Switch case question
Why does the case in the below example keep giving offset = 0 ?
Regardless of the contents of #define IDENTIFIER 'C', if 'C' then ofset should be 10, yet a serial print shows 0.
#include <Wire.h>
#include <Arduino.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP280.h>
#include "Adafruit_HTU21DF.h"
#include <ESP8266WiFi.h>
#define DS3231_I2C_ADDRESS 0x68
#define humidityLed 2  //built-in LED GPIO2: new message received
unsigned int disconnects, offset;
  delay(250);
  Serial.println(__FILE__);
  Wire.begin(4, 5);         // I2C 4 = SDA, 5 = SCL
  switch (IDENTIFIER) {
    case 'A':
      offset = 0;
    case 'B':
      offset = 5;
    case 'c':
      offset = 10;
    case 'D':
      offset = 15;
    case 'E': // reserve
      offset = 0;
  Serial.print(F("offset = "));
  Serial.println(offset);
My apologies!! I should have written capital 'C' inside the switch case code.
No
The option 10 is result for switch value 'c', that is not the same as 'C'.
If the offsets are spaced out evenly
offset = 5 * (IDENTIFIER - 'A');
with perhaps an additional check whether the result is out of bounds.
