I'm trying to control an Arduino via Excel VBA using the MSCOMM control
The following sketch accepts serial input, and controls the brightness of a led
It works fine when data is entered via a serial monitor
int outPort=3 ;
char buffer[8] ;
char character ;
int nBright = 0 ;
int i=0;
char digit ;
Serial.begin(9600) ; // set up the serial monitor
pinMode(outPort,OUTPUT);
i=0;
// Serial.flush(); // clear any 'junk' out of the serial buffer before waiting
while (Serial.available() == 0)
// do nothing until something enters the serial buffer
while (Serial.available() > 0)
nBright = Serial.parseInt();
Serial.print("You entered: ");
Serial.println(nBright);
Serial.flush();
// Control the brightness of a LED attached to Outport
// First make sure the number is 0-255
if(nBright < 0){nBright=0;}
if(nBright >255){nBright=255;}
analogWrite(outPort,nBright) ;
The following VBA code sends the number (0-255) in a TextBox to the Arduino (the D13 led flashes) , but the LED I want to control is not activated.
Private Sub CommandButton1_Click()
' Buffer to hold input string
Dim Instring As String
' Use COM13
MSComm1.CommPort = 13
' 9600 baud, no parity, 8 data, and 1 stop bit.
MSComm1.Settings = "9600,N,8,1"
' Tell the control to read entire buffer when Input
' is used.
MSComm1.InputLen = 0
' Open the port.
MSComm1.PortOpen = True
' Send the data to the port
data = TextBox1.Text ' The brightness required, 0-255
Debug.Print "Data=" & data
' Send the data to the Arduino.
MSComm1.Output = data & vbCrLf
' Close the Port
MSComm1.PortOpen = False
End Sub
Any thoughts ?
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
