I have an Arduino script: and need the Visual Basic 2008 Express Edition code I for it
Arduino code:
int ledPin = 13; // select the pin for the LED
int val = 0; // variable to store the data from the serial port
pinMode(ledPin,OUTPUT); // declare the LED's pin as output
Serial.begin(9600); // connect to the serial port
void loop () {
val = Serial.read(); // read the serial port
// if the stored value is a single-digit number, blink the LED that number
if (val > '0' && val <= '9' ) {
val = val - '0'; // convert from character to number
for(int i=0; i<val; i++) {
Serial.println("blink!");
digitalWrite(ledPin,HIGH);
delay(150);
digitalWrite(ledPin, LOW);
delay(150);
//Serial.println();
Throw a MSComm control on the VB form, set the properties for the MSComm to 9600,8,n,1. Add code to the vertical scrollbar for change() to send serial data.
