Using micro USB-B connector to detect phone connection
I am working on a project where the arduino needs to detect if the smartphone is plugged in the micro usb-b.
I noticed that the micro usb has 5 pins, and I am wondering if I could use the sensor/ID pin to send an electric signal to the arduino using a series of NPN transistor. is that possible?
if not, any recommendations?
Thanks,
C
Pinout here
Weedpharma
Sensor/I/O pin ? What is that, Newbie for " analog input " ?
Need to know which arduino.
"Sensor/ID pin" is referring to the 4th pin in the USB.
Weedpharma
The full spec here
excerpt (also I'm not quite sure what miniA and miniB refer to after a very quick glance):
The ID pin on a Mini-A plug shall be connected to the GND pin. The ID pin on a Mini-B plug is not connected or is connected to ground by a resistance of greater than RB_PLUG_ID. A dual-role device is required to be able to detect whether a Mini-A or Mini-B plug is inserted by determining if the ID pin resistance to ground is less than RA_PLUG_ID or if the resistance to ground is greater than RB_PLUG_ID.
Any ID resistance less than RA_PLUG_ID shall be treated as ID = FALSE and any resistance greater than RB_PLUG_ID shall be treated as ID = TRUE.
Sounds like shorting the pin in the cable should work.
my apologies and thanks for replying.
yes the sensor/ID pin in the micro USB-b.
I am using an arduino nano.
so the plan is to make the nano receive an electric signal(like a buttonPin) from the micro usb to tell the nano that the phone is plugged.
I am currently using the DATA + pin of the micro usb but the electric current fluctuates a lot if I use the DATA +. So, I was hoping if I could use the Sensor/ID pin in the micro usb.
