if you use a MIDI library (like this one), then you've a class that represent the midi connexion and thus you use the class to handle the communication and you'll have high level functions and capabilities. For example the library I just linked let you send MIDI over USB, Bluetooth, IP and AppleMIDI or has methods such as sendNoteOn() or sendPitchBend()
if you use directly the Serial line then you use the Serial class. it has no knowledge of midi of coure, so you have to handle everything yourself
it depends which library you have and on which line you communicate.
If the library expects a link that is already open for its transport, then yes, you need to do Serial.begin() or Serial1.begin() or whatever port is required indeed (baud rate would need to be 31250 for MIDI)
In the library I linked previously, you don't need to open it. you call [url=https://github.com/FortySevenEffects/arduino_midi_library/blob/da8ca5e69a63e1cbf2433e070b87e6f09a709b85/src/serialMIDI.h#L115]MIDI_CREATE_DEFAULT_INSTANCE[/url]() at the start of your sketch and that will configure Serial for you in the library that will be activated when you call begin() for the library.
ianmacleod:
Some are written with Serial.Begin and using the Serial.write method
It's quite possible to write MIDI programs without using any MIDI library. MIDI programs using Serial.writes are usually doing that. But without any links so I can see what it is you're looking at that's just a guess.
