Dear All,
I have a project where I need to make a serial (RS-232) communication between an M2M unit (it is a GPS tracker working with 12V) and Arduino.
From Arduino side only TX needed, but on RS-232 voltage level.
During the researching I have found out that, that I need a level shifter and GND most be common for both units.
I am trying to handle with this type of level shifter (also the connecting shame is the same):
https://www.google.hu/imgres?imgurl=https%3A%2F%2Fi.stack.imgur.com%2FZuoSe.png&imgrefurl=http%3A%2F%2Felectronics.stackexchange.com%2Fquestions%2F134724%2Farduino-rs232-level-shifter-or-rs2323-breakout-needed&docid=9CAo75Z6W6QQEM&tbnid=ly---h-VPlgJGM%3A&vet=1&w=1218&h=1242&bih=747&biw=1440&q=rs232%20%2B%20arduino&ved=0ahUKEwjgvK6kn_vRAhXEthQKHUOkB-IQMwhLKCcwJw&iact=mrc&uact=8#h=1242&imgrc=ly---h-VPlgJGM:&vet=1&w=1218
But no success
Other params:
8N1, 19200
#include <SoftwareSerial.h>
byte m2mdat[] = {0xAA, 0xBB, 0x06, 0x00, 0x00, 0x00, 0x07, 0x01, 0x05};
// initialize serial:
Serial.begin(19200);
// serial write
Serial.write(m2mdat,9);
Perhaps the level shifter couldn't work with only TX connection?
Or do you have any idea?
Thank you for your help!
Best regards,
V.
system
February 6, 2017, 1:08pm
2
Nonsense. The level shifter doesn't care that you are not receiving anything. Although, connecting a GPS in transmit only mode (transmit from the Arduino to the GPS) doesn't make sense.
PaulS:
And the level shifter only needs to have power to the device. The transmit line will then have the proper voltage. Something equal or greater than +3 volts. My tests have +8.1 volts using a 5 volt supply. The TTL side does not even have to be connected.
Paul
Hello,
Yes, now I also tested the level shifter. It's working fine, so I have checked the output voltage..
"Something equal or greater than +3 volts."
Unfortunately I can get from Tx only 1,6V. Also I have tried to make myserial with different pins:
SoftwareSerial mySerial(10,11);
And I can see only 1,6V on Tx (pin11) again..
What am I doing wrong? Or is there a problem in this code:
SoftwareSerial mySerial(10, 11);
mySerial.begin(19200);
// serial write
mySerial.write(m2mdat,9);
Thx!
system
February 7, 2017, 11:23am
5
The problem is not in the code.
Hello,
Finally I have solved the problem. A delay needed after the serial.write.
So the code is working this way:
// serial write
delay(100);
Anyway, thanks for the help!
