I'm attempting to use two Adafruit VL6180X sensors to set up a fixture that tracks and records the motion of two actuators. I've got a code for the two range sensors that without the actuators work amazingly, and without using the range sensors the relays drive the actuators fine. But whenever I attempt to combine the two codes the range sensor does not give me continuous data while the relays are actuating. essentially only giving me one range data point at the beginning of the actuation cycle. I've tried both "delay" and "millis" functions to try to have the range sensor loop keep running and kick off the actuator at a predisposed interval but it seems like no matter what the range sensors only loop with the actuator. Is there anyway to use one arduino to control a relay and continuously plot data from range sensors?
This is the code for two sensors by themselves:
#include <Adafruit_VL6180X.h>
// address we will assign if dual sensor is present
#define LOX1_ADDRESS 0x30
#define LOX2_ADDRESS 0x31
// set the pins to shutdown
#define SHT_LOX1 47
#define SHT_LOX2 46
// Optional define GPIO pins to check to see if complete
#define GPIO_LOX1 4
#define GPIO_LOX2 3
#define TIMING_PIN 13
// objects for the VL6180X
Adafruit_VL6180X lox1 = Adafruit_VL6180X();
Adafruit_VL6180X lox2 = Adafruit_VL6180X();
// Setup mode for doing reads
typedef enum {RUN_MODE_DEFAULT, RUN_MODE_TIMED, RUN_MODE_ASYNC, RUN_MODE_GPIO, RUN_MODE_CONT} runmode_t;
runmode_t run_mode = RUN_MODE_DEFAULT;
uint8_t show_command_list = 1;
// Define some globals used in the continuous range mode
// Note: going to start table drive this part, may back up and do the rest later
Adafruit_VL6180X *sensors[] = {&lox1, &lox2,};
const uint8_t COUNT_SENSORS = sizeof(sensors) / sizeof(sensors[0]);
const int sensor_gpios[COUNT_SENSORS] = {GPIO_LOX1, GPIO_LOX2,}; // if any are < 0 will poll instead
uint8_t         sensor_ranges[COUNT_SENSORS];
uint8_t         sensor_status[COUNT_SENSORS];
// Could do with uint8_t for 8 sensors, but just in case...
const uint16_t  ALL_SENSORS_PENDING = ((1 << COUNT_SENSORS) - 1);
uint16_t        sensors_pending = ALL_SENSORS_PENDING;
uint32_t        sensor_last_cycle_time;
    Reset all sensors by setting all of their XSHUT pins low for delay(10), then set all XSHUT high to bring out of reset
    Keep sensor #1 awake by keeping XSHUT pin high
    Put all other sensors into shutdown by pulling XSHUT pins low
    Initialize sensor #1 with lox.begin(new_i2c_address) Pick any number but 0x29 and it must be under 0x7F. Going with 0x30 to 0x3F is probably OK.
    Keep sensor #1 awake, and now bring sensor #2 out of reset by setting its XSHUT pin high.
    Initialize sensor #2 with lox.begin(new_i2c_address) Pick any number but 0x29 and whatever you set the first sensor to
void setID() {
  // all reset
  digitalWrite(SHT_LOX1, LOW);
  digitalWrite(SHT_LOX2, LOW);
  delay(10);
  // all unreset
  digitalWrite(SHT_LOX1, HIGH);
  digitalWrite(SHT_LOX2, HIGH);
  delay(10);
  // activating LOX1 and reseting LOX2
  // initing LOX1
  if (!lox1.begin()) {
    Serial.println(F("Failed to boot first VL6180X"));
    while (1);
  lox1.setAddress(LOX1_ADDRESS);
  delay(10);
  // activating LOX2
  delay(10);
  //initing LOX2
  if (!lox2.begin()) {
    Serial.println(F("Failed to boot second VL6180X"));
    while (1);
  lox2.setAddress(LOX2_ADDRESS);
  // activating LOX3
  delay(10);
void readSensor(Adafruit_VL6180X &vl) {
  Serial.print(" Addr: ");
  Serial.print(vl.getAddress(), HEX);
  float lux = vl.readLux(VL6180X_ALS_GAIN_5);
  Serial.print(" Lux: "); Serial.print(lux);
  uint8_t range = vl.readRange();
  uint8_t status = vl.readRangeStatus();
  if (status == VL6180X_ERROR_NONE) {
    Serial.print(" Range: "); Serial.print(range);
  // Some error occurred, print it out!
  if  ((status >= VL6180X_ERROR_SYSERR_1) && (status <= VL6180X_ERROR_SYSERR_5)) {
    Serial.print("(System error)");
  else if (status == VL6180X_ERROR_ECEFAIL) {
    Serial.print("(ECE failure)");
  else if (status == VL6180X_ERROR_NOCONVERGE) {
    Serial.print("(No convergence)");
  else if (status == VL6180X_ERROR_RANGEIGNORE) {
    Serial.print("(Ignoring range)");
  else if (status == VL6180X_ERROR_SNR) {
    Serial.print("Signal/Noise error");
  else if (status == VL6180X_ERROR_RAWUFLOW) {
    Serial.print("Raw reading underflow");
  else if (status == VL6180X_ERROR_RAWOFLOW) {
    Serial.print("Raw reading overflow");
  else if (status == VL6180X_ERROR_RANGEUFLOW) {
    Serial.print("Range reading underflow");
  else if (status == VL6180X_ERROR_RANGEOFLOW) {
    Serial.print("Range reading overflow");
void read_sensors() {
  readSensor(lox1);
  readSensor(lox2);
void timed_read_sensors() {
  digitalWrite(TIMING_PIN, HIGH);
  uint32_t start_time = millis();
  uint8_t range_lox1 = lox1.readRange();
  uint8_t status_lox1 = lox1.readRangeStatus();
  uint8_t range_lox2 = lox2.readRange();
  uint8_t status_lox2 = lox2.readRangeStatus();
  uint32_t delta_time = millis() - start_time;
  digitalWrite(TIMING_PIN, LOW);
  Serial.print(delta_time, DEC);
  Serial.print(" : ");
  if (status_lox1 == VL6180X_ERROR_NONE) Serial.print(range_lox1, DEC);
  else Serial.print("###");
  if (status_lox2 == VL6180X_ERROR_NONE) Serial.print(range_lox2, DEC);
void timed_async_read_sensors() {
  // lets start up all three
  lox1.startRange();
  lox2.startRange();
  // wait for each of them to complete
  lox1.waitRangeComplete();
  lox2.waitRangeComplete();
  uint8_t range_lox1 = lox1.readRangeResult();
  uint8_t range_lox2 = lox2.readRangeResult();
void timed_async_read_gpio() {
#ifdef GPIO_LOX1
  uint8_t range_lox1 = 0;
  uint8_t status_lox1 = VL6180X_ERROR_NONE;
  uint8_t range_lox2 = 0;
  uint8_t status_lox2 = VL6180X_ERROR_NONE;
  uint8_t range_lox3 = 0;
  uint8_t status_lox3 = VL6180X_ERROR_NONE;
  uint8_t pending_sensors = 0x7;
  lox1.startRange();
  lox2.startRange();
  while (pending_sensors && ((millis() - start_time) < 10000)) {
    if ((pending_sensors & 0x1) && !digitalRead(GPIO_LOX1)) {
      pending_sensors ^= 0x1;
    if ((pending_sensors & 0x2) && !digitalRead(GPIO_LOX2)) {
      pending_sensors ^= 0x2;
  Serial.print("(");
  Serial.print(pending_sensors, DEC);
  Serial.print(") : ");
  if (status_lox3 == VL6180X_ERROR_NONE) Serial.print(range_lox3, DEC);
#endif
// Continuous range test code
void start_continuous_range() {
  Serial.println("start Continuous range mode");
  for (uint8_t i = 0; i < COUNT_SENSORS; i++) {
    sensors[i]->startRangeContinuous();
  sensor_last_cycle_time = millis();
void stop_continuous_range() {
  Serial.println("Stop Continuous range mode");
    sensors[i]->stopRangeContinuous();
  delay(100); // give time for it to complete.
void Process_continuous_range() {
  uint16_t mask = 1;
    bool range_complete = false;
    if (sensors_pending & mask) {
      if (sensor_gpios[i] >= 0)
        range_complete = !digitalRead(sensor_gpios[i]);
        range_complete = sensors[i]->isRangeComplete();
      if (range_complete) {
        sensor_ranges[i] = sensors[i]->readRangeResult();
        sensor_status[i] = sensors[i]->readRangeStatus();
        sensors_pending ^= mask;
    mask <<= 1; // setup to test next one
  // See if we have all of our sensors read OK
  uint32_t delta_time = millis() - sensor_last_cycle_time;
  if (!sensors_pending || (delta_time > 100)) {
    Serial.print("(");
    Serial.print(sensors_pending, HEX);
    Serial.print(")");
    mask = 1;
      if (sensors_pending & mask) Serial.print("TTT");  // show timeout in this one
      else if (sensor_status[i] == VL6180X_ERROR_NONE) Serial.print(sensor_ranges[i], DEC);
      else {
        Serial.print("#");
        Serial.print(sensor_status[i], DEC);
    // setup for next pass
// Setup
  // wait until serial port opens for native USB devices
  while (! Serial) {
    delay(1);
  pinMode(SHT_LOX1, OUTPUT);
  pinMode(SHT_LOX2, OUTPUT);
  // Enable timing pin so easy to see when pass starts and ends
  pinMode(TIMING_PIN, OUTPUT);
#ifdef GPIO_LOX1
  // If we defined GPIO pins, enable them as PULL UP
  pinMode(GPIO_LOX1, INPUT_PULLUP);
  pinMode(GPIO_LOX2, INPUT_PULLUP);
#endif
  Serial.println("Shutdown pins inited...");
  Serial.println("All in reset mode...(pins are low)");
  Serial.println("Starting...");
  setID();
// Loop
  if (Serial.available()) {
    uint8_t ch = Serial.read();
    while (Serial.read() != -1) ; // remove the rest
    runmode_t prev_run_mode = run_mode;
    // See what the user typed in
    switch (ch) {
      case 'd':
      case 'D':
      case 't':
      case 'T':
        run_mode = RUN_MODE_TIMED;
      case 'a':
      case 'A':
        run_mode = RUN_MODE_ASYNC;
#ifdef GPIO_LOX1
      case 'g':
      case 'G':
        run_mode = RUN_MODE_GPIO;
#endif
      case 'c':
      case 'C':
        run_mode = RUN_MODE_CONT;
      default:
    if (run_mode != prev_run_mode) {
      // if previous mode was continuous mode, shut it down
      if (prev_run_mode == RUN_MODE_CONT) stop_continuous_range();
      if (run_mode == RUN_MODE_CONT) start_continuous_range();
  if (show_command_list) {
    Serial.println("\nSet run mode by entering one of the following letters");
    Serial.println("    D - Default mode");
    Serial.println("    T - Timed mode - Reads done one after another");
    Serial.println("    A - Asynchronous mode - Try starting all three at once");
#ifdef GPIO_LOX1
    Serial.println("    G - Asynchronous mode - Like above use GPIO pins");
#endif
    Serial.println("    C - Continuous mode - Try starting all three at once");
    show_command_list = 0;
  switch (run_mode) {
    case RUN_MODE_DEFAULT:
      read_sensors();
    case RUN_MODE_TIMED:
      timed_read_sensors();
    case RUN_MODE_ASYNC:
      timed_async_read_sensors();
    case RUN_MODE_GPIO:
      timed_async_read_gpio();
    case RUN_MODE_CONT:
      Process_continuous_range();
  delay(100);
Code for the relays:
