Hello,
I'm brand new to Arduino and stepper motors, so this could very well be me over looking something obvious.
I'm using the uStepper32 with a NEMA23 motor to drive a linear actuator. The total displacement is 388mm and I've measured 1mm of displacement equates to 45deg of rotation from the motor.
I'm using the moveToEnd function to have the motor drive the actuator all the way to one end (until it detects a stall) then all the way to the other (so it covers the full 388mm travel). Then return the "Degrees turned from calling the function, till end was reached", however this is coming back over the serial port at "0.43" ?
I was expecting a value closer to 17460 degree (388 * 45), so this is way off?
Any help here appreciated, links to the relevant places below:
Function: uStepperS32/src/UstepperS32.h at master · uStepper/uStepperS32 · GitHub
uStepper32 data sheet: https://ooznest.co.uk/wp-content/uploads/2023/02/uStepper-S32-Product-Sheet-Feb-22.pdf
Code:
* File: limitDetection.ino *
* Version: 2.3.0 *
* Date: October 7th, 2023 *
* Author: Thomas Hørring Olsen *
* Description: Limit Detection Example Sketch! *
* This example demonstrates how the library can be used to detect hard *
* limits in an application, without the use of mechanical endstop switches. *
* Stallguard is very sensitive and provides seamless stall detection when *
* tuned for the application. It is dependent on speed, current setting *
* and load conditions amongst others. The encoder stall detection is *
* unaffected by most of these but can be a bit less sensitive. *
* For more information, check out the documentation: *
* http://ustepper.com/docs/usteppers/html/index.html *
* Note.......: Place the stepper motor on a solid surface where it cannot harm anyone *
* during the test. *
* (C) 2023 *
* uStepper ApS *
* www.ustepper.com *
* administration@ustepper.com *
* The code contained in this file is released under the following open source license: *
* Creative Commons Attribution-NonCommercial-ShareAlike 4.0 International *
* The code in this file is provided without warranty of any kind - use at own risk! *
* neither uStepper ApS nor the author, can be held responsible for any damage *
* caused by the use of the code contained in this file ! *
#include <UstepperS32.h>
UstepperS32 stepper;
#define STEPSPERREV 200 //Number of steps pr revolution. 200 for a 1.8deg motor, 400 for a 0.9deg motor
#define RES (STEPSPERREV *256)/360.0//calculate microstep pr. degree
#define STEPPRMM 25//full step pr. mm for the rail used in the demo
#define MMPRSTEP 1/(STEPPRMM*256)//mm pr. microstep
#define MMPRDEG MMPRSTEP*RES//mm pr. degree
#define STALLSENSITIVITY 2//sensitivity of the stall detection, between -64 and 63 - higher number is less sensitive
// Desired rpm for homing
int16_t rpm = 50;
void setup(){
stepper.setup(NORMAL, STEPSPERREV); //Initialize uStepper S32
stepper.checkOrientation(30.0); //Check orientation of motor connector with +/- 30 microsteps movement
stepper.setMaxAcceleration(2000); //Use an acceleration of 2000 fullsteps/s^2
stepper.setMaxVelocity(500); //Max velocity of 500 fullsteps/s
stepper.setCurrent(75);
float railLength;
float cwDirAngle;
float ccwDirAngle;
cwDirAngle = stepper.moveToEnd(CW, rpm, STALLSENSITIVITY); //Reset to CW endpoint
Serial.println(cwDirAngle);
//Serial.println(railLength*MMPRDEG);//find end positions and read out the recorded end position
ccwDirAngle = stepper.moveToEnd(CCW, rpm, STALLSENSITIVITY); //Go to CCW end
Serial.println(ccwDirAngle);
while(1);
The moveToEnd function is defined as follows:
float UstepperS32::moveToEnd(bool dir, float rpm, int8_t threshold, uint32_t timeOut)
uint32_t timeOutStart = micros();
// Lowest reliable speed for stallguard
if (rpm < 10.0)
rpm = 10.0;
if (dir == CW)
this->setRPM(abs(rpm));
this->setRPM(-abs(rpm));
delay(100);
this->isStalled();
// Enable stallguard to detect hardware stop (use driver directly, as to not override user stall settings)
ptr->driver.enableStallguard(threshold, true, rpm);
float length = this->encoder.getAngleMoved();
while (!this->isStalled())
delay(1);
if ((micros() - timeOutStart) > (timeOut * 1000))
break; // TimeOut !! break out and exit
this->stop();
ptr->driver.clearStall();
// Return to normal operation
ptr->driver.disableStallguard();
length -= this->encoder.getAngleMoved();
return abs(length);
