 20 30 40
1176 01234567890123456789012345678901234567890123456789
1177 10 20 30 40
1178 01234567890123456789012345678901234567890123456789
1179 10 20 30 40
1180 01234567890123456789012345678901234567890123456789
1181 10 20 30 40
1182 01234567890123456789012345678901234567890123456789
1183 10 20 30 40
1184 01234567890123456789012345678901234567890123456789
1185 10 20 30 40
1186 01234567890123456789012345678901234567890123456789
1187 10 20 30 40
1188 01234567890123456789012345678901234567890123456789
1189 10 20 30 40
1190 01234567890123456789012345678901234567890123456789
1191 10 20 30 40
1192 01234567890123456789012345678901234567890123456789
1193 10 20 30 40
1194 01234567890123456789012345678901234567890123456789
1195 10 20 30 40
1196 01234567890123456789012345678901234567890123456789
1197 10 20 30 40
1198 01234567890123456789012345678901234567890123456789
1199 10 20 30 40
1200 01234567890123456789012345678901234567890123456789
1201 10 20 30 40
1202 01234567890123456789012345678901234567890123456789
1203 10 20 30 40
1204 01234567890123456789012345678901234567890123456789
1205 10 20 30 40
1206 01234567890123456789012345678901234567890123456789
1207 10 20 30 40
1208 01234567890123456789012345678901234567890123456789
1209 10 20 30 40
1210 01234567890123456789012345678901234567890123456789
1211 10 20 30 40
1212 01234567890123456789012345678901234567890123456789
1213 10 20 30 40
1214 01234567890123456789012345678901234567890123456789
1215 10 20 30 40
1216 01234567890123456789012345678901234567890123456789
1217 10 20 30 40
1218 01234567890123456789012345678901234567890123456789
1219 10 20 30 40
1220 01234567890123456789012345678901234567890123456789
1221 10 20 30 40
1222 01234567890123456789012345678901234567890123456789
1223 10 20 30 40
1224 01234567890123456789012345678901234567890123456789
1225 10 20 30 40
1226 01234567890123456789012345678901234567890123456789
1227 10 20 30 40
1228 01234567890123456789012345678901234567890123456789
1229 10 20 30 40
1230 01234567890123456789012345678901234567890123456789
1231 10 20 30 40
1232 01234567890123456789012345678901234567890123456789
1233 10 20 30 40
1234 01234567890123456789012345678901234567890123456789
1235 10 20 30 40
1236 01234567890123456789012345678901234567890123456789
1237 10 20 30 40
1238 01234567890123456789012345678901234567890123456789
1239 10 20 30 40
1240 01234567890123456789012345678901234567890123456789
1241 10 20 30 40
1242 01234567890123456789012345678901234567890123456789
1243 10 20 30 40
1244 01234567890123456789012345678901234567890123456789
1245 10 20 30 40
1246 01234567890123456789012345678901234567890123456789
1247 10 20 30 40
1248 01234567890123456789012345678901234567890123456789
1249 10 20 30 40
1250 01234567890123456789012345678901234567890123456789
1251 10 20 30 40
1252 01234567890123456789012345678901234567890123456789
1253 10 20 30 40
1254 01234567890123456789012345678901234567890123456789
1255 10 20 30 40
1256 01234567890123456789012345678901234567890123456789
1257 10 20 30 40
1258 01234567890123456789012345678901234567890123456789
1259 10 20 30 40
1260 01234567890123456789012345678901234567890123456789
1261 10 20 30 40
1262 01234567890123456789012345678901234567890123456789
1263 10 20 30 40
1264 01234567890123456789012345678901234567890123456789
1265 10 20 30 40
1266 01234567890123456789012345678901234567890123456789
1267 10 20 30 40
1268 01234567890123456789012345678901234567890123456789
1269 10 20 30 40
1270 01234567890123456789012345678901234567890123456789
1271 10 20 30 40
1272 01234567890123456789012345678901234567890123456789
1273 10 20 30 40
1274 01234567890123456789012345678901234567890123456789
1275 10 20 30 40
1276 01234567890123456789012345678901234567890123456789
1277 10 20 30 40
1278 01234567890123456789012345678901234567890123456789
1279 10 20 30 40
1280 01234567890123456789012345678901234567890123456789
1281 10 20 30 40
1282 01234567890123456789012345678901234567890123456789
1283 10 20 30 40
1284 01234567890123456789012345678901234567890123456789
1285 10 20 30 40
1286 01234567890123456789012345678901234567890123456789
1287 10 20 30 40
1288 01234567890123456789012345678901234567890123456789
1289 10 20 30 40
1290 01234567890123456789012345678901234567890123456789
1291 10 20 30 40
1292 01234567890123456789012345678901234567890123456789
1293 10 20 30 40
1294 01234567890123456789012345678901234567890123456789
1295 10 20 30 40
1296 01234567890123456789012345678901234567890123456789
1297 10 20 30 40
1298 01234567890123456789012345678901234567890123456789
1299 10 20 30 40
1300 01234567890123456789012345678901234567890123456789
1301 10 20 30 40
1302 01234567890123456789012345678901234567890123456789
1303 10 20 30 40
1304 01234567890123456789012345678901234567890123456789
1305 10 20 30 40
1306 01234567890123456789012345678901234567890123456789
1307 10 20 30 40
1308 01234567890123456789012345678901234567890123456789
1309 10 20 30 40
1310 01234567890123456789012345678901234567890123456789
1311 10 20 30 40
1312 01234567890123456789012345678901234567890123456789
1313 10 20 30 40
1314 01234567890123456789012345678901234567890123456789
1315 10 20 30 40
1316 01234567890123456789012345678901234567890123456789
1317 10 20 30 40
1318 01234567890123456789012345678901234567890123456789
1319 10 20 30 40
1320 01234567890123456789012345678901234567890123456789
1321 10 20 30 40
1322 01234567890123456789012345678901234567890123456789
1323 10 20 30 40
1324 01234567890123456789012345678901234567890123456789
1325 10 20 30 40
1326 01234567890123456789012345678901234567890123456789
1327 10 20 30 40
1328 01234567890123456789012345678901234567890123456789
1329 10 20 30 40
1330 01234567890123456789012345678901234567890123456789
1331 10 20 30 40
1332 01234567890123456789012345678901234567890123456789
1333 10 20 30 40
1334 01234567890123456789012345678901234567890123456789
1335 10 20 30 40
1336 01234567890123456789012345678901234567890123456789
1337 10 20 30 40
1338 01234567890123456789012345678901234567890123456789
1339 10 20 30 40
1340 01234567890123456789012345678901234567890123456789
1341 10 20 30 40
1342 01234567890123456789012345678901234567890123456789
1343 10 20 30 40
1344 01234567890123456789012345678901234567890123456789
1345 10 20 30 40
1346 01234567890123456789012345678901234567890123456789
1347 10 20 30 40
1348 01234567890123456789012345678901234567890123456789
1349 10 20 30 40
1350 01234567890123456789012345678901234567890123456789
1351 10 20 30 40
1352 01234567890123456789012345678901234567890123456789
1353 10 20 30 40
1354 01234567890123456789012345678901234567890123456789
1355 10 20 30 40
1356 01234567890123456789012345678901234567890123456789
1357 10 20 30 40
1358 01234567890123456789012345678901234567890123456789
1359 10 20 30 40
1360 01234567890123456789012345678901234567890123456789
1361 10 20 30 40
1362 01234567890123456789012345678901234567890123456789
1363 10 20 30 40
1364 01234567890123456789012345678901234567890123456789
1365 10 20 30 40
1366 01234567890123456789012345678901234567890123456789
1367 10 20 30 40
1368 01234567890123456789012345678901234567890123456789
1369 10 20 30 40
1370 01234567890123456789012345678901234567890123456789
1371 10 20 30 40
1372 01234567890123456789012345678901234567890123456789
1373 10 20 30 40
1374 01234567890123456789012345678901234567890123456789
1375 10 20 30 40
1376 01234567890123456789012345678901234567890123456789
1377 10 20 30 40
1378 01234567890123456789012345678901234567890123456789
1379 10 20 30 40
1380 01234567890123456789012345678901234567890123456789
1381 10 20 30 40
1382 01234567890123456789012345678901234567890123456789
1383 10 20 30 40
1384 01234567890123456789012345678901234567890123456789
1385 10 20 30 40
1386 01234567890123456789012345678901234567890123456789
1387 10 20 30 40
1388 01234567890123456789012345678901234567890123456789
1389 10 20 30 40
1390 01234567890123456789012345678901234567890123456789
1391 10 20 30 40
1392 01234567890123456789012345678901234567890123456789
1393 10 20 30 40
1394 01234567890123456789012345678901234567890123456789
1395 10 20 30 40
1396 01234567890123456789012345678901234567890123456789
1397 10 20 30 40
1398 01234567890123456789012345678901234567890123456789
1399 10 20 30 40
1400 01234567890123456789012345678901234567890123456789
1401 10 20 30 40
1402 01234567890123456789012345678901234567890123456789
1403 10 20 30 40
1404 01234567890123456789012345678901234567890123456789
1405 10 20 30 40
1406 01234567890123456789012345678901234567890123456789
1407 10 20 30 40
1408 01234567890123456789012345678901234567890123456789
1409 10 20 30 40
1410 01234567890123456789012345678901234567890123456789
1411 10 20 30 40
1412 01234567890123456789012345678901234567890123456789
1413 10 20 30 40
1414 01234567890123456789012345678901234567890123456789
1415 10 20 30 40
1416 01234567890123456789012345678901234567890123456789
1417 10 20 30 40
1418 01234567890123456789012345678901234567890123456789
1419 10 20 30 40
1420 01234567890123456789012345678901234567890123456789
1421 10 20 30 40
1422 01234567890123456789012345678901234567890123456789
1423 10 20 30 40
1424 01234567890123456789012345678901234567890123456789
1425 10 20 30 40
1426 01234567890123456789012345678901234567890123456789
1427 10 20 30 40
1428 01234567890123456789012345678901234567890123456789
1429 10 20 30 40
1430 01234567890123456789012345678901234567890123456789
1431 10 20 30 40
1432 01234567890123456789012345678901234567890123456789
1433 10 20 30 40
1434 01234567890123456789012345678901234567890123456789
1435 10 20 30 40
1436 01234567890123456789012345678901234567890123456789
1437 10 20 30 40
1438 01234567890123456789012345678901234567890123456789
1439 10 20 30 40
1440 01234567890123456789012345678901234567890123456789
1441 10 20 30 40
1442 01234567890123456789012345678901234567890123456789
1443 10 20 30 40
1444 01234567890123456789012345678901234567890123456789
1445 10 20 30 40
1446 01234567890123456789012345678901234567890123456789
1447 10 20 30 40
1448 01234567890123456789012345678901234567890123456789
1449 10 20 30 40
1450 01234567890123456789012345678901234567890123456789
1451 10 20 30 40
1452 01234567890123456789012345678901234567890123456789
1453 10 20 30 40
1454 01234567890123456789012345678901234567890123456789
1455 10 20 30 40
1456 01234567890123456789012345678901234567890123456789
1457 10 20 30 40
1458 01234567890123456789012345678901234567890123456789
1459 10 20 30 40
1460 01234567890123456789012345678901234567890123456789
1461 10 20 30 40
1462 01234567890123456789012345678901234567890123456789
1463 10 20 30 40
1464 01234567890123456789012345678901234567890123456789
1465 10 20 30 40
1466 01234567890123456789012345678901234567890123456789
1467 10 20 30 40
1468 01234567890123456789012345678901234567890123456789
1469 10 20 30 40
1470 01234567890123456789012345678901234567890123456789
1471 10 20 30 40
1472 01234567890123456789012345678901234567890123456789
1473 10 20 30 40
1474 01234567890123456789012345678901234567890123456789
1475 10 20 30 40
1476 01234567890123456789012345678901234567890123456789
1477 10 20 30 40
1478 01234567890123456789012345678901234567890123456789
1479 10 20 30 40
1480 01234567890123456789012345678901234567890123456789
1481 10 20 30 40
1482 01234567890123456789012345678901234567890123456789
1483 10 20 30 40
1484 01234567890123456789012345678901234567890123456789
1485 10 20 30 40
1486 01234567890123456789012345678901234567890123456789
1487 10 20 30 40
1488 01234567890123456789012345678901234567890123456789
1489 10 20 30 40
1490 01234567890123456789012345678901234567890123456789
1491 10 20 30 40
1492 01234567890123456789012345678901234567890123456789
1493 10 20 30 40
1494 01234567890123456789012345678901234567890123456789
1495 10 20 30 40
1496 01234567890123456789012345678901234567890123456789
1497 10 20 30 40
1498 01234567890123456789012345678901234567890123456789
1499 10 20 30 40
1500 01234567890123456789012345678901234567890123456789
1501 10 20 30 40
1502 01234567890123456789012345678901234567890123456789
1503 10 20 30 40
1504 01234567890123456789012345678901234567890123456789
1505 10 20 30 40
1506 01234567890123456789012345678901234567890123456789
1507 10 20 30 40
1508 01234567890123456789012345678901234567890123456789
1509 10 20 30 40
1510 01234567890123456789012345678901234567890123456789
1511 10 20 30 40
1512 01234567890123456789012345678901234567890123456789
1513 10 20 30 40
1514 01234567890123456789012345678901234567890123456789
1515 10 20 30 40
1516 01234567890123456789012345678901234567890123456789
1517 10 20 30 40
1518 01234567890123456789012345678901234567890123456789
1519 10 20 30 40
1520 01234567890123456789012345678901234567890123456789
1521 10 20 30 40
1522 01234567890123456789012345678901234567890123456789
1523 10 20 30 40
1524 01234567890123456789012345678901234567890123456789
1525 10 20 30 40
1526 01234567890123456789012345678901234567890123456789
1527 10 20 30 40
1528 01234567890123456789012345678901234567890123456789
1529 10 20 30 40
1530 01234567890123456789012345678901234567890123456789
1531 10 20 30 40
1532 01234567890123456789012345678901234567890123456789
1533 10 20 30 40
1534 01234567890123456789012345678901234567890123456789
1535 10 20 30 40
1536 01234567890123456789012345678901234567890123456789
1537 10 20 30 40
1538 01234567890123456789012345678901234567890123456789
1539 10 20 30 40
1540 01234567890123456789012345678901234567890123456789
1541 10 20 30 40
1542 01234567890123456789012345678901234567890123456789
1543 10 20 30 40
1544 01234567890123456789012345678901234567890123456789
1545 10 20 30 40
1546 01234567890123456789012345678901234567890123456789
1547 10 20 30 40
1548 01234567890123456789012345678901234567890123456789
1549 10 20 30 40
1550 01234567890123456789012345678901234567890123456789
1551 10 20 30 40
1552 01234567890123456789012345678901234567890123456789
1553 10 20 30 40
1554 01234567890123456789012345678901234567890123456789
1555 10 20 30 40
1556 01234567890123456789012345678901234567890123456789
1557 10 20 30 40
1558 01234567890123456789012345678901234567890123456789
1559 10 20 30 40
1560 01234567890123456789012345678901234567890123456789
1561 10 20 30 40
1562 01234567890123456789012345678901234567890123456789
1563 10 20 30 40
1564 01234567890123456789012345678901234567890123456789
1565 10 20 30 40
1566 01234567890123456789012345678901234567890123456789
1567 10 20 30 40
1568 01234567890123456789012345678901234567890123456789
1569 10 20 30 40
1570 01234567890123456789012345678901234567890123456789
1571 10 20 30 40
1572 01234567890123456789012345678901234567890123456789
1573 10 20 30 40
1574 01234567890123456789012345678901234567890123456789
1575 10 20 30 40
1576 01234567890123456789012345678901234567890123456789
1577 10 20 30 40
1578 01234567890123456789012345678901234567890123456789
1579 10 20 30 40
1580 01234567890123456789012345678901234567890123456789
1581 10 20 30 40
1582 01234567890123456789012345678901234567890123456789
1583 10 20 30 40
1584 01234567890123456789012345678901234567890123456789
1585 10 20 30 40
1586 01234567890123456789012345678901234567890123456789
1587 10 20 30 40
1588 01234567890123456789012345678901234567890123456789
1589 10 20 30 40
1590 01234567890123456789012345678901234567890123456789
1591 10 20 30 40
1592 01234567890123456789012345678901234567890123456789
1593 10 20 30 40
1594 01234567890123456789012345678901234567890123456789
1595 10 20 30 40
1596 01234567890123456789012345678901234567890123456789
1597 10 20 30 40
1598 01234567890123456789012345678901234567890123456789
1599 10 20 30 40
1600 01234567890123456789012345678901234567890123456789
1601 10 20 30 40
1602 01234567890123456789012345678901234567890123456789
1603 10 20 30 40
1604 01234567890123456789012345678901234567890123456789
1605 10 20 30 40
1606 01234567890123456789012345678901234567890123456789
1607 10 20 30 40
1608 01234567890123456789012345678901234567890123456789
1609 10 20 30 40
1610 01234567890123456789012345678901234567890123456789
1611 10 20 30 40
1612 01234567890123456789012345678901234567890123456789
1613 10 20 30 40
1614 01234567890123456789012345678901234567890123456789
1615 10 20 30 40
1616 01234567890123456789012345678901234567890123456789
1617 10 20 30 40
1618 01234567890123456789012345678901234567890123456789
1619 10 20 30 40
1620 01234567890123456789012345678901234567890123456789
1621 10 20 30 40
1622 01234567890123456789012345678901234567890123456789
1623 10 20 30 40
1624 01234567890123456789012345678901234567890123456789
1625 10 20 30 40
1626 01234567890123456789012345678901234567890123456789
1627 10 20 30 40
1628 01234567890123456789012345678901234567890123456789
1629 10 20 30 40
1630 01234567890123456789012345678901234567890123456789
1631 10 20 30 40
1632 01234567890123456789012345678901234567890123456789
1633 10 20 30 40
1634 01234567890123456789012345678901234567890123456789
1635 10 20 30 40
1636 01234567890123456789012345678901234567890123456789
1637 10 20 30 40
1638 01234567890123456789012345678901234567890123456789
1639 10 20 30 40
1640 01234567890123456789012345678901234567890123456789
1641 10 20 30 40
1642 01234567890123456789012345678901234567890123456789
1643 10 20 30 40
1644 01234567890123456789012345678901234567890123456789
1645 10 20 30 40
1646 01234567890123456789012345678901234567890123456789
1647 10 20 30 40
1648 01234567890123456789012345678901234567890123456789
1649 10 20 30 40
1650 01234567890123456789012345678901234567890123456789
1651 10 20 30 40
1652 01234567890123456789012345678901234567890123456789
1653 10 20 30 40
1654 01234567890123456789012345678901234567890123456789
1655 10 20 30 40
1656 01234567890123456789012345678901234567890123456789
1657 10 20 30 40
1658 01234567890123456789012345678901234567890123456789
1659 10 20 30 40
1660 01234567890123456789012345678901234567890123456789
1661 10 20 30 40
1662 01234567890123456789012345678901234567890123456789
1663 10 20 30 40
1664 01234567890123456789012345678901234567890123456789
1665 10 20 30 40
1666 01234567890123456789012345678901234567890123456789
1667 10 20 30 40
1668 01234567890123456789012345678901234567890123456789
1669 10 20 30 40
1670 01234567890123456789012345678901234567890123456789
1671 10 20 30 40
1672 01234567890123456789012345678901234567890123456789
1673 10 20 30 40
1674 01234567890123456789012345678901234567890123456789
1675 10 20 30 40
1676 01234567890123456789012345678901234567890123456789
1677 10 20 30 40
1678 01234567890123456789012345678901234567890123456789
1679 10 20 30 40
1680 01234567890123456789012345678901234567890123456789
1681 10 20 30 40
1682 01234567890123456789012345678901234567890123456789
1683 10 20 30 40
1684 01234567890123456789012345678901234567890123456789
1685 10 20 30 40
1686 01234567890123456789012345678901234567890123456789
1687 10 20 30 40
1688 01234567890123456789012345678901234567890123456789
1689 10 20 30 40
1690 01234567890123456789012345678901234567890123456789
1691 10 20 30 40
1692 01234567890123456789012345678901234567890123456789
1693 10 20 30 40
1694 01234567890123456789012345678901234567890123456789
1695 10 20 30 40
1696 01234567890123456789012345678901234567890123456789
1697 10 20 30 40
1698 01234567890123456789012345678901234567890123456789
1699 10 20 30 40
1700 01234567890123456789012345678901234567890123456789
1701 10 20 30 40
1702 01234567890123456789012345678901234567890123456789
1703 10 20 30 40
1704 01234567890123456789012345678901234567890123456789
1705 10 20 30 40
1706 01234567890123456789012345678901234567890123456789
1707 10 20 30 40
1708 01234567890123456789012345678901234567890123456789
1709 10 20 30 40
1710 01234567890123456789012345678901234567890123456789
1711 10 20 30 40
1712 01234567890123456789012345678901234567890123456789
1713 10 20 30 40
1714 01234567890123456789012345678901234567890123456789
1715 10 20 30 40
1716 01234567890123456789012345678901234567890123456789
1717 10 20 30 40
1718 01234567890123456789012345678901234567890123456789
1719 10 20 30 40
1720 01234567890123456789012345678901234567890123456789
1721 10 20 30 40
1722 01234567890123456789012345678901234567890123456789
1723 10 20 30 40
1724 01234567890123456789012345678901234567890123456789
1725 10 20 30 40
1726 01234567890123456789012345678901234567890123456789
1727 10 20 30 40
1728 01234567890123456789012345678901234567890123456789
1729 10 20 30 40
1730 01234567890123456789012345678901234567890123456789
1731 10 20 30 40
1732 01234567890123456789012345678901234567890123456789
1733 10 20 30 40
1734 01234567890123456789012345678901234567890123456789
1735 10 20 30 40
1736 01234567890123456789012345678901234567890123456789
1737 10 20 30 40
1738 01234567890123456789012345678901234567890123456789
1739 10 20 30 40
1740 01234567890123456789012345678901234567890123456789
1741 10 20 30 40
1742 01234567890123456789012345678901234567890123456789
1743 10 20 30 40
1744 01234567890123456789012345678901234567890123456789
1745 10 20 30 40
1746 01234567890123456789012345678901234567890123456789
1747 10 20 30 40
1748 01234567890123456789012345678901234567890123456789
1749 10 20 30 40
1750 01234567890123456789012345678901234567890123456789
1751 10 20 30 40
1752 01234567890123456789012345678901234567890123456789
1753 10 20 30 40
1754 01234567890123456789012345678901234567890123456789
1755 10 20 30 40
1756 01234567890123456789012345678901234567890123456789
1757 10 20 30 40
1758 01234567890123456789012345678901234567890123456789
1759 10 20 30 40
1760 01234567890123456789012345678901234567890123456789
1761 10 20 30 40
1762 01234567890123456789012345678901234567890123456789
1763 10 20 30 40
1764 01234567890123456789012345678901234567890123456789
1765 10 20 30 40
1766 01234567890123456789012345678901234567890123456789
1767 10 20 30 40
1768 01234567890123456789012345678901234567890123456789
1769 10 20 30 40
1770 01234567890123456789012345678901234567890123456789
1771 10 20 30 40
1772 01234567890123456789012345678901234567890123456789
1773 10 20 30 40
1774 01234567890123456789012345678901234567890123456789
1775 10 20 30 40
1776 01234567890123456789012345678901234567890123456789
1777 10 20 30 40
1778 01234567890123456789012345678901234567890123456789
1779 10 20 30 40
1780 01234567890123456789012345678901234567890123456789
1781 10 20 30 40
1782 01234567890123456789012345678901234567890123456789
1783 10 20 30 40
1784 01234567890123456789012345678901234567890123456789
1785 10 20 30 40
1786 01234567890123456789012345678901234567890123456789
1787 10 20 30 40
1788 01234567890123456789012345678901234567890123456789
1789 10 20 30 40
1790 01234567890123456789012345678901234567890123456789
1791 10 20 30 40
1792 01234567890123456789012345678901234567890123456789
1793 10 20 30 40
1794 01234567890123456789012345678901234567890123456789
1795 10 20 30 40
1796 01234567890123456789012345678901234567890123456789
1797 10 20 30 40
1798 01234567890123456789012345678901234567890123456789
1799 10 20 30 40
1800 01234567890123456789012345678901234567890123456789
1801 10 20 30 40
1802 01234567890123456789012345678901234567890123456789
1803 10 20 30 40
1804 01234567890123456789012345678901234567890123456789
1805 10 20 30 40
1806 01234567890123456789012345678901234567890123456789
1807 10 20 30 40
1808 01234567890123456789012345678901234567890123456789
1809 10 20 30 40
1810 01234567890123456789012345678901234567890123456789
1811 10 20 30 40
1812 01234567890123456789012345678901234567890123456789
1813 10 20 30 40
1814 01234567890123456789012345678901234567890123456789
1815 10 20 30 40
1816 01234567890123456789012345678901234567890123456789
1817 10 20 30 40
1818 01234567890123456789012345678901234567890123456789
1819 10 20 30 40
1820 01234567890123456789012345678901234567890123456789
1821 10 20 30 40
1822 01234567890123456789012345678901234567890123456789
1823 10 20 30 40
1824 01234567890123456789012345678901234567890123456789
1825 10 20 30 40
1826 01234567890123456789012345678901234567890123456789
1827 10 20 30 40
1828 01234567890123456789012345678901234567890123456789
1829 10 20 30 40
1830 01234567890123456789012345678901234567890123456789
1831 10 20 30 40
1832 01234567890123456789012345678901234567890123456789
1833 10 20 30 40
1834 01234567890123456789012345678901234567890123456789
1835 10 20 30 40
1836 01234567890123456789012345678901234567890123456789
1837 10 20 30 40
1838 01234567890123456789012345678901234567890123456789
1839 10 20 30 40
1840 01234567890123456789012345678901234567890123456789
1841 10 20 30 40
1842 01234567890123456789012345678901234567890123456789
1843 10 20 30 40
1844 01234567890123456789012345678901234567890123456789
1845 10 20 30 40
1846 01234567890123456789012345678901234567890123456789
1847 10 20 30 40
1848 01234567890123456789012345678901234567890123456789
1849 10 20 30 40
1850 01234567890123456789012345678901234567890123456789
1851 10 20 30 40
1852 01234567890123456789012345678901234567890123456789
1853 10 20 30 40
1854 01234567890123456789012345678901234567890123456789
1855 10 20 30 40
1856 01234567890123456789012345678901234567890123456789
1857 10 20 30 40
1858 01234567890123456789012345678901234567890123456789
1859 10 20 30 40
1860 01234567890123456789012345678901234567890123456789
1861 10 20 30 40
1862 01234567890123456789012345678901234567890123456789
1863 10 20 30 40
1864 01234567890123456789012345678901234567890123456789
1865 10 20 30 40
1866 01234567890123456789012345678901234567890123456789
1867 10 20 30 40
1868 01234567890123456789012345678901234567890123456789
1869 10 20 30 40
1870 01234567890123456789012345678901234567890123456789
1871 10 20 30 40
1872 01234567890123456789012345678901234567890123456789
1873 10 20 30 40
1874 01234567890123456789012345678901234567890123456789
1875 10 20 30 40
1876 01234567890123456789012345678901234567890123456789
1877 10 20 30 40
1878 01234567890123456789012345678901234567890123456789
1879 10 20 30 40
1880 01234567890123456789012345678901234567890123456789
1881 10 20 30 40
1882 01234567890123456789012345678901234567890123456789
1883 10 20 30 40
1884 01234567890123456789012345678901234567890123456789
1885 10 20 30 40
1886 01234567890123456789012345678901234567890123456789
1887 10 20 30 40
1888 01234567890123456789012345678901234567890123456789
1889 10 20 30 40
1890 01234567890123456789012345678901234567890123456789
1891 10 20 30 40
1892 01234567890123456789012345678901234567890123456789
1893 10 20 30 40
1894 01234567890123456789012345678901234567890123456789
1895 10 20 30 40
1896 01234567890123456789012345678901234567890123456789
1897 10 20 30 40
1898 01234567890123456789012345678901234567890123456789
1899 10 20 30 40
1900 01234567890123456789012345678901234567890123456789
1901 10 20 30 40
1902 01234567890123456789012345678901234567890123456789
1903 10 20 30 40
1904 01234567890123456789012345678901234567890123456789
1905 10 20 30 40
1906 01234567890123456789012345678901234567890123456789
1907 10 20 30 40
1908 01234567890123456789012345678901234567890123456789
1909 10 20 30 40
1910 01234567890123456789012345678901234567890123456789
1911 10 20 30 40
1912 01234567890123456789012345678901234567890123456789
1913 10 20 30 40
1914 01234567890123456789012345678901234567890123456789
1915 10 20 30 40
1916 01234567890123456789012345678901234567890123456789
1917 10 20 30 40
1918 01234567890123456789012345678901234567890123456789
1919 10 20 30 40
1920 01234567890123456789012345678901234567890123456789
1921 10 20 30 40
1922 01234567890123456789012345678901234567890123456789
1923 10 20 30 40
1924 01234567890123456789012345678901234567890123456789
1925 10 20 30 40
1926 01234567890123456789012345678901234567890123456789
1927 10 20 30 40
1928 01234567890123456789012345678901234567890123456789
1929 10 20 30 40
1930 01234567890123456789012345678901234567890123456789
1931 10 20 30 40
1932 01234567890123456789012345678901234567890123456789
1933 10 20 30 40
1934 01234567890123456789012345678901234567890123456789
1935 10 20 30 40
1936 01234567890123456789012345678901234567890123456789
1937 10 20 30 40
1938 01234567890123456789012345678901234567890123456789
1939 10 20 30 40
1940 01234567890123456789012345678901234567890123456789
1941 10 20 30 40
1942 01234567890123456789012345678901234567890123456789
1943 10 20 30 40
1944 01234567890123456789012345678901234567890123456789
1945 10 20 30 40
1946 01234567890123456789012345678901234567890123456789
1947 10 20 30 40
1948 01234567890123456789012345678901234567890123456789
1949 10 20 30 40
1950 01234567890123456789012345678901234567890123456789
1951 10 20 30 40
1952 01234567890123456789012345678901234567890123456789
1953 10 20 30 40
1954 01234567890123456789012345678901234567890123456789
1955 10 20 30 40
1956 01234567890123456789012345678901234567890123456789
1957 10 20 30 40
1958 01234567890123456789012345678901234567890123456789
1959 10 20 30 40
1960 01234567890123456789012345678901234567890123456789
1961 10 20 30 40
1962 01234567890123456789012345678901234567890123456789
1963 10 20 30 40
1964 01234567890123456789012345678901234567890123456789
1965 10 20 30 40
1966 01234567890123456789012345678901234567890123456789
1967 10 20 30 40
1968 01234567890123456789012345678901234567890123456789
1969 10 20 30 40
1970 01234567890123456789012345678901234567890123456789
1971 10 20 30 40
1972 01234567890123456789012345678901234567890123456789
1973 10 20 30 40
1974 01234567890123456789012345678901234567890123456789
1975 10 20 30 40
1976 01234567890123456789012345678901234567890123456789
1977 10 20 30 40
1978 01234567890123456789012345678901234567890123456789
1979 10 20 30 40
1980 01234567890123456789012345678901234567890123456789
1981 10 20 30 40
1982 01234567890123456789012345678901234567890123456789
1983 10 20 30 40
1984 01234567890123456789012345678901234567890123456789
1985 10 20 30 40
1986 01234567890123456789012345678901234567890123456789
1987 10 20 30 40
1988 01234567890123456789012345678901234567890123456789
1989 10 20 30 40
1990 01234567890123456789012345678901234567890123456789
1991 10 20 30 40
1992 01234567890123456789012345678901234567890123456789
1993 10 20 30 40
1994 01234567890123456789012345678901234567890123456789
1995 10 20 30 40
1996 01234567890123456789012345678901234567890123456789
1997 10 20 30 40
1998 01234567890123456789012345678901234567890123456789
1999 10 20 30 40
2000 01234567890123456789012345678901234567890123456789
2001 10 20 30 40
2002 01234567890123456789012345678901234567890123456789
2003 10 20 30 40
2004 01234567890123456789012345678901234567890123456789
2005 10 20 30 40
2006 01234567890123456789012345678901234567890123456789
2007 10 20 30 40
2008 01234567890123456789012345678901234567890123456789
2009 10 20 30 40
2010 01234567890123456789012345678901234567890123456789
2011 10 20 30 40
2012 01234567890123456789012345678901234567890123456789
2013 10 20 30 40
2014 01234567890123456789012345678901234567890123456789
2015 10 20 30 40
2016 01234567890123456789012345678901234567890123456789
2017 10 20 30 40
2018 01234567890123456789012345678901234567890123456789
2019 10 20 30 40
2020 01234567890123456789012345678901234567890123456789
2021 10 20 30 40
2022 01234567890123456789012345678901234567890123456789
2023 10 20 30 40
2024 01234567890123456789012345678901234567890123456789
2025 10 20 30 40
2026 01234567890123456789012345678901234567890123456789
2027 10 20 30 40
2028 01234567890123456789012345678901234567890123456789
2029 10 20 30 40
2030 01234567890123456789012345678901234567890123456789
2031 10 20 30 40
2032 01234567890123456789012345678901234567890123456789
2033 10 20 30 40
2034 01234567890123456789012345678901234567890123456789
2035 10 20 30 40
2036 01234567890123456789012345678901234567890123456789
2037 10 20 30 40
2038 01234567890123456789012345678901234567890123456789
2039 10 20 30 40
2040 01234567890123456789012345678901234567890123456789
2041 10 20 30 40
2042 01234567890123456789012345678901234567890123456789
2043 10 20 30 40
2044 01234567890123456789012345678901234567890123456789
2045 10 20 30 40
2046 01234567890123456789012345678901234567890123456789
2047 10 20 30 40
2048 01234567890123456789012345678901234567890123456789
2049 10 20 30 40
2050 01234567890123456789012345678901234567890123456789
2051 10 20 30 40
2052 01234567890123456789012345678901234567890123456789
2053 10 20 30 40
2054 01234567890123456789012345678901234567890123456789
2055 10 20 30 40
2056 01234567890123456789012345678901234567890123456789
2057 10 20 30 40
2058 01234567890123456789012345678901234567890123456789
2059 10 20 30 40
2060 01234567890123456789012345678901234567890123456789
2061 10 20 30 40
2062 01234567890123456789012345678901234567890123456789
2063 10 20 30 40
2064 01234567890123456789012345678901234567890123456789
2065 10 20 30 40
2066 01234567890123456789012345678901234567890123456789
2067 10 20 30 40
2068 01234567890123456789012345678901234567890123456789
2069 10 20 30 40
2070 01234567890123456789012345678901234567890123456789
2071 10 20 30 40
2072 01234567890123456789012345678901234567890123456789
2073 10 20 30 40
2074 01234567890123456789012345678901234567890123456789
2075 10 20 30 40
2076 01234567890123456789012345678901234567890123456789
2077 10 20 30 40
2078 01234567890123456789012345678901234567890123456789
2079 10 20 30 40
2080 01234567890123456789012345678901234567890123456789
2081 10 20 30 40
2082 01234567890123456789012345678901234567890123456789
2083 10 20 30 40
2084 01234567890123456789012345678901234567890123456789
2085 10 20 30 40
2086 01234567890123456789012345678901234567890123456789
2087 10 20 30 40
2088 01234567890123456789012345678901234567890123456789
2089 10 20 30 40
2090 01234567890123456789012345678901234567890123456789
2091 10 20 30 40
2092 01234567890123456789012345678901234567890123456789
2093 10 20 30 40
2094 01234567890123456789012345678901234567890123456789
2095 10 20 30 40
2096 01234567890123456789012345678901234567890123456789
2097 10 20 30 40
2098 01234567890123456789012345678901234567890123456789
2099 10 20 30 40
2100 01234567890123456789012345678901234567890123456789
2101 10 20 30 40
2102 01234567890123456789012345678901234567890123456789
2103 10 20 30 40
2104 01234567890123456789012345678901234567890123456789
2105 10 20 30 40
2106 01234567890123456789012345678901234567890123456789
2107 10 20 30 40
2108 01234567890123456789012345678901234567890123456789
2109 10 20 30 40
2110 01234567890123456789012345678901234567890123456789
2111 10 20 30 40
2112 01234567890123456789012345678901234567890123456789
2113 10 20 30 40
2114 01234567890123456789012345678901234567890123456789
2115 10 20 30 40
2116 01234567890123456789012345678901234567890123456789
2117 10 20 30 40
2118 01234567890123456789012345678901234567890123456789
2119 10 20 30 40
2120 01234567890123456789012345678901234567890123456789
2121 10 20 30 40
2122 01234567890123456789012345678901234567890123456789
2123 10 20 30 40
2124 01234567890123456789012345678901234567890123456789
2125 10 20 30 40
2126 01234567890123456789012345678901234567890123456789
2127 10 20 30 40
2128 01234567890123456789012345678901234567890123456789
2129 10 20 30 40
2130 01234567890123456789012345678901234567890123456789
2131 10 20 30 40
2132 01234567890123456789012345678901234567890123456789
2133 10 20 30 40
2134 01234567890123456789012345678901234567890123456789
2135 10 20 30 40
2136 01234567890123456789012345678901234567890123456789
2137 10 20 30 40
2138 01234567890123456789012345678901234567890123456789
2139 10 20 30 40
2140 01234567890123456789012345678901234567890123456789
2141 10 20 30 40
2142 01234567890123456789012345678901234567890123456789
2143 10 20 30 40
2144 01234567890123456789012345678901234567890123456789
2145 10 20 30 40
2146 01234567890123456789012345678901234567890123456789
2147 10 20 30 40
2148 01234567890123456789012345678901234567890123456789
2149 10 20 30 40
2150 01234567890123456789012345678901234567890123456789
2151 10 20 30 40
2152 01234567890123456789012345678901234567890123456789
2153 10 20 30 40
2154 01234567890123456789012345678901234567890123456789
2155 10 20 30 40
2156 01234567890123456789012345678901234567890123456789
2157 10 20 30 40
2158 01234567890123456789012345678901234567890123456789
2159 10 20 30 40
2160 01234567890123456789012345678901234567890123456789
2161 10 20 30 40
2162 01234567890123456789012345678901234567890123456789
2163 10 20 30 40
2164 01234567890123456789012345678901234567890123456789
2165 10 20 30 40
2166 01234567890123456789012345678901234567890123456789
2167 10 20 30 40
2168 01234567890123456789012345678901234567890123456789
2169 10 20 30 40
2170 01234567890123456789012345678901234567890123456789
2171 10 20 30 40
2172 01234567890123456789012345678901234567890123456789
2173 10 20 30 40
2174 01234567890123456789012345678901234567890123456789
2175 10 20 30 40
2176 01234567890123456789012345678901234567890123456789
2177 10 20 30 40
2178 01234567890123456789012345678901234567890123456789
2179 10 20 30 40
2180 01234567890123456789012345678901234567890123456789
2181 10 20 30 40
2182 01234567890123456789012345678901234567890123456789
2183 10 20 30 40
2184 01234567890123456789012345678901234567890123456789
2185 10 20 30 40
2186 01234567890123456789012345678901234567890123456789
2187 10 20 30 40
2188 01234567890123456789012345678901234567890123456789
2189 10 20 30 40
2190 01234567890123456789012345678901234567890123456789
2191 10 20 30 40
2192 01234567890123456789012345678901234567890123456789
2193 10 20 30 40
2194 01234567890123456789012345678901234567890123456789
2195 10 20 30 40
2196 01234567890123456789012345678901234567890123456789
2197 10 20 30 40
2198 01234567890123456789012345678901234567890123456789
2199 10 20 30 40
2200 01234567890123456789012345678901234567890123456789
2201 10 20 30 40
2202 01234567890123456789012345678901234567890123456789
2203 10 20 30 40
2204 01234567890123456789012345678901234567890123456789
2205 10 20 30 40
2206 01234567890123456789012345678901234567890123456789
2207 10 20 30 40
2208 01234567890123456789012345678901234567890123456789
2209 10 20 30 40
2210 01234567890123456789012345678901234567890123456789
2211 10 20 30 40
2212 01234567890123456789012345678901234567890123456789
2213 10 20 30 40
2214 01234567890123456789012345678901234567890123456789
2215 10 20 30 40
2216 01234567890123456789012345678901234567890123456789
2217 10 20 30 40
2218 01234567890123456789012345678901234567890123456789
2219 10 20 30 40
2220 01234567890123456789012345678901234567890123456789
2221 10 20 30 40
2222 01234567890123456789012345678901234567890123456789
2223 10 20 30 40
2224 01234567890123456789012345678901234567890123456789
2225 10 20 30 40
2226 01234567890123456789012345678901234567890123456789
2227 10 20 30 40
2228 01234567890123456789012345678901234567890123456789
2229 10 20 30 40
2230 01234567890123456789012345678901234567890123456789
2231 10 20 30 40
2232 01234567890123456789012345678901234567890123456789
2233 10 20 30 40
2234 01234567890123456789012345678901234567890123456789
2235 10 20 30 40
2236 01234567890123456789012345678901234567890123456789
2237 10 20 30 40
2238 01234567890123456789012345678901234567890123456789
2239 10 20 30 40
2240 01234567890123456789012345678901234567890123456789
2241 10 20 30 40
2242 01234567890123456789012345678901234567890123456789
2243 10 20 30 40
2244 01234567890123456789012345678901234567890123456789
2245 10 20 30 40
2246 01234567890123456789012345678901234567890123456789
2247 10 20 30 40
2248 01234567890123456789012345678901234567890123456789
2249 10 20 30 40
2250 01234567890123456789012345678901234567890123456789
120.000 characters per post 117 kB
The enum is indeed a better solution!
system
Closed
October 17, 2023, 8:21pm
15
