I am working on a recording barometer (and some other data). There will be a remote data collector and a display controller. Communication between the two is by RF24s.
The logic is this. The display controller sends a wake up signal to the data collector who replies with the current readings. To save power the display controller uses LowPower and SLEEP_FOREVER. The RF24 uses its interrupt to wake up the data collector, who then replies with the data.
This works with a weird anomaly: the reply is always 1 step behind the wake up.
The display sends: "wakeup n".
The collector replies with: "temp,dewpoint,barometer,solarpower,batterystate,wakeup n"
The display says that it received: "temp,dewpoint,barometer,solarpower,batterystate,wakeup n-1"
below is the code I am using.
Can anyone see what I am doing wrong?
```cpp
#include <Wire.h>
#include "LowPower.h"
#include <Adafruit_INA219.h>
#include <math.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
LiquidCrystal_I2C lcd(0x27,20,4);
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(9, 10); // CE, CSN
Adafruit_INA219 ina219(0x040);
Adafruit_BME280 bme;
const byte address[][6] = {"00001", "00002"};
int count = 0;
Serial.begin(57600);
lcd.begin(20,4);
lcd.init();
lcd.backlight();
lcd.home();
lcd.clear();
analogReference(INTERNAL);
bme.begin(0x76);
ina219.begin(); //
ina219.setCalibration_16V_400mA();
pinMode(2, INPUT);
radio.begin();
radio.setChannel(72);
radio.openReadingPipe(0, address[0]);
radio.openWritingPipe(address[1]);
radio.setPALevel(RF24_PA_MIN);
radio.maskIRQ(1,1,0); //mask all IRQ triggers except for receive (1 is mask, 0 is no mask)
radio.startListening();
char text[32] = "";
String reply;
lcd.noBacklight();
attachInterrupt(0, interruptFunction, FALLING);
LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
detachInterrupt(0);
lcd.backlight();
// while(radio.available() & c < 8)
if(radio.available() ){
lcd.clear();
radio.read(&text, sizeof(text));
lcd.print(text);
reply = getData() + "#" + text;
lcd.setCursor(0,1);
lcd.print(reply);
reply.toCharArray(text, reply.length()+5);
radio.stopListening();
radio.write(&text, 32 );
else lcd.print("*");
count++;if(count == 80) {count = 0;lcd.clear();lcd.setCursor(0,0);}
delay(2000);
void interruptFunction() {}
String getData(){
float tempC, rh, dewpointC, t, pressure;
int tempF, dewpointF, power, count;
String readings = "";
bool report;
tempC = bme.readTemperature();
tempF = int(32 + 1.8 * tempC);
rh = bme.readHumidity();
t = logf(rh/100) + ((17.625 * tempC) / (243.04 + tempC) );
dewpointC = (243.04 * t) /
(17.625 - t);
dewpointF = int(32 + 1.8 * dewpointC);
pressure = 1.07+(0.02953*bme.readPressure()) / 100.0F;
power = int(ina219.getPower_mW());
power = 150;
readings = String(tempF) + ","
+ String(dewpointF) + ","
+ String(pressure) + ","
+ String(power) + ","
+ 5123 ;//int(1 11.5 * analogRead(A0) ); //battery state
// readings.toCharArray(payload, 32);
return readings;
#include <Wire.h>
#include <SPI.h>
#include <RF24.h>
int count = 0;
lcd.begin(20,4);
lcd.init();
lcd.backlight();
lcd.home();
lcd.clear();
radio.begin();
radio.openWritingPipe(address[0]);
radio.openReadingPipe(0, address[1]);
radio.setPALevel(RF24_PA_MIN, true);
char text[32];
String txt = "wakeup ";
lcd.clear();
txt = txt + String(count);
txt.toCharArray(text, txt.length()+5);
lcd.setCursor(0,0);
lcd.print("sending ");lcd.print(count);
radio.write(&text, 32);
delay(5);
if(radio.available()){
lcd.setCursor(0,1);
radio.read(&text, 32);
lcd.print(text);
Serial.println(text);
count++;
delay(5000);
