Using MFRC522 RFID Reader With ATTINY84
I am having trouble using the MFRC522 RFID reader with the attiny84. I am trying to make a keycard security for a truck anti-theft system. I can make an atmega8 microcontroller work very well very easily, however I do not want to "waste" one if I don't need to. I am a complete noob, so this may be super easy for you guys to figure out. So far I have MOSI to pin6, MISO to pin5, SCK to pin4, SDA to pin10, RESET to pin8, GND to GND, 3.3v to 3.3v. I have absolutely no resistors, capacitors or anything(and this may be the problem). I am using ATTinyCore and the code seems to upload to the attiny84 chip without problems. I know the RFID reader works and the ID number for the card is correct. Here is the code:
#include <SPI.h>
#include <RFID.h>
#define SS_PIN 10
#define RST_PIN 8
RFID rfid(SS_PIN, RST_PIN);
String rfidCard;
int i;
int relay = 3;
int led = 9;
  SPI.begin();
  rfid.init();
  pinMode(relay, OUTPUT);
  digitalWrite(relay, LOW);
 pinMode(led, OUTPUT);
 digitalWrite(led, HIGH);
  if (rfid.isCard()) {
    if (rfid.readCardSerial()) {
      rfidCard = String(rfid.serNum[0]) + " " + String(rfid.serNum[1]) + " " + String(rfid.serNum[2]) + " " + String(rfid.serNum[3]);
if (rfidCard=="211 160 177 30"){
  digitalWrite(relay, HIGH);
}else if(rfidCard=="243 207 206 46"){
}else if(rfidCard=="17 145 161 38"){
}else{
rfid.halt();
This exact code works perfectly fine with the atmega8 chip.
Here are the settings I have selected:
Any help is appreciated. Thanks
Look for this:
I have already read that and am using the attinycore. Unless I am thinking wrong, all I need to do is copy the attinycore url, put it in the preferences url section, and use it in the toolbar right?
Yes, just make sure to use latest stable version V1.0.4.
Did you some test with ATTiny Core and a SPI device?
The only SPI device I have is the RFID card reader. I don't have another SPI device to test with.
