RC522 RFID Module not connecting
I am trying to connect my Arduino Uno R4 Wifi to a RFID-RC522 reader. I have checked that my sketch is being uploaded correctly and that the wiring is secure.
Here is an image of my setup:
Here is my code:
#include <SPI.h>
#include <MFRC522.h>
// RC522 pins
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance
  Serial.begin(9600);  // Start serial monitor
  SPI.begin();         // Start SPI bus
  mfrc522.PCD_Init();  // Initialize RC522
  Serial.println("RFID Reader Ready. Scan a card...");
  // Look for new cards
  if (!mfrc522.PICC_IsNewCardPresent()) return;
  if (!mfrc522.PICC_ReadCardSerial()) return;
  // Print card UID
  Serial.print("Card UID: ");
  for (byte i = 0; i < mfrc522.uid.size; i++) {
    Serial.print(mfrc522.uid.uidByte[i], HEX);
    Serial.print(" ");
  // Halt PICC
  mfrc522.PICC_HaltA();
When I run this, the RFID reader doesn't connect to the Arduino and can't read the card I have. I am very new to Arduino. Does anyone know what I am doing wrong or how to fix it? Thank you!
At a glance of your hardware, I can't say I'm confident those jumper wires are making a solid connection between the reader and the breadboard. Any way you can solder up the rfid reader?
Nice work with the (somewhat) clear photo and properly posted code though!
EDIT: The Uno R4 is a 5V board, btw. The reader is a 3.3V device. You should really use a level shifter and ensure that you are powering the RFID reader with the 3.3V it is designed for.
Most of the internet gets this wrong. Here is how to wire up a 3V3 reader to a 5V system.
Also I can't see any soldering onto your RFID reader, it will not work without soldering.
Thank you so much! It worked perfectly.
Great news. Now to finish off the post, click on the post that most helped you as the solution, it will help other in future know there is a proper answer.
