Variable for Descriptor
This involves an ESP32-WROOM-32d.
Trying to write a single set of Serial Read/Writes that can be used for either a Bluetooth or hardware Serial connection after whichever is tested to exist.
Don't want to write duplicate code, one using "Serial.println;" and another "SerialBT.println;"...
Is there a way to make a variable to call whichever Serial connection exists, which can then be used in a single set of serial read/writes???
"serialvariable.println;" My first thought was an array, but can't seem to get it working.
//This example code is in the Public Domain (or CC0 licensed, at your option.)
//By Evandro Copercini - 2018
//This example creates a bridge between Serial and Classical Bluetooth (SPP)
//and also demonstrate that SerialBT have the same functionalities of a normal Serial
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
BluetoothSerial SerialBT;
//int SerVar[] = {Serial, SerialBT};  //HOW TO DECLARE ARRAY OF THESE TWO COMMANDS ???
int SerNo;
  SerialBT.begin("ESP32test"); //Bluetooth device name
  Serial.println("The device started, now you can pair it with bluetooth!");
void loop() {                 //This WORKS but requires DUPLICATE code for each type of Serial connection.
  if (Serial.available()) {   //UART connection
    Serial.println("Test");
    delay(10);
  if (SerialBT.available()) { //Bluetooth Serial connection
    SerialBT.println("Test");
    delay(50);
void Loop_alternative() {     //This attempt is based on an array.
  if (SerialBT.available()) {   // Tests for Bluetooth Serial connection
    SerNo = 1;
  } else {                      // Uses UART if no Bluetooth Serial connection
    SerNo = 0;
  SerVar[SerNo].println("Test");  //BT Serial is priority and UART is secondary.
  //Add more universal Serial Read and Write coding for both UART and Bluetooth.
  //Duplicate code not necessary.
Serial is inherited from Stream class. If BluetoothSerial is also inherited from Stream class, you can make an array of Stream
Stream *serials[] = {&Serial, &SerialBT}
   serials[0]->begin(9600);
   serials[1]->begin(9600);
arduino_new:
arduino_new:
Thank you for responding. When I tried your recommendation it gave the error for both lines: "'class Stream' has no member named 'begin'" Any thoughts?
Hmm, Stream doesn't have begin().
Try this:
   SerialBT.begin("ESP32Test");
   //check serial buffer
   if (serials[0]->available()) {
      serials[0]->read();
   check Bluetooth buffer
   if (serials[1]->available()) {
      serials[1]->read();
This works without error... and something new for me. So thank you for that.
I do have a question about the "Stream *serials[] = {&Serial, &SerialBT};"
what does the '*" and "&" mean?
arduino_new:
No, because not all classes that inherit from Stream need one.
Bwanna:
Google search for tutorials on C / C++ pointers. Here's one.
After that comes Polymorphism which is the technique @arduino_new's code took advantage of.
gfvalvo:
Agree.
Update: Thank you for the guidance on this. The links are very interesting and something I'll continue to review. Here is the working code. It'll save a lot of duplication and allow me to connect via BT (phone) or direct UART (PC) when interfacing with the unit. This is why I enjoy this site. Great folks, great help!
#endif
int SerNo;
void loop () {
    SerNo = 1;
    SerNo = 0;
  serials[SerNo]->println("Test");  //BT Serial is priority and UART is secondary.
