I have a arduino nano v3.0 with a dfplayer mini and a power supply with 3.3V or 5V.I also have the speaker 3W with 8 ohm.But i cant seem to make it work.I tried it but it looks like my dfplayer mini dosent get detected by my code of arduino
This is just a test code cuz i plan to change that
Oh ok bro i will try to do it later and see lets hope nothing is wrong in the wiring or stuff idk.Btw i have the power supply but im not using it i think do i need any wiring there or no?
Did you correct the wrong Rx/Tx pins shown in your photo? The TX pin of the Nano, pin 11, should be connected (via a 1k resistor as advised several times) to the RX pin of the DFR module (next to the 5V pin).
No no i meant to do the work later​ cuz i wasnt home and was so busy these days.I will try tomorrow i think and let you guys know.I will try to find a resistor too.
Do you also have a battery pack or some sort of external power supply other than your computer’s USB port? The DFPlayer is a bit of a power hog, so it would be best if it had its own power supply and a smoothing capacitor of at least 10uf. Just make sure the grounds are connected between the arduino and the DFPlayer, otherwise you may have unpredictable behavior.
I use a charger into the power supply if you look closely to the power suply there is a black charger hole there.But i plan to change the power suply maybe instead of the charger maybe get a 3 battery 1.5V each if that works?
