Using the Chrono Library
Hi everyone,
I have recently discovered the chrono library and have been using for a project i am working on, however i am getting some unusal behaviour, which i am struggling to get to the bottom of, and i am hoping someone will be able to point out my error.
Specifically the problem is found when i stop and resume a chrono timer, and i have made a sketch to demonstrate what i am finding..
#include <Chrono.h>
boolean toggle1 = HIGH;
// Instantiate Chronos
Chrono chronoA;
Chrono chronoB;
Chrono chronoC;
Chrono chronoDisplay;
  Serial.begin(57600);
  while (!Serial) {
  if (chronoA.hasPassed(5000)) {  //Every 5 seconds..
    toggle1 = !toggle1;           //..toggle..
    chronoA.restart();            //..and restart the chrono
  if (toggle1 == LOW) {   //If the toggle is low..
    chronoB.stop();       //..pause the chrono
  if (toggle1 == HIGH) {  //If the toggle is High..
    chronoB.resume();     //..resume the chrono
  if (chronoDisplay.hasPassed(500)) {   //Every 0.5seconds..
    Serial.print("ChronoA: ");          //..output the values to serial
    Serial.println(chronoA.elapsed());
    Serial.print("ChronoB: ");
    Serial.println(chronoB.elapsed());
    Serial.print("ChronoC: ");
    Serial.println(chronoC.elapsed());
    Serial.print("Toggle Position: ");
    Serial.println(toggle1);
    Serial.print("Is chronoB Running: ");
    Serial.println(chronoB.isRunning());
    chronoDisplay.restart();
The sketch is intended to stop and resume chonoB every 5 seconds, so for 5 seconds it would count up, then stop for 5 seconds, and then count up for a additional 5 seconds etc etc.
However i am finding that chronoB does count up but does not follow any kind of pattern.
If someone could point out my error i would be very grateful!
Boolean variables should be assigned values of true or false.
I can't see any pattern, either. Hint, hint.
Right - like what is this supposed to do, got a link?
Cause the name alone - Chronos, intrigues me. It blends 50's style sci-fi with Arduino.
Paul, I'll remember that about boolean assigned values, thanks.
Chris, here is the description of the chrono library
http://sofapirate.github.io/Chrono/#heading_toc_j_11
Thank you for your replies.
If we could see the output, perhaps the pattern would be obvious to someone, who could then suggest what the problem is, and maybe even a solution.
Hi Paul,
doh, I guess that would help :slight_smile:
ChronoA: 1003
ChronoB: 0
ChronoC: 1003
Toggle Position: 1
Is chronoB Running: 1
ChronoA: 1506
ChronoB: 1
ChronoC: 1506
Toggle Position: 1
ChronoA: 2009
ChronoB: 0
ChronoC: 2009
Toggle Position: 1
ChronoA: 2512
ChronoB: 0
ChronoC: 2512
Toggle Position: 1
ChronoA: 3015
ChronoB: 1
ChronoC: 3015
Toggle Position: 1
ChronoA: 3518
ChronoB: 0
ChronoC: 3518
Toggle Position: 1
ChronoA: 4021
ChronoB: 0
ChronoC: 4021
Toggle Position: 1
ChronoA: 4524
ChronoB: 0
ChronoC: 4524
Toggle Position: 1
ChronoA: 27
ChronoB: 1
ChronoC: 5027
Toggle Position: 0
Is chronoB Running: 0
ChronoA: 530
ChronoB: 1
ChronoC: 5530
Toggle Position: 0
ChronoA: 1033
ChronoB: 1
ChronoC: 6033
Toggle Position: 0
ChronoA: 1536
ChronoB: 1
ChronoC: 6536
Toggle Position: 0
ChronoA: 2040
ChronoB: 1
ChronoC: 7040
Toggle Position: 0
ChronoA: 2543
ChronoB: 1
ChronoC: 7543
Toggle Position: 0
ChronoA: 3046
ChronoB: 1
ChronoC: 8046
Toggle Position: 0
ChronoA: 3549
ChronoB: 1
ChronoC: 8549
Toggle Position: 0
ChronoA: 4052
ChronoB: 1
ChronoC: 9052
Toggle Position: 0
ChronoA: 4555
ChronoB: 1
ChronoC: 9555
Toggle Position: 0
ChronoA: 59
ChronoB: 1
ChronoC: 10059
Toggle Position: 1
ChronoA: 562
ChronoB: 1
ChronoC: 10562
Toggle Position: 1
ChronoA: 1065
ChronoB: 1
ChronoC: 11065
Toggle Position: 1
ChronoA: 1568
ChronoB: 1
ChronoC: 11568
Toggle Position: 1
ChronoA: 2071
ChronoB: 1
ChronoC: 12071
Toggle Position: 1
ChronoA: 2575
ChronoB: 2
ChronoC: 12575
Toggle Position: 1
ChronoA: 3078
ChronoB: 1
ChronoC: 13078
Toggle Position: 1
ChronoA: 3581
ChronoB: 1
ChronoC: 13581
Toggle Position: 1
ChronoA: 4084
ChronoB: 2
ChronoC: 14084
Toggle Position: 1
ChronoA: 4587
ChronoB: 1
ChronoC: 14587
Toggle Position: 1
ChronoA: 90
ChronoB: 2
ChronoC: 15090
Toggle Position: 0
ChronoA: 593
ChronoB: 2
ChronoC: 15593
Toggle Position: 0
ChronoA: 1096
ChronoB: 2
ChronoC: 16096
Toggle Position: 0
ChronoA: 1599
ChronoB: 2
ChronoC: 16599
Toggle Position: 0
ChronoA: 2102
ChronoB: 2
ChronoC: 17102
Toggle Position: 0
ChronoA: 2605
ChronoB: 2
ChronoC: 17605
Toggle Position: 0
PaulS:
Heh.
@OP (who is devil plus one, I guess ...)
Move the curly brace from right under the line:
</sub> <sub>  chronoA.restart();            //..and restart the chrono</sub> <sub>
to the end of your sketch, and it works, right?
I don't see the point though. Chrono.reset() is cool, but it just seems like an extraneous level of abstraction on top of an already abstracted construct, namely millis() counting.
Hi Chris,
You are right! I moved the curly bracket and it started to work.
#include <Chrono.h>
bool toggle1 = true;
Chrono chronoA;
Chrono chronoB;
Chrono chronoC;
  while (!Serial) {
    if (toggle1 == false) {   //If the toggle is low..
    } else if (toggle1 == true) {  //If the toggle is High..
So, i guess it didnt like the original version of my sketch calling the .stop() and .resume() command every at iteration of the loop?
Really appreciate your help with that Chris.
