@Daryl,
It is great you want to help, and having watched your video it seems apparent you fixed the UTFT problem by accident rather than any real understanding of the library system. If you did understand the library system your touch library would be working fine too!!
Ok, try this.....
Locate your sketch folder, I can only comment on XP as I am still in the dark (reliable) ages, but it should be in
My Documents\Arduino.
To complicate things further I re-located my sketch library to flash drive.....My sketches AND libraries can now travel!! ;)
So once you located your 'Arduino' folder.......inside is a 'libraries' folder......... The clue is in the name??? Place UTFT, UTFT_Buttons, UTouch and UTFT_tinyFAT in the libraries folder.
ALL your library files should be placed here!!
Once you have copied your new libraries, you MUST restart the arduino software......... I am mystified why you talk about signing in as a new user and uninstalling and re-installing the software?? Maybe you have too much time on your hands?
Case solved..... Ignore Daryls video, he waffles and rambles for about 5 minutes and the end result is less than useful.......
I especially like Daryls comment about.......i did this and I am not going to do it again, but you like click open and it does the rest?? That will be super helpful to other newbies having this problem!!! Particularly given his own admission he didn't figure out how to get touch working yet!!!???
Furthermore, done the way I have outlined, no further changes needed, you can run Arduino 1.0.5 1.5.3 1.5.4 nightly or any other version you might like..... And all sketches work fine......
Another seemingly important fact our Daryl appears to have overlooked, is that not only does UTFT appear black when not installed correctly, I am quite sure EXAMPLES does not contain anything related to UTFT? Since the library contains the examples??
I am a big fan of Hennings suite of libraries, he has done a sterling job, and I was one of those users that had problems with a MEGA2560, but at least I did install them in the correct location before saying lots of people have had problems!!! I would just like to say finally, comments like that may put off new users from potentially the best TFT related libraries out there, which is a pity when it is so apparent the commentee knows so little.
Regards,
Fellow 'newbie' (recently upgraded :P)
Graham
PS Daryl.....Please don't make another video of comparable standard to your last one..... just follow my instructions..... ;)
