Using Labview to connect to Arduino
Hi, Im new to Arduino and i have a school assignment.
To construct Block Diagram using labview software to link to arduino uno, thermistor control system.
I would like to know , how it can connect to Arduino.
Any expert can advise.
Thanks
The Labview documentation describes these operations in detail. Study it carefully.
I would suggest you look into serial connections between the two. Remember Labview is not hardware it is software so whatever method you chose to make the connection there has to be hardware on the Labview machine side to support it.
@Azahar Surely your lecturer / tutor or whatever will have given you some info on how to get started. Or did they just throw you under the bus and tell you hit up the Arduino forum to do their work for them?
