Very simple code with a problem
Hi guys I'm wondering why in this little program, the serial output is NOT being indented (\t)?
If i change the data types of x,y and z from int to float, it works. Later testing showed me that it works with int too ONLY IF the number is greater than 2 digits, and by that I mean >=10 OR <0 (minus sign counts).
Its basically a problem I'm having with another code I've just made it really simple here so everyone can run it quickly and hopefully I can get more answers faster ^.^...
int x;
int y;
int z;
  x = 0;
  y = 0;
  z = 0;
  Serial.print("X is: ");
  Serial.print(x);
  Serial.print("\tY is: ");
  Serial.print(y);
  Serial.print("\tZ is: ");
  Serial.println(z);
Thanks!
scopesys:
int x;
int y;
int z;
  x = 0;
  y = 0;
  z = 0;
  Serial.print(x);
  Serial.print(y);
  Serial.println(z);
Thanks!
the reason is because \t is calling a "tab" function basiclly. But the start of the tab spacing isnt set by the last char you have entered into your code but from a base point of 0. so whats happening is most of your tab is being eatten up by x = 0 and v = 0 ect.
by adding a simple space before the tab i have moved the tabs starting space to a new reset location if that makes sense.
int x;
int y;
int z;
x = 0;
y = 0;
z = 0;
Serial.print(x);
Serial.print(" \tY is: ");
Serial.print(y);
Serial.print(" \tZ is: ");
Serial.println(z);
The \t character inserts the tab (ascii char 9) into the string, and the ascii tab width is a field 8 characters wide. The tab will jump from where the text stops in the 8 character block to the next field. If you have used up 5 characters it will jump 3. In your case, with your text and one digit number, you use up 7 and it jumps one. When you use a two digit number which brings the total to 8 characters, tab jumps across the full field to the next starting point.
cattledog:
Thank you both, what Remy suggested worked but I didn't quite understand why from his post however your explanation cleared things up for me ^.^...
I got a question though, why 8? Does it have something to do with 8 chars (each 1 bit?) representing 1 byte and what tab does is skip to the next byte?
Sorry I'm very new to programming xD
No. It is an arbitrary number chosen by the writers of the Serial monitor as a compromise between being useful and wasting space.
