So i have a project, i used an arduino uno and the voice module recognition worked just fine, 2 digital pins except 5v and gnd(its the only one you find when you search on google voice recognition module v3), i had to switch to arduino mega for the extra pins, but since then i cant make the recognition to work on the mega(it has a train code for eg ) and it doesnt get detectes in the code, i tried using 2 digital pins like on uno, nothing, i tried the special rx and tx pins(the module works on rx and tx or atleast that is written on the pins) i cant make it to work, can i get helped a little with some advices?
For informed help, please read and follow the instructions in the "How to get the best out of this forum" post. Post the code, using code tags, and a hand drawn wiring diagram, with pins and connections clearly labeled.
* @file vr_sample_train.ino
* @author JiapengLi
* @brief This file provides a demostration on
* how to train VoiceRecognitionModule to record your voice
* @note:
* Use serial command to control VoiceRecognitionModule. '
* All commands are case insensitive. Default serial baud rate 115200.
* COMMAND FORMAT EXAMPLE Comment
* train train (r0) (r1)... train 0 2 45 Train records
* load load (r0) (r1) ... load 0 51 2 3 Load records
* clear clear clear remove all records in Recognizer
* record record / record (r0) (r1)... record / record 0 79 Check record train status
* vr vr vr Check recognizer status
* getsig getsig (r) getsig 0 Get signature of record (r)
* sigtrain sigtrain (r) (sig) sigtrain 0 ZERO Train one record(r) with signature(sig)
* settings settings settings Check current system settings
* @section HISTORY
* 2013/06/13 Initial version.
#include <SoftwareSerial.h>
#include "VoiceRecognitionV3.h"
* Connection
* Arduino VoiceRecognitionModule
* 2 -------> TX
* 3 -------> RX
VR myVR(19,18); // 2:RX 3:TX, you can choose your favourite pins.
/** declare print functions */
void printSeperator();
void printSignature(uint8_t *buf, int len);
void printVR(uint8_t *buf);
void printLoad(uint8_t *buf, uint8_t len);
void printTrain(uint8_t *buf, uint8_t len);
void printCheckRecognizer(uint8_t *buf);
void printUserGroup(uint8_t *buf, int len);
void printCheckRecord(uint8_t *buf, int num);
void printCheckRecordAll(uint8_t *buf, int num);
void printSigTrain(uint8_t *buf, uint8_t len);
void printSystemSettings(uint8_t *buf, int len);
void printHelp(void);
// command analyze part
#define CMD_BUF_LEN 64+1
#define CMD_NUM 10
typedef int (*cmd_function_t)(int, int);
uint8_t cmd[CMD_BUF_LEN];
uint8_t cmd_cnt;
uint8_t *paraAddr;
int receiveCMD();
int checkCMD(int len);
int checkParaNum(int len);
int findPara(int len, int paraNum, uint8_t **addr);
int compareCMD(uint8_t *para1 , uint8_t *para2, int len);
int cmdTrain(int len, int paraNum);
int cmdLoad(int len, int paraNum);
int cmdTest(int len, int paraNum);
int cmdVR(int len, int paraNum);
int cmdClear(int len, int paraNum);
int cmdRecord(int len, int paraNum);
int cmdSigTrain(int len, int paraNum);
int cmdGetSig(int len, int paraNum);
int cmdSettings(int len, int paraNum);
int cmdHelp(int len, int paraNum);
/** cmdList, cmdLen, cmdFunction has correspondence */
const char cmdList[CMD_NUM][10] = { // command list table
"train" }
"load" }
"clear" }
"vr" }
"record" }
"sigtrain" }
"getsig" }
"Settings" }
"test" }
"help" }
const char cmdLen[CMD_NUM]= { // command length
5, // {"train"},
4, // {"load"},
5, // {"clear"},
2, // {"vr"},
6, // {"record"},
8, // {"sigtrain"},
6, // {"getsig"},
8, // {"Settings"},
4, // {"test"},
4, // {"help"}
cmd_function_t cmdFunction[CMD_NUM]={ // command handle fuction(function pointer table)
cmdTrain,
cmdLoad,
cmdClear,
cmdVR,
cmdRecord,
cmdSigTrain,
cmdGetSig,
cmdSettings,
cmdTest,
cmdHelp,
/** temprory data */
uint8_t buf[255];
uint8_t records[7]; // save record
void setup(void)
myVR.begin(9600);
/** initialize */
Serial.println(F("Elechouse Voice Recognition V3 Module \"train\" sample."));
printSeperator();
Serial.println(F("Usage:"));
printSeperator();
printHelp();
printSeperator();
cmd_cnt = 0;
void loop(void)
int len, paraNum, paraLen, i;
/** receive Serial command */
len = receiveCMD();
if(len>0){
/** check if the received command is valid */
if(!checkCMD(len)){
/** check parameter number of the received command */
paraNum = checkParaNum(len);
/** display the receved command back */
Serial.write(cmd, len);
/** find the first parameter */
paraLen = findPara(len, 1, ¶Addr);
/** compare the received command with command in the list */
for(i=0; i<CMD_NUM; i++){
/** compare command length */
if(paraLen == cmdLen[i]){
/** compare command content */
if( compareCMD(paraAddr, (uint8_t *)cmdList[i], paraLen) == 0 ){
/** call command function */
if( cmdFunction[i](len, paraNum) != 0){
printSeperator();
Serial.println(F("Command Format Error!"));
printSeperator();
/** command is not supported*/
if(i == CMD_NUM){
printSeperator();
Serial.println(F("Unkonwn command"));
printSeperator();
else{
/** received command is invalid */
printSeperator();
Serial.println(F("Command format error"));
printSeperator();
/** try to receive recognize result */
int ret;
ret = myVR.recognize(buf, 50);
if(ret>0){
/** voice recognized, print result */
printVR(buf);
* @brief receive command from Serial.
* @param NONE.
* @retval command length, if no command receive return -1.
int receiveCMD()
int ret;
int len;
unsigned long start_millis;
start_millis = millis();
while(1){
ret = Serial.read();
if(ret>0){
cmd[cmd_cnt] = ret;
if(cmd[cmd_cnt] == '\n'){
len = cmd_cnt+1;
cmd_cnt = 0;
return len;
cmd_cnt++;
if(cmd_cnt == CMD_BUF_LEN){
cmd_cnt = 0;
return -1;
if(millis() - start_millis > 100){
cmd_cnt = 0;
return -1;
* @brief compare two commands, case insensitive.
* @param para1 --> command buffer 1
* para2 --> command buffer 2
* len --> buffer length
* @retval 0 --> equal
* -1 --> unequal
int i;
uint8_t res;
for(i=0; i<len; i++){
res = para2[i] - para1[i];
if(res != 0 && res != 0x20){
res = para1[i] - para2[i];
return -1;
return 0;
* @brief Check command format.
* @param len --> command length
* @retval 0 --> command is valid
* -1 --> command is invalid
int i;
if(cmd[i] > 0x1F && cmd[i] < 0x7F){
else if(cmd[i] == '\t' || cmd[i] == ' ' || cmd[i] == '\r' || cmd[i] == '\n'){
else{
return -1;
return 0;
* @brief Check the number of parameters in the command
* @retval number of parameters
int cnt=0, i;
for(i=0; i<len; ){
if(cmd[i]!='\t' && cmd[i]!=' ' && cmd[i] != '\r' && cmd[i] != '\n'){
cnt++;
while(cmd[i] != '\t' && cmd[i] != ' ' && cmd[i] != '\r' && cmd[i] != '\n'){
i++;
i++;
return cnt;
* @brief Find the specified parameter.
* paraIndex --> parameter index
* addr --> return value. position of the parameter
* @retval length of specified parameter
int findPara(int len, int paraIndex, uint8_t **addr)
int cnt=0, i, paraLen;
uint8_t dt;
for(i=0; i<len; ){
dt = cmd[i];
if(dt!='\t' && dt!=' '){
cnt++;
if(paraIndex == cnt){
*addr = cmd+i;
paraLen = 0;
i++;
paraLen++;
return paraLen;
else{
i++;
else{
i++;
return -1;
if(paraNum != 1){
return -1;
printSeperator();
printHelp();
printSeperator();
return 0;
* @brief Handle "train" command
* paraNum --> number of parameters
* @retval 0 --> success
* -1 --> Command format error
int i, ret;
if(paraNum < 2 || paraNum > 8 ){
return -1;
for(i=2; i<=paraNum; i++){
findPara(len, i, ¶Addr);
records[i-2] = atoi((char *)paraAddr);
if(records[i-2] == 0 && *paraAddr != '0'){
return -1;
printSeperator();
ret = myVR.train(records, paraNum-1, buf);
// ret = myVR.train(records, paraNum-1);
if(ret >= 0){
printTrain(buf, ret);
else if(ret == -1){
Serial.println(F("Train failed."));
else if(ret == -2){
Serial.println(F("Train Timeout."));
printSeperator();
return 0;
* @brief Handle "load" command
int i, ret;
return -1;
return -1;
// myVR.writehex(records, paraNum-1);
ret = myVR.load(records, paraNum-1, buf);
printSeperator();
if(ret >= 0){
printLoad(buf, ret);
else{
Serial.println(F("Load failed or timeout."));
printSeperator();
return 0;
* @brief Handle "clear" command
if(paraNum != 1){
return -1;
if(myVR.clear() == 0){
printSeperator();
Serial.println(F("Recognizer cleared."));
printSeperator();
else{
printSeperator();
Serial.println(F("Clear recognizer failed or timeout."));
printSeperator();
return 0;
* @brief Handle "vr" command
int ret;
if(paraNum != 1){
return -1;
ret = myVR.checkRecognizer(buf);
if(ret<=0){
printSeperator();
Serial.println(F("Check recognizer failed or timeout."));
printSeperator();
return 0;
printSeperator();
printCheckRecognizer(buf);
printSeperator();
return 0;
* @brief Handle "record" command
int ret;
if(paraNum == 1){
ret = myVR.checkRecord(buf);
printSeperator();
if(ret>=0){
printCheckRecordAll(buf, ret);
else{
Serial.println(F("Check record failed or timeout."));
printSeperator();
else if(paraNum < 9){
for(int i=2; i<=paraNum; i++){
return -1;
ret = myVR.checkRecord(buf, records, paraNum-1); // auto clean duplicate records
printSeperator();
if(ret>=0){
printCheckRecord(buf, ret);
else{
printSeperator();
else{
return -1;
return 0;
* @brief Handle "sigtrain" command
int ret, sig_len;
uint8_t *lastAddr;
if(paraNum < 2){
return -1;
findPara(len, 2, ¶Addr);
records[0] = atoi((char *)paraAddr);
if(records[0] == 0 && *paraAddr != '0'){
return -1;
findPara(len, 3, ¶Addr);
sig_len = findPara(len, paraNum, &lastAddr);
sig_len +=( (unsigned int)lastAddr - (unsigned int)paraAddr );
printSeperator();
ret = myVR.trainWithSignature(records[0], paraAddr, sig_len, buf);
// ret = myVR.trainWithSignature(records, paraNum-1);
if(ret >= 0){
printSigTrain(buf, ret);
else{
Serial.println(F("Train with signature failed or timeout."));
printSeperator();
return 0;
* @brief Handle "getsig" command
int ret;
if(paraNum != 2){
return -1;
return -1;
ret = myVR.checkSignature(records[0], buf);
printSeperator();
if(ret == 0){
Serial.println(F("Signature isn't set."));
else if(ret > 0){
Serial.print(F("Signature:"));
printSignature(buf, ret);
else{
Serial.println(F("Get sig error or timeout."));
printSeperator();
return 0;
* @brief Handle "test" command
printSeperator();
Serial.println(F("TEST is not supported."));
printSeperator();
return 0;
int ret;
if(paraNum != 1){
return -1;
ret = myVR.checkSystemSettings(buf);
if( ret > 0){
printSeperator();
printSystemSettings(buf, ret);
printSeperator();
else{
printSeperator();
Serial.println(F("Check system settings error or timeout"));
printSeperator();
return 0;
* @brief Print signature, if the character is invisible,
* print hexible value instead.
* @param buf --> command length
* len --> number of parameters
int i;
if(buf[i]>0x19 && buf[i]<0x7F){
Serial.write(buf[i]);
else{
Serial.print(F("["));
Serial.print(buf[i], HEX);
Serial.print(F("]"));
* @param buf --> VR module return value when voice is recognized.
* buf[0] --> Group mode(FF: None Group, 0x8n: User, 0x0n:System
* buf[1] --> number of record which is recognized.
* buf[2] --> Recognizer index(position) value of the recognized record.
* buf[3] --> Signature length
* buf[4]~buf[n] --> Signature
Serial.println(F("VR Index\tGroup\tRecordNum\tSignature"));
Serial.print(buf[2], DEC);
Serial.print(F("\t\t"));
if(buf[0] == 0xFF){
Serial.print(F("NONE"));
else if(buf[0]&0x80){
Serial.print(F("UG "));
Serial.print(buf[0]&(~0x80), DEC);
else{
Serial.print(F("SG "));
Serial.print(buf[0], DEC);
Serial.print(F("\t"));
Serial.print(buf[1], DEC);
if(buf[3]>0){
printSignature(buf+4, buf[3]);
else{
Serial.println(F("\r\n"));
* @brief Print seperator. Print 80 '-'.
for(int i=0; i<80; i++){
Serial.write('-');
* @brief Print recoginizer status.
* buf[0] --> Number of valid voice records in recognizer
* buf[i+1] --> Record number.(0xFF: Not loaded(Nongroup mode), or not set (Group mode)) (i= 0, 1, ... 6)
* buf[8] --> Number of all voice records in recognizer
* buf[9] --> Valid records position indicate.
* buf[10] --> Group mode indicate(FF: None Group, 0x8n: User, 0x0n:System)
Serial.print(F("All voice records in recognizer: "));
Serial.println(buf[8], DEC);
Serial.print(F("Valid voice records in recognizer: "));
Serial.println(buf[0], DEC);
if(buf[10] == 0xFF){
Serial.println(F("VR is not in group mode."));
else if(buf[10]&0x80){
Serial.print(F("VR is in user group mode:"));
Serial.println(buf[10]&0x7F, DEC);
else{
Serial.print(F("VR is in system group mode:"));
Serial.println(buf[10], DEC);
Serial.println(F("VR Index\tRecord\t\tComment"));
for(int i=0; i<7; i++){
Serial.print(i, DEC);
if(buf[i+1] == 0xFF){
Serial.print(F("Unloaded\tNONE"));
else{
Serial.print(F("Not Set\t\tNONE"));
else{
Serial.print(buf[i+1], DEC);
if(buf[9]&(1<<i)){
Serial.print(F("Valid"));
else{
Serial.print(F("Untrained"));
* @brief Print record train status.
* @param buf --> Check record command return value
* buf[0] --> Number of checked records
* buf[2i+1] --> Record number.
* buf[2i+2] --> Record train status. (00: untrained, 01: trained, FF: record value out of range)
* (i = 0 ~ buf[0]-1 )
* num --> Number of trained records
Serial.print(F("Check "));
Serial.println(F(" records."));
Serial.print(num, DEC);
if(num>1){
Serial.println(F(" records trained."));
else{
Serial.println(F(" record trained."));
for(int i=0; i<buf[0]*2; i += 2){
Serial.print(F("\t-->\t"));
switch(buf[i+2]){
case 0x01:
Serial.print(F("Trained"));
case 0x00:
case 0xFF:
Serial.print(F("Record value out of range"));
default:
Serial.print(F("Unknown Stauts"));
Serial.print(F("Check 255"));
if(num>1){
else{
myVR.writehex(buf, 255);
for(int i=0; i<255; i++){
if(buf[i] == 0xF0){
continue;
switch(buf[i]){
case 0x01:
case 0x00:
case 0xFF:
default:
* @brief Print check user group result.
* buf[8i] --> group number.
* buf[8i+1] --> group position 0 status.
* buf[8i+2] --> group position 1 status.
* buf[8i+6] --> group position 5 status.
* buf[8i+7] --> group position 6 status.
* (i = 0 ~ len)
* len --> number of checked groups
int i, j;
Serial.println(F("Check User Group:"));
Serial.print(F("Group:"));
Serial.println(buf[8*i]);
for(j=0; j<7; j++){
if(buf[8*i+1+j] == 0xFF){
Serial.print(F("NONE\t"));
else{
Serial.print(buf[8*i+1+j], DEC);
* @brief Print "load" command return value.
* @param buf --> "load" command return value
* buf[0] --> number of records which are load successfully.
* buf[2i+1] --> record number
* buf[2i+2] --> record load status.
* 00 --> Loaded
* FC --> Record already in recognizer
* FD --> Recognizer full
* FE --> Record untrained
* FF --> Value out of range"
* (i = 0 ~ (len-1)/2 )
* len --> length of buf
if(len == 0){
Serial.println(F("Load Successfully."));
return;
else{
Serial.print(F("Load success: "));
for(int i=0; i<len-1; i += 2){
Serial.print(F("Record "));
switch(buf[i+2]){
case 0:
Serial.println(F("Loaded"));
case 0xFC:
Serial.println(F("Record already in recognizer"));
case 0xFD:
Serial.println(F("Recognizer full"));
case 0xFE:
Serial.println(F("Record untrained"));
case 0xFF:
Serial.println(F("Value out of range"));
default:
Serial.println(F("Unknown status"));
* @brief Print "train" command return value.
* @param buf --> "train" command return value
* buf[0] --> number of records which are trained successfully.
* buf[2i+2] --> record train status.
* 00 --> Trained
* FE --> Train Time Out
* (i = 0 ~ len-1 )
if(len == 0){
Serial.println(F("Train Finish."));
return;
else{
Serial.print(F("Train success: "));
switch(buf[i+2]){
case 0:
Serial.println(F("Trained"));
case 0xFE:
Serial.println(F("Train Time Out"));
case 0xFF:
default:
Serial.print(F("Unknown status "));
Serial.println(buf[i+2], HEX);
* @brief Print "sigtrain" command return value.
* @param buf --> "sigtrain" command return value
* buf[1] --> record number
* buf[2] --> record train status.
* 00 --> Trained
* F0 --> Trained, signature truncate
* buf[3] ~ buf[len-1] --> Signature.
if(len == 0){
Serial.println(F("Train With Signature Finish."));
return;
else{
Serial.print(F("Success: "));
switch(buf[2]){
case 0:
case 0xF0:
Serial.println(F("Trained, signature truncate"));
case 0xFE:
case 0xFF:
default:
Serial.println(buf[2], HEX);
Serial.print(F("SIG: "));
Serial.write(buf+3, len-3);
* @brief Print "settings" command return value.
* @param buf --> "settings" command return value
* 00 --> Trained
const unsigned int io_pw_tab[16]={
10, 15, 20, 25, 30, 35, 40, 45,
50, 75, 100, 200, 300, 400, 500, 1000
switch(buf[0]){
case 0:
case 3:
Serial.println(F("Baud rate: 9600"));
case 1:
Serial.println(F("Baud rate: 2400"));
case 2:
Serial.println(F("Baud rate: 4800"));
case 4:
Serial.println(F("Baud rate: 19200"));
case 5:
Serial.println(F("Baud rate: 38400"));
default:
Serial.println(F("Baud rate: UNKONOWN"));
switch(buf[1]){
case 0:
case 0xFF:
Serial.println(F("Outpu IO Mode: Pulse"));
case 1:
Serial.println(F("Outpu IO Mode: Toggle"));
case 2:
Serial.println(F("Outpu IO Mode: Clear(When recognized) "));
case 3:
Serial.println(F("Outpu IO Mode: Set(When recognized)"));
default:
Serial.println(F("Output IO Mode: UNKONOWN"));
if(buf[2] > 15){
Serial.println(F("Pulse width: UNKONOWN"));
else{
Serial.print(F("Pulse Width: "));
Serial.print(io_pw_tab[buf[2]], DEC);
Serial.println(F("ms"));
if(buf[3] == 0 || buf[3] == 0xFF){
Serial.println(F("Auto Load: disable"));
else{
Serial.println(F("Auto Load: enable"));
switch(buf[4]){
case 0:
case 0xFF:
Serial.println(F("Group control by external IO: disabled"));
case 1:
Serial.println(F("Group control by external IO: system group selected"));
case 2:
Serial.println(F("Group control by external IO: user group selected"));
default:
Serial.println(F("Group control by external IO: UNKNOWN STATUS"));
Serial.println(F("COMMAND FORMAT EXAMPLE Comment"));
printSeperator();
// Serial.println(F("--------------------------------------------------------------------------------------------------------------"));
Serial.println(F("train train (r0) (r1)... train 0 2 45 Train records"));
Serial.println(F("load load (r0) (r1) ... load 0 51 2 3 Load records"));
Serial.println(F("clear clear clear remove all records in Recognizer"));
Serial.println(F("record record / record (r0) (r1)... record / record 0 79 Check record train status"));
Serial.println(F("vr vr vr Check recognizer status"));
Serial.println(F("getsig getsig (r) getsig 0 Get signature of record (r)"));
Serial.println(F("sigtrain sigtrain (r) (sig) sigtrain 0 ZERO Train one record(r) with signature(sig)"));
Serial.println(F("settings settings settings Check current system settings"));
Serial.println(F("help help help print this message"));
This is the code and this is how it works : https://www.youtube.com/watch?v=YZ0SOAFXVAQ, on my arduino uno on pin 5 RX and on pin 6 the TX, on the mega i couldnt make it work i tried plugging it in the RX TX ports nothing, normal digitals, nothing
Did you read this link?
Post a wiring diagram. Hand drawn is preferred, with pins and connections clearly labeled.
