my code is
float value=0;
float rev=0;
int rpm;
int oldtime=0;
int time;
#include<SD.h>
void isr() //interrupt service routine
rev++; //Each rotation, this interrupt function is run twice, so
//take this into consideration
//when calculating ROC Disk Speed
//update count
SD.begin(); //initialise the SD
Serial.begin(9600); //initialise the serial communication
attachInterrupt(0,isr,FALLING); //attaching the interrupt
//Interrupt 0 is digital pin 2, so that is where the IR detector is connected
//Triggers on FALLING (change from HIGH to LOW)
delay (1000); //Do not process interruptions during calculations
detachInterrupt(0); //detaches the interrupt
millis();
time=millis()-oldtime; //finds the time
rpm=(rev/time)*60000; //calculates rpm
oldtime=millis(); //saves the current time
rev=0; //reset the revolutions counted
Serial.print("ROC BD " );
Serial.print(rpm);
Serial.println(" RPM");
attachInterrupt(0,isr,FALLING); //restart the interrupt processing
The circuit diagram is attached. Two variations from the attached circuit are:
(a) Instead of using the OLED screen, I am trying to log the data in the SD card.
(b) I have no switch on my circuit.
I am only getting values around 3000rpm even for a speed that should be for less than 100rpm.
Please advice, I am a novice in this area. I need the tachometer for my postgraduate project.
Thanks.
circuit diagram for making measuring RPM with IR LED and IR receiver.pdf (82.6 KB)
