Varialbe volatile long and Serial Monitor
When I run the code below and open and close the Serial Monitor. The _LeftEncoderTicks variable will become unpredictable. Sometimes it returns to zero, sometimes it stays the same and other times it will jump to a random number.
I am not stopping the code. Just opening and closing the Serial Monitor window. The funny thing is that when I start the Serial Monitor, it prints 0's and as soon as I move the encoder, it jumps to the higher different numbers.
*Quadrature Decoder
#include "Arduino.h"
#include <digitalWriteFast.h>  // library for high performance reads and writes by jrraines
                               // see http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1267553811/0
                               // and http://code.google.com/p/digitalwritefast/
// It turns out that the regular digitalRead() calls are too slow and bring the arduino down when
// I use them in the interrupt routines while the motor runs at full speed.
// Quadrature encoders
// Left encoder
#define c_LeftEncoderInterruptA 0
#define c_LeftEncoderInterruptB 1
#define c_LeftEncoderPinA 2
#define c_LeftEncoderPinB 3
#define LeftEncoderIsReversed
volatile bool _LeftEncoderASet;
volatile bool _LeftEncoderBSet;
volatile bool _LeftEncoderAPrev;
volatile bool _LeftEncoderBPrev;
volatile long _LeftEncoderTicks = 0;
  // Left encoder
  pinMode(c_LeftEncoderPinA, INPUT_PULLUP);      // sets pin A as input
 // digitalWrite(c_LeftEncoderPinA, LOW);  // turn on pullup resistors
  pinMode(c_LeftEncoderPinB, INPUT_PULLUP);      // sets pin B as input
 // digitalWrite(c_LeftEncoderPinB, LOW);  // turn on pullup resistors
  attachInterrupt(c_LeftEncoderInterruptA, HandleLeftMotorInterruptA, CHANGE);
  attachInterrupt(c_LeftEncoderInterruptB, HandleLeftMotorInterruptB, CHANGE);
  Serial.print("Encoder Ticks: ");
  Serial.print(_LeftEncoderTicks);
  Serial.print("  Revolutions: ");
  Serial.print(_LeftEncoderTicks/1440.00);//4000 Counts Per Revolution
  Serial.print("\n");
// Interrupt service routines for the left motor's quadrature encoder
void HandleLeftMotorInterruptA(){
  _LeftEncoderBSet = digitalReadFast(c_LeftEncoderPinB);
  _LeftEncoderASet = digitalReadFast(c_LeftEncoderPinA);
  _LeftEncoderTicks+=ParseEncoder();
  _LeftEncoderAPrev = _LeftEncoderASet;
  _LeftEncoderBPrev = _LeftEncoderBSet;
// Interrupt service routines for the right motor's quadrature encoder
void HandleLeftMotorInterruptB(){
  // Test transition;
int ParseEncoder(){
  if(_LeftEncoderAPrev && _LeftEncoderBPrev){
    if(!_LeftEncoderASet && _LeftEncoderBSet) return 1;
    if(_LeftEncoderASet && !_LeftEncoderBSet) return -1;
  }else if(!_LeftEncoderAPrev && _LeftEncoderBPrev){
    if(!_LeftEncoderASet && !_LeftEncoderBSet) return 1;
    if(_LeftEncoderASet && _LeftEncoderBSet) return -1;
  }else if(!_LeftEncoderAPrev && !_LeftEncoderBPrev){
    if(_LeftEncoderASet && !_LeftEncoderBSet) return 1;
    if(!_LeftEncoderASet && _LeftEncoderBSet) return -1;
  }else if(_LeftEncoderAPrev && !_LeftEncoderBPrev){
    if(_LeftEncoderASet && _LeftEncoderBSet) return 1;
    if(!_LeftEncoderASet && !_LeftEncoderBSet) return -1;
