Variables Storage in eeprom
I am fairly new to Arduino programming and working on a project where I'm looking to store the variables in the eeprom so I can recall them after reboots. I'm trying to run it on a elegoo uno r3.
First I am uploading the variable structures via a put sketch (below)
  Used to first set up struct for eeprom storage
#include <EEPROM.h>
//User Changed Variables Structure
struct Stored_Variables {
  String Name;
  int Value;
Stored_Variables Number_Input = { "Number Input", 10 };
Stored_Variables Pistol_Default = { "Pistol Default", 26 };
Stored_Variables Rifle_Default = { "Rifle Default", 100 };
Stored_Variables Steps_Per_BB = { "Steps Per BB", 339 };
  //  Serial.begin(9600);
  //  Serial.println();
  while (!Serial) {
    ;  // wait for serial port to connect. Needed for native USB port only
  int eeAddress = 0;  //Location we want the data to be put.
  EEPROM.put(eeAddress, Number_Input);
  Serial.print("Written Number_Input data type! \n\nView the example sketch eeprom_get to see how you can retrieve the values!");
  eeAddress += sizeof(Number_Input);  //Move address to the next byte after float 'f'.
  EEPROM.put(eeAddress, Pistol_Default);
  Serial.print("Written Pistol_Default data type! \n\nView the example sketch eeprom_get to see how you can retrieve the values!");
  eeAddress += sizeof(Pistol_Default);  //Move address to the next byte after float 'f'.
  EEPROM.put(eeAddress, Rifle_Default);
  Serial.print("Written Rifle_Default data type! \n\nView the example sketch eeprom_get to see how you can retrieve the values!");
  eeAddress += sizeof(Rifle_Default);  //Move address to the next byte after float 'f'.
  EEPROM.put(eeAddress, Steps_Per_BB);
  Serial.print("Written Steps_Per_BB data type! \n\nView the example sketch eeprom_get to see how you can retrieve the values!");
Then when trying to read the values back it shows � for the first 2 character on strings and int values are wrong for 3rd and 4th variable. is there something I may have overlooked
Code for Get sketch below
    eeprom_get example.
    This shows how to use the EEPROM.get() method.
    To pre-set the EEPROM data, run the example sketch eeprom_put.
    This sketch will run without it, however, the values shown
    will be shown from what ever is already on the EEPROM.
    This may cause the serial object to print out a large string
    of garbage if there is no null character inside one of the strings
    loaded.
    Written by Christopher Andrews 2015
    Released under MIT licence.
#include <EEPROM.h>
  String Name;
  int Value;
  while (!Serial) {
  int eeAddress = 0;  //EEPROM address to start reading from
  Stored_Variables Number_Input;  //Variable to store custom object read from EEPROM.
  EEPROM.get(eeAddress, Number_Input);
  Serial.println("Read Number_Input from EEPROM: ");
  Serial.println(Number_Input.Name);
  Serial.println(Number_Input.Value);
  eeAddress = sizeof(Number_Input);  //Move address to the next byte after float 'f'.
  Stored_Variables Pistol_Default;  //Variable to store custom object read from EEPROM.
  EEPROM.get(eeAddress, Pistol_Default);
  Serial.println("Read Pistol_Default from EEPROM: ");
  Serial.println(Pistol_Default.Name);
  Serial.println(Pistol_Default.Value);
  eeAddress = sizeof(Pistol_Default);  //Move address to the next byte after float 'f'.
  Stored_Variables Rifle_Default;  //Variable to store custom object read from EEPROM.
  EEPROM.get(eeAddress, Rifle_Default);
  Serial.println("Read Rifle_Default.Name from EEPROM: ");
  Serial.println(Rifle_Default.Name);
  Serial.println(Rifle_Default.Value);
  eeAddress = sizeof(Rifle_Default);  //Move address to the next byte after float 'f'.
  Stored_Variables Steps_Per_BB;  //Variable to store custom object read from EEPROM.
  EEPROM.get(eeAddress, Steps_Per_BB);
  Serial.println("Read Steps_Per_BB from EEPROM: ");
  Serial.println(Steps_Per_BB.Name);
  Serial.println(Steps_Per_BB.Value);
  /* Empty loop */
Serial monitor output
�mber Input
10
�stol Default
26
�stol Default
26
�stol Default
26
The String class uses dynamically-allocated heap memory to store the actual characters. You can't save a String class variable to EEPROM this way. Make the struct entry a char array.
Thanks for your help changing String straight to char solved the problem
