Hello, this is not a question, this is a discussion about using .readBytes() from the Stream class with the Wire library. It started in a other topic.
The Stream.readBytes() can wait for new data to arrive, but the I2C bus uses packages of data and new data will never arrive.
New users might make a mistake with the number of bytes. If they ask too many bytes with Wire.readBytes(), then the timeout kicks in which is useless for the I2C bus.
The source code of Stream.readBytes() is here and the function timedRead() is here. Since the Stream class is at a higher level and not hardware related, its code is often (almost) the same on other platforms.
Test sketch with a bug to make the timeout appear:
#include <Wire.h>
byte buffer[20];
Serial.begin( 115200);
Serial.println( "Testing timeout with a bug in the code...");
Wire.begin();
Wire.setTimeout( 3000); // default 1 second, let's make it 3 for fun.
Wire.beginTransmission( 0x68);
Wire.write( 0x00);
Wire.endTransmission();
unsigned long t1 = millis();
// Better code could be:
// Wire.requestFrom( 0x68, 5);
// if( Wire.available() == 5)
// Or shorter:
// if( Wire.requestFrom( 0x68, 5) == 5)
if( Wire.available() > 0) // I do not agree with this code line
Wire.readBytes( buffer, 6); // use a bug, read 6 when there are only 5 !
unsigned long t2 = millis();
unsigned long elapsedMillis = t2 - t1;
Serial.print( "The code with the bug took ");
Serial.print( (float) elapsedMillis / 1000.0);
Serial.println( " seconds.");
void loop() {}
The sketch in Wokwi:
This problem is trivial: if the code has a bug then why worry about a unwanted timeout anyway ?
However, when the Wire.readBytes() would be used in the onReceive handler of a Target (Slave), then a timeout (caused by a bug in the sketch) is not harmless anymore.
