Using Proto Shield for Breakout Boards
This is my first post and my first venture into Arduino.
I've bought a Proto Shield, Uno 3 and various sensors on Breakout Boards. I need to place sensors in various rooms around the house and have them (wired) connected back to the Uno 3 where the software will run.
I bought the leads for the breakout board which I will cut and solder an extension cable to which will run round the house to the main board where I (thought - and was told) could solder to the Proto Shield??
I cannot find any diagrams to show me the connections needed and even if this is possible - is it?
I was hoping to use the Proto Shield as a "main board" to connect all the sensors to. Am I barking up the wrong tree here?
Thank you - in advance - for your help here! :slight_smile:
Hi, welcome to the forum.
What you are discussing sounds valid to me.
What are the sensors you are using?
Hi there and thank you!
I'm using a temperature sensor (http://www.maplin.co.uk/p/linker-temperature-sensor-n11dh) with Linker Cables (http://www.maplin.co.uk/p/linker-cable-50cm-5-pack-a69ng) which I want to cut into and extend. So the Linker Module will have the correct plug and the Mainboard will have 4 cables to which I want to solder onto the Proto Shield as a "permanent" connection.
If I know how to add one safely, I can figure out how to add more.
I'm also testing a MQ2 Gas Sensor Shield (http://www.maplin.co.uk/p/mq2-smoke-detector-shield-for-arduino-n98dg) which I want to break away and treat this a a separate sensor, wired up in a different room but again, connected to the main board.
Apologies, I hope this is making sense??
Thanks again!!
For the first sensor, need to connect to +5, Gnd, and A0 (or one of the other analog inputs).
The 2nd one needs +5, Gnd, an Analog input, a PWM output, and a digital output for its LED.
So you will need to wire up a little bus circuit to get all the +5s and Gnds connected, and then connect to the other pins as needed, making sure to not use the same analog pin, or PWM pin, or digital pin, for 2 different sensors.
You have a protoshield like this, or something similar?
Where the female headers are brought over to a hole in the prototype area where you can solder to, or out to a screw terminal where you just screw a wire in place.
http://wwww.crossroadsfencing.com/BobuinoRev17
The shield I bought is this one:
http://www.maplin.co.uk/p/arduino-proto-shield-r3-n35ku
It's the original Arduino Shield and being new (last experience was 20 years ago!) to electronics I am trying to learn fast. I cannot see any obvious "tracks" on the board so I'm assuming I use patch cables to connect the outputs?
Yes, looks like you need to wire from the hole next to the header to wherever you are connecting to.
Fantastic!
Thank you very must for your help - very much appreciated.
I'll have a look at this tonight. :smiley:
