Varspeedservo jittering
hi when i use the library varspeedservo my servo jitters (im using a good power supply of 7.2V) when i use the usual servo library my servo works fine.
how do i solve the jittering?
code:
#include <VarSpeedServo.h>
VarSpeedServo myservo;
int pos = 86.5;
myservo.attach(9);
    myservo.write(pos,30,true);
any help?
Don't smash the servo millions of times per second. Just for test, add a delay(1000);// 1 second delay
in loop.
i have tried this and i still have jittering
Move
to setup(), and see it it still does it.
Which servo. Which Arduino.
Show us your "good 7.2volt supply", and the wiring/setup (picture).
Did you also connect servo ground to Arduino ground.
Leo..
What do you have the servo frequency set to..??
Many will not handle over 50Hz.
Can't put a fraction in an int.
Leo..
