I have a problem and I wish to draw upon the collective genius of Arduino Forums...
I want to make a vacuum regulating device. Basically, I would program in some cycles (what vacuum, how long, repeat how many times) etc into an arduino that would then control a solenoid valve located in-line with the vacuum line. When I'm drawing a vacuum in the chamber, I'd apple a current to the normally-closed solenoid and allow the vacuum pump to suck the air out of the chamber. When I need to hold the vacuum, I'd simply stop applying current and let the solenoid valve close. When I need to release vacuum, I'd just use a vent valve on the chamber. Seems straight-forward enough... I realize that they need a lot of current, so I'd be using an external power source (most likely wall).
Right now, I'm thinking of using a MAP (manifold air pressure) sensor from an old vehicle for the vacuum sensor (so that I can detect when to switch the solenoid on or off). I need recommendations for vacuum solenoid valves that can take up to -28 inch of Hg. Also, are there any differences between solenoid valves and vacuum solenoid valves? Just because a solenoid is rated for 0~+X pressure shouldn't mean that it can't handle negative pressure...?
Cost is an issue and I'm hoping to keep the solenoid in the early~mid double digits if possible.
The control logic sounds pretty straight-forward. I'd say the most complicated part is the user interface.
Do you have any idea what sort of signal you get out of the MAP sensor?
I don't know, but I'd assume you can install it backwards (I don't know if there's even a "direction") on an air/gas solenoid. And I would expect just about any air solenoid would work, since one atmosphere is low compared to most compressed-air systems.
If you use a 120V or 240V solenoid, you need to isolate the arduino from the high voltage. That means a relay, or an opto-isolator with a TRIAC. The simplest solution would be a solid-state relay, but that's usually not the cheapest way. If you can find a 12V or 24V solenoid, you'll need something to boost the voltage & current (a MOSFET or relay, etc.) but you don't need the isolation.
The MAP sensor outputs a voltage that I'll probably have to map/linearize around the pressure region of interest. I'm hoping it will be straightforward.
I've never heard of/used an opto-isolator or a TRIAC (been googling them over lunch). Do you have any good reference material/examples of these? I'm more familiar with diodes/relays. It'd be nice to experiment around and learn more during this project.
Thanks a lot for the input!
DVDdoug:
Having worked in a oil refinery before retirement, I bought and installed lots of solenoid valves for lots of different applications and learned early on that you should never assume anything about the proper application of a specific solenoid valve in a specific service. If it's not stated explicitly in it's datasheet, then call a manufactures rep (beware sales vendors, they want to sell and don't always grok the tek) and ask, I always found them helpful if I couldn't find the information I needed in a datasheet.
