So i have a preject were i have to control RGB leds, and I have to use 12 ports to control each color (4 different LED) can i use any of the arduino uno ports to do so? I ask this because I know not all ports have PWM, in case i can't wich alternative do you guys recommend?
Common 4-pin RGB LEDs need three PWM pins per LED if you want to control brightness of each colour.
A string of addressable RGB LEDs only needs one Arduino pin.
Addressable LEDs come in all shapes and sizes, even in common 5mm.
Leo..
I want to control a 4x1 RGB LED matrix, this means i have 12 different LED to control, the problem is I want to control each color brightness so i can make any color I like, researching i bit i found multiplexing with MOSFET's but I can't figure out how to write the code, the thing I'm looking for is a simple code where i can just change the brightness value to change colors, heres the schematic
Wawa:
Leo..
There are no 5mm ones in my country, sadly
I think coding for that with software PWM is going to be quite a challenge.
Given that some additional components - in this case the FETs - will be required, I would suggest you "do it properly" and either just use four "Neopixels" - undoubtedly the simplest approach and plenty of code to hand - or use a device purpose- designed for the job such as a PCA9685 module.
Also you show an ATmega328 on its own. Much easier and generally cheaper, to use a cheap Chinese Pro Mini clone. In any case you will need some sort of programming adapter.
I was reading about the module online and it definetly seems way easier, I'll update any progress, for now thanks a lot
Eriol123:
And no postal service either?
Do not cross post please.
Topics merged.
Paul__B:
I think coding for that with software PWM is going to be quite a challenge.Given that some additional components - in this case the FETs - will be required, I would suggest you "do it properly" and either just use four "Neopixels" - undoubtedly the simplest approach and plenty of code to hand - or use a device purpose- designed for the job such as a PCA9685 module.
Hi it's me again, so, I'm already working a bit with that idea right now, so i found a library called fast LED, is it possible to use it with the PCA9685 module?
No.
It is for addressable LED strips or LEDs that contain controller chips.
