Using TMRPCM through SD card with Servo
#include <SPI.h>
#include <SD.h>                      // need to include the SD library
#define SD_ChipSelectPin 4           //using digital pin 4 on arduino nano 328, can use other pins
#include <TMRpcm.h>
#include <Servo.h>
int pos = 0;                          // variable to store the servo position
int count = 0;                        //Number of sweeps
int ledPin=8;                         //definition digital 8 pins as pin to control the LED
long duration;                        // variable for the duration of sound wave travel
int distance;                         // variable for the distance measurement
#define echoPin 3                     // attach pin D9 Arduino to pin Echo of HC-SR04
#define trigPin 10                    //attach pin D10 Arduino to pin Trig of HC-SR04
Servo servo;
TMRpcm tmrpcm;                        // create an object for use in this sketch
 pinMode(ledPin,OUTPUT);             //Set the digital 8 port mode, OUTPUT: Output mode
 pinMode(2 , OUTPUT);            //Set the digital 2 port mode, OUTPUT: Output mode
 pinMode(7 , OUTPUT);              //Set the digital 7 port mode, OUTPUT: Output mode
 pinMode(trigPin, OUTPUT);           // Sets the trigPin as an OUTPUT
 pinMode(echoPin, INPUT);            // Sets the echoPin as an INPUT
 tmrpcm.speakerPin = 9;              //5,6,11 or 46 on Mega, 9 on Uno, Nano, etc
 servo.attach(5);
 if (!SD.begin(SD_ChipSelectPin))
    {  // see if the card is present and can be initialized:
    Serial.println("SD fail");
    return;   // don't do anything more if not
    Serial.println("SD ok");
  digitalWrite(ledPin,HIGH);          //HIGH is set to about 5V PIN8
  delay(1000);                         //Set the delay time, 1000 = 1S
  digitalWrite(ledPin,LOW);            //LOW is set to about 5V PIN8
  // Clears the trigPin condition
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  // Sets the trigPin HIGH (ACTIVE) for 10 microseconds
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Reads the echoPin, returns the sound wave travel time in microseconds
  duration = pulseIn(echoPin, HIGH);
  // Calculating the distance
  distance = duration * 0.034 / 2; // Speed of sound wave divided by 2 (go and back)
  Serial.println(distance);
  if(distance<20)
    count=0;
    digitalWrite(2,HIGH);
    digitalWrite(7, LOW);
    tmrpcm.play("ECI3.wav"); //the sound file will play each time the arduino powers up, or is reset
    //audio.stopPlayback()
    while (count<=5)
      for (pos=0; pos<=180 ; pos++)
        servo.write(pos);
        delay(15);
      for (int pos=180; pos>=0 ; pos--)
        servo.write(pos);
        delay(15);
         count=count+1;
    digitalWrite(2,LOW);
In my setup, once the distance sensor is activated, a sound plays , two motors start running and one servo motor starts to and fro motion. But during operation, the sound file is not playing and only there is a static noise of motor running and servo motion. Already tried USE_TIMER2 of tmrpcm library and Servotimer2 library. Please help.
Thanks in advance friends.
Post that code, instead of code that obviously cannot work because of the well-documented conflict.
Making both of the changes quoted above won't work either.
Should I post the code with Servotimer2 library for reference?
Additionally, can you please send the link to the reference for the conflict.
Regards
Post code that you think should work, but doesn't, and explain what goes wrong. Also post a hand drawn wiring diagram corresponding to the posted code, with pins labeled.
The TMRpcm and Servo libraries both use Timer1 on the Uno, which does not work.
By the way, you appear to be making two common and sometimes fatal mistakes for the equipment: attempting to power a servo from the 5V Arduino pin, and using a 9V smoke alarm battery to power a motor.
Neither is likely to work well, if at all, and the servo may actually damage the voltage regulator on the Uno.
I have put my best effort to put everything in pen and paper. Sorry for the lousy effort.
I m using 12V supply from my 12V UPS. Using 9V supply for energising my Servo and Motors.
Please ask me in case of clarification required regarding diagram.
Regards
I just went through my own circuit diagram and request f clarification -
As I have utilised tmrpcm lib with #USE_TIMER2, PWM 3 and 11 cannot be used. But I need to use the pin 11 for MOSI of <SD.H>. Any solution?
An Arduino Mega, Pro Micro or Micro (etc.) has more timers.
PCA9685 16bit PWM driver should work?
Getting a better board is always the best solution but since I m still in the bottom most point of the learning curve, I have another question :-
Can I put another 16Mhz timer in existing arduino for additional timer?
