Using web serial as serial monitor
#include <Servo.h>
// setup servo
int servoPin = D4;
int PEN_DOWN = 90; // angle of servo when pen is down
int PEN_UP = 30;   // angle of servo when pen is up
Servo penServo;
float wheel_dia=65.9; //    # mm (increase = spiral out)
float wheel_base=115; //    # mm (increase = spiral in, ccw)
int steps_rev=512; //        # 512 for 64x gearbox, 128 for 16x gearbox
int delay_time=6; //         # time between steps in ms
// Stepper sequence org->pink->blue->yel
int L_stepper_pins[] = {D7, D5, D6, D8};
int R_stepper_pins[] = {D3, D1, D0, D2};
int fwd_mask[][4] =  {{1, 0, 1, 0},
                      {0, 1, 1, 0},
                      {0, 1, 0, 1},
                      {1, 0, 0, 1}};
int rev_mask[][4] =  {{1, 0, 0, 1},
                      {0, 1, 0, 1},
                      {0, 1, 1, 0},
                      {1, 0, 1, 0}};
  randomSeed(analogRead(1));
  for(int pin=0; pin<4; pin++){
    pinMode(L_stepper_pins[pin], OUTPUT);
    digitalWrite(L_stepper_pins[pin], LOW);
    pinMode(R_stepper_pins[pin], OUTPUT);
    digitalWrite(R_stepper_pins[pin], LOW);
  penServo.attach(servoPin);
  Serial.println("setup");
  penup();
void loop(){
 Serial.println("Enter your name or sequence of letters:");
  while (!Serial.available()) {
  // Read user input from Serial Monitor
  String userInput = Serial.readStringUntil('\n');
  pendown();
  Serial.print("Drawing in progress...");
  drawName(userInput);
  Serial.print("Drawing completed!!!");
  // Optional delay between drawings
// ----- HELPER FUNCTIONS -----------
int step(float distance){
  int steps = distance * steps_rev / (wheel_dia * 3.1412); //24.61
  Serial.println("Drawing in progress");
  return steps;
float getNearestAngle(float angle_){
float angle = 0;
int step = 0;
float previousAngle = 0;
float step_length = 3.1412 * wheel_dia / steps_rev;
while(!(previousAngle <= angle_ && angle_ <= angle)){
step += 1;
previousAngle = angle;
angle = step * step_length * 360 / (wheel_base * 3.1412) + 0.01;
float dif1 = angle_- angle;
float dif2 = angle_- previousAngle;
if(abs(dif1) < abs(dif2)){
return angle;
}else{
return previousAngle;
void forward(float distance){
  int steps = step(distance);
  for(int step=0; step<steps; step++){
    for(int mask=0; mask<4; mask++){
        digitalWrite(L_stepper_pins[pin], rev_mask[mask][pin]);
        digitalWrite(R_stepper_pins[pin], fwd_mask[mask][pin]);
      delay(delay_time);
void backward(float distance){
        digitalWrite(L_stepper_pins[pin], fwd_mask[mask][pin]);
        digitalWrite(R_stepper_pins[pin], rev_mask[mask][pin]);
      delay(delay_time);
void right(float degrees){
  float rotation = getNearestAngle(degrees) / 360.0;
  float distance = wheel_base * 3.1412 * rotation;
      delay(delay_time);
void left(float degrees){
      delay(delay_time);
void done(){ // unlock stepper to save battery
    delay(delay_time);
void penup(){
  delay(250);
  Serial.println("PEN_UP()");
  penServo.write(PEN_UP);
  delay(250);
void pendown(){
  delay(250);
  Serial.println("PEN_DOWN()");
  penServo.write(PEN_DOWN);
  delay(250);
void A(){
  left(70);
  forward(110);
  left(40);
  backward(110);
  forward(50);
  left(67);
  forward(42);
  penup();
  left(150);
  forward(93);
  left(33);
  pendown();
void B(){
  left(90);
  forward(110);
  right(70);
  int a = 1;
  int b = 1;
  while (a<=140) {
      forward(1);
      right(1.82);
      a++;
  left(45);
  while (b<=150) {
      backward(1);
      right(1.7);
      b++;
  penup();
  left(35);
  forward(60);
  pendown();
void c(){
  penup();
  forward(70);
  right(5);
  pendown();
  int a = 1;
  while (a<=230) {
      backward(1.2);
      right(1);
      a++;
  penup();
  right(50);
  backward(120);
  right(125);
  pendown();
void d(){
  left(90);
  forward(110);
  right(70);
  int a = 1;
  while (a<=270) {
      forward(1.2);
      right(1);
      a++;
  penup();
  right(170);
  forward(105);
  pendown();
void e(){
    forward(50);
    penup();
    backward(50);
    pendown();
    left(90);
    forward(55);
    right(90);
    forward(50);
    penup();
    backward(50);
    left(90);
    pendown();
    forward(55);
    right(90);
    forward(50);
    penup();
    right(75);
    forward(114);
    left(75);
    pendown();
void f(){
  left(90);
  forward(55);
  right(90);
  forward(50);
  penup();
  backward(50);
  left(90);
  pendown();
  forward(55);
  right(90);
  forward(50);
  penup();
  right(75);
  forward(114);
  left(75);
  pendown();
void g(){
  penup();
  forward(70);
  pendown();
  left(90);
  forward(45);
  left(90);
  forward(30);
  penup();
  backward(30);
  right(90);
  backward(45);
  pendown();
  right(65);
  int a = 1;
  while (a<=275){
      backward(1.2);
      right(1);
      a++;
  penup();
  right(50);
  backward(120);
  right(115);
  pendown();
void h(){
  left(90);
  forward(110);
  penup();
  backward(55);
  right(90);
  pendown();
  forward(50);
  penup();
  left(90);
  forward(55);
  pendown();
  backward(110);
  penup();
  right(90);
  forward(30);
  pendown();
void I(){
  left(90);
  forward(110);
  penup();
  right(165);
  forward(115);
  left(75);
  pendown();
void j(){
  penup();
  left(90);
  forward(30);
  pendown();
  int a = 1;
  while (a <= 90) {
      left(2);
      backward(1);
      a++;
  backward(80);
  penup();
  left(10);
  forward(108);
  left(80);
  pendown();
void k(){
  left(90);
  forward(110);
  penup();
  backward(55);
  right(45);
  pendown();
  forward(75);
  penup();
  backward(75);
  right(90);
  pendown();
  forward(75);
  penup();
  left(45);
  forward(30);
  pendown();
void l(){
  penup();
  left(90);
  forward(110);
  pendown();
  backward(110);
  penup();
  right(90);
  pendown();
  forward(55);
  penup();
  forward(30);
  pendown();
void m(){
  left(90);
  forward(110);
  right(150);
  forward(55);
  left(120);
  forward(55);
  left(30);
  backward(110);
  right(90);
  penup();
  forward(30);
  pendown();
void n(){
  left(90);
  forward(110);
  left(35);
  backward(130);
  right(35);
  forward(110);
  penup();
  backward(110);
  right(90);
  forward(30);
  pendown();
void o(){
  penup();
  left(90);
  forward(80);
  pendown();
  backward(60);
  int a = 1;
  while (a <= 90){
      backward(1);
      left(2);
      a++;
  backward(60);
  int b = 1;
  while (b <= 90){
      backward(1);
      left(2);
      b++;
  penup();
  right(135);
  forward(110);
  left(53);
  pendown();
void p(){
  left(90);
  forward(110);
  right(70);
  int a = 1;
  while (a<=120) {
      forward(1);
      right(2);
      a++;
  penup();
  left(150);
  forward(70);
  left(70);
  forward(30);
  pendown();
void q(){
  penup();
  left(90);
  forward(80);
  pendown();
  backward(60);
  int a = 1;
  while (a <= 90) {
      backward(1);
      left(2);
      a++;
  backward(60);
  int b = 1;
  while (b <= 90) {
      backward(1);
      left(2);
      b++;
  penup();
  right(155);
  forward(55);
  pendown();
  forward(60);
  penup();
  left(145);
  forward(20);
  right(80);
  forward(25);
  pendown();
void r(){
  left(90);
  forward(110);
  right(70);
  int a = 1;
  while (a<=120) {
      forward(1);
      right(2);
      a++;
  left(150);
  forward(70);
  penup();
  left(70);
  forward(30);
  pendown();
void s(){
  penup();
  left(90);
  forward(20);
  pendown();
  int a = 1;
  while (a<=120) {
      left(2.2);
      backward(1);
      a++;
  backward(30);
  int b = 1;
  while (b<=120) {
      backward(1);
      right(2.2);
      b++;
  penup();
  backward(85);
  right(90);
  forward(30);
  pendown();
void t(){
  penup();
  forward(40);
  left(90);
  pendown();
  forward(110);
  penup();
  left(90);
  forward(40);
  pendown();
  backward(80);
  penup();
  right(90);
  backward(110);
  right(90);
  forward(30);
  pendown();
void u(){
  penup();
  left(90);
  forward(110);
  pendown();
  backward(80);
  int a = 1;
  while (a <= 90) {
      backward(1);
      left(2);
      a++;
  backward(80);
  penup();
  left(10);
  forward(108);
  left(80);
  pendown();
void v(){
  penup();
  left(90);
  forward(110);
  left(20);
  pendown();
  backward(117);
  right(35);
  forward(117);
  penup();
  left(20);
  backward(110);
  right(90);
  forward(30);
  pendown();
void w(){
  penup();
  left(90);
  forward(110);
  left(10);
  pendown();
  backward(117);
  right(25);
  forward(60);
  penup();
  left(30);
  pendown();
  backward(60);
  right(25);
  forward(117);
  penup();
  left(10);
  backward(110);
  right(90);
  forward(30);
  pendown();
void x(){
  left(75);
  forward(114);
  penup();
  left(105);
  forward(30);
  right(75);
  pendown();
  backward(114);
  penup();
  right(105);
  forward(30);
  pendown();
void y(){
  left(75);
  forward(114);
  penup();
  left(105);
  forward(30);
  right(75);
  pendown();
  backward(57);
  penup();
  backward(57);
  right(105);
  forward(30);
  pendown();
void z(){
  penup();
  forward(80);
  pendown();
  backward(80);
  left(54);
  forward(136);
  right(54);
  backward(80);
  penup();
  right(54);
  forward(136);
  left(54);
  forward(30);
  pendown();
void circle(){
  int a = 1;
  while (a<=449) {
    forward(1);
    right(1);
    a++;
void space(){
  penup();
  forward(60);
  pendown();
void drawName(String name) {
  for (int i = 0; i < name.length(); i++) {
    char letter = tolower(name[i]);
    switch (letter) {
    case 'a':
        A();
    case 'b':
        B();
    case 'c':
        c();
    case 'd':
        d();
    case 'e':
        e();
    case 'f':
        f();
    case 'g':
        g();
    case 'h':
        h();
    case 'i':
        I();
    case 'j':
        j();
    case 'k':
        k();
    case 'l':
        l();
    case 'm':
        m();
    case 'n':
        n();
    case 'o':
        o();
    case 'p':
        p();
    case 'q':
        q();
    case 'r':
        r();
    case 's':
        s();
    case 't':
        t();
    case 'u':
        u();
    case 'v':
        v();
    case 'w':
        w();
    case 'x':
        x();
    case 'y':
        y();
    case 'z':
        z();
    case ' ':
        space();
    default:
       Serial.println("Error! Please enter alphabets only.");
    delay(500);  // Optional delay between letters
Hello Everyone!
Actually I was working on a project which can write letters.
Everything is done but the problem is that I want to access serial monitor through wifi so that I can input letters wirelessly. For this I want to use web serial but I don't know how to do this. I am using ESP8266 for the same. Kindly help, we are just 14 years and have started these things recently so we don't know much and hence I request you to kindly help us.
Hi @hellenic_87
weclome to the arduino-forum.
Well done posting your code as a code-section in your very first posting.
google is ALWAYS worth a 5 minutes search
Have you at least done a search for
"Arduino Webserial" ?
or
"ESP8266 Webserial" ?
Please do not post your question inside code tags; I've fixed your post.
Do you have a link to web serial; not everybody knows what it is.
we are constantly searching for it but the task is not executing correctly.
go to the google website and type
arduino webserial
it is that easy
OK. As you wrote that you are only 14 years old. I will post some more help.
This help will teach you fishing. This help will not serve ready to eat fish.
Even if you want help you will have to describe with much more precision what you really want.
I will write an example that changes roles. I am asking for help in an everyday situation and you are my (potential) helper
I ask "Can you do me a favor?"
You: 100% sure you will ask back "what kind of thing do you need help with?"
me: "help me do my favor thing"
You: what is your favorite thing?
me: "cooking"
you: "what do you want to cook?"
me: "a cake"
you: "well you do not "cook" a cake you bake it
"what kind of cake?"
me: "my favorite one"
you: what is your favorite cake?
I think you got the picture now
I'm pretty sure that you agree and will follow the way how to solve your problem mimimum 200 minutes faster.
This requires to invest 20 minutes of your precious time to read how to speedup solving your problems.
Directly after registering you got presented informations how to speed up solving your problem.
You should really read it.
best regards Stefan
what about the examples here
