Variables not declared in scope
I am very new to Arduino, and am trying to create code for a school project. I have outlined variables in future void code but I keep receiving messages that the generate_sequence, show_sequence and get_sequence are 'not declared in this scope'. Any idea how to fix this? this is the section of my code:
if (level == 1)
 generate_sequence(); //generate a sequence;
 if (digitalRead(A4) == LOW || level != 1) //If start button is pressed or you're winning
 show_sequence(); //show the sequence
 get_sequence(); //wait for your sequence
void show_sequence()
 digitalWrite(2, LOW);
 digitalWrite(3, LOW);
 digitalWrite(4, LOW);
 digitalWrite(5, LOW);
 for (int i = 0; i < level; i++)
   digitalWrite(sequence[i], HIGH);
   delay(velocity);
   digitalWrite(sequence[i], LOW);
   delay(200);
void get_sequence()
 int flag = 0; //this flag indicates if the sequence is correct
   flag = 0;
   while (flag == 0)
     if (digitalRead(A0) == LOW)
       digitalWrite(5, HIGH);
       your_sequence[i] = 5;
       flag = 1;
       delay(200);
       if (your_sequence[i] != sequence[i])
         wrong_sequence();
         return;
     if (digitalRead(A1) == LOW)
       digitalWrite(4, HIGH);
       your_sequence[i] = 4;
       flag = 1;
       delay(200);
         wrong_sequence();
         return;
     if (digitalRead(A2) == LOW)
       digitalWrite(3, HIGH);
       your_sequence[i] = 3;
       flag = 1;
       delay(200);
         wrong_sequence();
         return;
     if (digitalRead(A3) == LOW)
       digitalWrite(2, HIGH);
       your_sequence[i] = 2;
       flag = 1;
       delay(200);
         wrong_sequence();
         return;
 right_sequence();
void generate_sequence()
 randomSeed(millis()); //in this way is really random!!!
 for (int i = 0; i < MAX_LEVEL; i++)
   sequence[i] = random(2, 6);
check your brackets, as you can see (I indented the code you shared and used code tags) it seems there are many pairs of {} not matching
Don't post snippets (Snippets R Us!)
I can't really see where those would be. I'll attach my entire code if that's helpful. It's a code for simon says with a puzzle leading into a numbered password
#include <Keypad.h>
const int ROW_NUM = 4; //four rows
const int COLUMN_NUM = 3; //three columns
char keys[ROW_NUM][COLUMN_NUM] = {
  {'1', '2', '3'},
  {'4', '5', '6'},
  {'7', '8', '9'},
  {'*', '0', '#'}
byte pin_rows[ROW_NUM] = {13, 12, 11, 10};
byte pin_column[COLUMN_NUM] = {9, 8, 7};
Keypad keypad = Keypad( makeKeymap(keys), pin_rows, pin_column, ROW_NUM, COLUMN_NUM );
const String password = "2475";
String input_password;
const int MAX_LEVEL = 10;
int sequence[MAX_LEVEL];
int your_sequence[MAX_LEVEL];
int level = 1;
int velocity = 1000;
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  pinMode(A2, INPUT);
  pinMode(A3, INPUT);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  char key = keypad.getKey();
  if (key) {
    Serial.println(key);
    if (key == '*') {
      input_password = ""; // clear input password
    } else if (key == '#') {
      if (password == input_password) {
        delay(250);
        delay(250);
        delay(250);
      input_password += key; // append new character to input password string
  if (level == 1)
    delay(velocity);
    delay(200);
void get_sequence()
    flag = 0;
    while (flag == 0)
        flag = 1;
        delay(200);
          wrong_sequence();
          return;
        flag = 1;
        delay(200);
          wrong_sequence();
          return;
        flag = 1;
        delay(200);
          wrong_sequence();
          return;
        flag = 1;
        delay(200);
          wrong_sequence();
          return;
  right_sequence();
void wrong_sequence()
  for (int i = 0; i < 3; i++)
    delay(250);
    delay(250);
  level = 1;
  velocity = 1000;
void right_sequence()
  if (level == 3) {  //round 3 reward: number 2 (0010)
    delay(250);
  else if (level == 5) { //round 5 reward: number 4 (0100)
    delay(250);
  else if (level == 8) { //round 8 reward: number 7 (0111)
    delay(250);
  else if (level == 10) { //round 10 reward: number 5 (0101)
    delay(250);
  else {
    delay(250);
  if (level < MAX_LEVEL) {
    level++;
    level = 1;
    velocity = 1000;
  else {
  velocity -= 50; { //increase difficulty
This is part of it:
Then show_sequence has an extra closing brace.
