Thanks very much! I made it and its working fine with a lookup table ... only thing is on the bottom end its a bit steppy/notchy when I run a dimmer chase. Is probably due to the few steps or resolution (255 / 8 bit) ...... Is there a way to avoid this?
Here is my Code:
#include <avr/pgmspace.h> // Needed for PROGMEM and pgm_read_byte()
#include <DMXSerial.h>
#include "ws2812.h"
#define dmxModePin 2
#define dmxBaseCh 1
#define NUM_LEDS 10
const int RedPin = 13;
const int startChannel = 3;
byte uwLevel, wwLevel, cwLevel;
byte ledRgbData[NUM_LEDS * 3];
const uint8_t PROGMEM cwgamma8[] = {
0, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 3, 3, 3, 4, 4, 4, 5, 5, 6, 6, 7, 7, 7, 8, 8, 9, 9, 10, 10, 11, 11, 12, 13, 13, 14, 14, 15, 15, 16, 17, 17, 18, 18, 19, 20, 20, 21, 22, 22, 23, 24, 24, 25, 26, 27, 27, 28, 29, 29, 30, 31, 32, 32, 33, 34, 35, 35, 36, 37, 38, 39, 39, 40, 41, 42, 43, 44, 44, 45, 46, 47, 48, 49, 50, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 103, 104, 105, 106, 107, 108, 109, 110, 112, 113, 114, 115, 116, 117, 119, 120, 121, 122, 123, 124, 126, 127, 128, 129, 130, 132, 133, 134, 135, 136, 138, 139, 140, 141, 143, 144, 145, 146, 148, 149, 150, 151, 153, 154, 155, 157, 158, 159, 160, 162, 163, 164, 166, 167, 168, 170, 171, 172, 174, 175, 176, 178, 179, 180, 182, 183, 184, 186, 187, 188, 190, 191, 192, 194, 195, 197, 198, 199, 201, 202, 204, 205, 206, 208, 209, 211, 212, 213, 215, 216, 218, 219, 221, 222, 223, 225, 226, 228, 229, 231, 232, 234, 235, 237, 238, 240, 241, 243, 244, 245, 247, 248, 249, 250, 251, 253, 254, 255 };
const uint8_t PROGMEM uwgamma8[] = {
0, 0, 1, 2, 3, 4, 5, 6, 7, 8, 8, 9, 10, 11, 11, 12, 12, 13, 13, 14, 14, 15, 15, 16, 16, 17, 17, 18, 18, 19, 19, 20, 20, 20, 21, 21, 22, 22, 22, 23, 23, 24, 24, 24, 25, 25, 25, 26, 26, 26, 27, 27, 27, 27, 28, 28, 28, 28, 28, 29, 29, 29, 29, 29, 29, 29, 29, 29, 29, 29, 29, 29, 29, 30, 30, 30, 30, 30, 30, 30, 30, 30, 30, 30, 30, 30, 30, 30, 30, 29, 29, 29, 29, 29, 29, 29, 28, 28, 28, 28, 28, 28, 28, 28, 28, 28, 27, 27, 27, 27, 27, 27, 27, 27, 27, 27, 27, 27, 26, 26, 26, 26, 26, 26, 25, 25, 25, 24, 25, 24, 24, 24, 24, 24, 24, 24, 24, 23, 23, 23, 23, 23, 23, 22, 23, 23, 22, 23, 22, 22, 22, 22, 22, 22, 22, 21, 22, 21, 21, 21, 21, 21, 20, 21, 21, 20, 20, 20, 20, 20, 20, 20, 20, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 19, 18, 18, 18, 19, 18, 18, 18, 18, 18, 18, 18, 17, 17, 17, 17, 17, 17, 17, 17, 16, 16, 16, 16, 16, 16, 16, 16, 15, 15, 15, 15, 16, 15, 15, 15, 15, 14, 14, 14, 13, 14, 13, 13, 13, 12, 12, 11, 11, 10, 10, 10, 10, 9, 9, 8, 8, 7, 7, 6, 6, 5, 5, 4, 3, 3, 2, 2, 1, 0, 0, 0, 0,
const uint8_t PROGMEM wwgamma8[] = {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 2, 2, 3, 3, 3, 4, 5, 5, 6, 6, 7, 7, 8, 8, 9, 9, 10, 10, 11, 12, 12, 13, 13, 14, 15, 15, 16, 16, 17, 18, 18, 19, 20, 20, 21, 22, 22, 23, 24, 25, 25, 26, 27, 28, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 93, 94, 95, 96, 97, 99, 100, 101, 102, 103, 105, 106, 107, 108, 109, 110, 111, 112, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 126, 127, 128, 129, 130, 131, 132, 133, 134, 136, 137, 138, 139, 140, 141, 142, 143, 144, 146, 147, 148, 149, 150, 151, 152, 153, 154, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 170, 171, 172, 173, 174, 175, 176, 177, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 190, 191, 192, 193, 194, 195, 196, 197, 198, 200, 201, 202, 203, 204, 205, 207, 208, 209, 211, 212, 213, 214, 216, 217, 218, 220, 221, 223, 224, 225, 227, 228, 230, 231, 233, 234, 236, 237, 239, 240, 242, 243, 245, 247, 248, 250, 251, 253, 255,
void setup () {
DMXSerial.init(DMXProbe, dmxModePin);
DMXSerial.maxChannel(dmxBaseCh + NUM_LEDS * 3); // Adjust for total number of LEDs * 3
setupNeopixel();
pinMode(RedPin, OUTPUT);
if (DMXSerial.receive()) {
for (int i = 0; i < NUM_LEDS; i++) {
uwLevel = pgm_read_byte(&uwgamma8[DMXSerial.read(dmxBaseCh + i * 3)]);
wwLevel = pgm_read_byte(&wwgamma8[DMXSerial.read(dmxBaseCh + i * 3)]);
cwLevel = pgm_read_byte(&cwgamma8[DMXSerial.read(dmxBaseCh + i * 3 + 1)]);
ledRgbData[i * 3] = uwLevel;
ledRgbData[i * 3 + 2] = wwLevel;
ledRgbData[i * 3 + 1] = cwLevel;
updateNeopixel(ledRgbData, NUM_LEDS);
