Using two dfplayer modules
I'm using arduino nano board, and I'm trying to play two different music simultaneously. One dfplayer has to be controlled by a touch sensor, and another dfplayer will be controlled by the distance sensor. But I don't know how to connect 2 dfplayers with the nano board. Now I connected one dfplayer.
//Very much inspired by https://www.dfrobot.com/blog-1462.html by DFRobot Feb 26 2020
//Additions made by Just Baselmans https://www.youtube.com/justbaselmansYT Jan 23 2023
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
// Initialize software serial on pins 10 and 11
SoftwareSerial mySoftwareSerial1(10, 11);
SoftwareSerial mySoftwareSerial2(7, 8);
DFRobotDFPlayerMini myDFPlayer;
String line;
char command;
int dis1 = A1;
int touch = A2;
int track = 1;
  // Serial communication with the module
  mySoftwareSerial1.begin(9600);
  mySoftwareSerial2.begin(9600);
  // Initialize Arduino serial
  analogReference(DEFAULT);
  pinMode (dis1, INPUT);
  Serial.println(F("DFRobot DFPlayer Mini"));
  Serial.println(F("Initializing DFPlayer module ... Wait!"));
  if (!myDFPlayer.begin(mySoftwareSerial1)) {
    Serial.println(F("Not initialized:"));
    Serial.println(F("1. Check the DFPlayer Mini connections"));
    Serial.println(F("2. Insert an SD card"));
    while (true)
  Serial.println(F("DFPlayer Mini module initialized!"));
  //myDFPlayer.setTimeOut(500);
  myDFPlayer.volume(15);
  myDFPlayer.EQ(0);
  command = Serial.peek();
  line = Serial.readStringUntil('\n');
  int raw1=analogRead(dis1);
 int touchval = analogRead(touch);
  //Serial.println(raw1);
  //Serial.println(touchval);
  delay(100);
  int range = map(raw1, 220, 700, 0, 7);
  switch (range) {
    case 0:
      myDFPlayer.play(1);
      Serial.println("Range 8");
    case 1:
      myDFPlayer.play(2);
      Serial.println("Range 7");
    case 2:
      myDFPlayer.play(3);
      Serial.println("Range 6");
    case 3:
      myDFPlayer.play(4);
      Serial.println("Range 5");
    case 4:
      myDFPlayer.play(5);
      Serial.println("Range 4");
    case 5:
      myDFPlayer.play(6);
      Serial.println("Range 3");
    case 6:
      myDFPlayer.play(7);
      Serial.println("Range 2");
    case 7:
      myDFPlayer.play(8);
      Serial.println("Range 1");
In the Arduino IDE, on the menu bar click on Edit then Copy for Forum, then post your code here
Much bettor
Thank you
Sorry, but, 2 instances of SoftwareSerial is not a particularly good idea.
Then, how can I play two dfplayers?
My project deadline is 2 days left and I only have a nano, fio, uno board
Does your current code work correctly for just the one player?
yes it works
Well, just like SoftwareSerial, you can create two players:
DFRobotDFPlayerMini myDFPlayer1;
DFRobotDFPlayerMini myDFPlayer2;
Check to see if they are working and connected:
!myDFPlayer1.begin(mySoftwareSerial1, false, true)
!myDFPlayer2.begin(mySoftwareSerial2, false, true)
Play a track:
myDFPlayer1.play(1);
delay(10);
myDFPlayer2.play(1);
The rest is up to you.
D'accord - nous verrons.
Connect them in I/O Mode (VCC, GND, SPK_1, SPK_2). When you want DFPlayerMini to play NEXT file, "short-press" grounding IO_2, for PREV file, "short-press" grounding IO_1. "Long-press" will increase/decrease volume.
Thank you sooo much this works well
Glad it worked
Have a nice day!
Toujours le sceptique
I'm curious. Are they playing simultaneously (sounds from both speakers playing over each other), or successively?
Could you share your code please?
