using TFT Screen with Voice Recognition
Hello i am quite new to arduino.
i have a TFT Sceen 3.2" for arduino Mega (ILI9341)
Arduino Mega
and GeeeTech Voice recognition module
i am using the UTFT Library with a sample built in code
i am trying to make my Voice recognition module to work on an arduino board which has my TFT Screen on
i have the TFT Code working and the Voice recognition code working
but i cant figure out how to make them both work at the same time
(something like software serial?) i want the arduino to listen on touches and voices at the same time
cant figure out how to do that
both codes attached
slave_test ( is the file using the TFT Screen, also initializing the Voice recognition)
Voice_recognition_test (only voice)
again both works.
problem is when i want to combine them
thanks very much :slight_smile:
slave_code.ino (5.84 KB)
voice_recognition_test.ino (763 Bytes)
I've deleted your other cross-post @shahaf321.
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
When Per asked you not to cross post / duplicate he meant it !
Your additional duplicate also DELETED.
Please take the next 48 hours to read up from the links below.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
