Using SoftwareSerial library
Hello
I have this weirdness with the library
When used this way....
while(bluetooth.available()<1) {} // wait for input
i = bluetooth.parseInt(); // get int
bluetooth.print(i); // send out int
delay(100); // wait before continuing
it doesn't wait for input i doesn't get a value and falls through everything else
but if I leave out < bluetooth.print(i); >
it waits for input and i gets a value everything works after
any ideas on why this is so?
I'm using an Arduino nano for this
Why are you doing such wierdness with Bluetooth? Did you follow the examples?
SoftwareSerial can not transmit and receive at the same time, that may be causing your problem.
