Using two servos but only one will work??
I am trying to get the basics of using a servo. I have done the single servo examples and they all work fine. I tried writing some sketches to use two servos but only one would ever work.
This is simple 2 servo sketch I got online. Which ever servo is assigned a pin first works, but not the second servo assigned. Same results on any pin I try.
I also tried the softwareservo library and some examples that use the SoftwareServo::refresh(); statement to keep multiple servo ports refreshed but I keep getting a error.
Here is the sample sketch.
#include <Servo.h>
Servo myservo;
Servo mysecondservo;
myservo.attach(3); // attaches a servo connected to pin 3
mysecondservo.attach(15); // attaches a servo connected to pin 15
myservo.write(180); // sets the servo position at 180 degrees
mysecondservo.write(65); // sets the servo position at 65 degrees
Any help would be appreciated.
What Arduino are you using?
...R
Simple servo test code for two servos. Note that servos need e3xternal power supplies.
//zoomkat 10-09-14 serial servo test
//type servo position 0 to 180 in serial monitor
//opposite side servos rotate together
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo1;  // create servo object to control a servo
Servo myservo2;
  myservo1.attach(8);
  myservo2.attach(9);
  Serial.println("servo-test"); // so I can keep track of what is loaded
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the String readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    Serial.println(readString);  //so you can see the captured String
    int n = readString.toInt();  //convert readString into a number
    myservo1.write(n);
    myservo2.write(180-n); //turns opposide servo in desired direction
    readString="";
I am using Arduino nano and I am powering the servos with a external supply.
Zoomkat--
I just tried your code and it mostly worked. The two servos moved but had a lot of jitter. They are MKS high voltage servos I took out of a plane because of the jitter. I will try two simple 9 gram servos and see what happens.
Thanks!
I tried two 9 gram analog servos and they worked fine.
Thanks for the help!
I still don't understand why in my sketch only the first servo assigned to a pin works????
My standard arduino does not indicate a pin 15, so what is that equivalent to on a standard arduino?
I didn't really pay attention in that sketch that it was pin 15. When I actually compiled the sketches I always tried pins 7 thru 10.
I just tried this sketch from you and it now also works with analog servos.
// Powering a servo from the arduino usually DOES NOT WORK.
String readString;
#include <Servo.h>
Servo myservo2;
myservo1.attach(7);
myservo2.attach(9);
myservo1.write(n);
readString="";
Do you have a link to your high voltage servos? Are you supplying the recommended voltage? Also Please read #7 below concerning posting code.:
http://forum.arduino.cc/index.php/topic,148850.0.html
http://www.mksservosusa.com/product.php?productid=145&cat=&page=3
They do have a operating frequency above 50hz.
I took them out of a giant scale plane and replaced them with Hitec servos. Looks like the next place they will get mounted is on a swap meet table.
Operating Voltage 6.0 ~7.4 V DC Volts
Those are large servos, so most likely you may have a power supply issue.
I was using a 2s lipo for the MKS servos. I think they are just crappy servos. That's why I took them out of my plane.
Here is video of my plane before and after I changed the servos.
