When I try typing in my code, I get an error. Here it is:
exit status 1
variable or field 'setup' declared void
exit status 1
Do you think it might help if we could see your code ?
Please follow the advice given in the link below when posting code . Use code tags when posting code here to make it easier to read and copy for examination
Sure, Here is my code:
const int buzzPin = 11;
const int trigPin = 9;
const int echoPin = 10;
long duration;
int distance;
void setup {
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(buzzPin, OUPUT);
// Setting up the Distance Sensor:
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = duration*0.034/2;
Serial.print("Distance: ");
Serial.println(distance);
//Buzzer sound making
do {
tone(buzzPin, distance, 1);
while(1);
Why do users choose to ignore the advice on posting code ?
The easier you make it to read and copy your code the more likely it is that you will get help
Please follow the advice given in the link I posted
This is my setup:
void setup {
This is the error message:
Arduino: 1.8.15 (Windows Store 1.8.49.0) (Windows 10), Board: "Arduino Uno"
distanceMusic:8:6: error: variable or field 'setup' declared void
void setup {
distanceMusic:9:27: error: expected '}' before ';' token
distanceMusic:10:10: error: expected constructor, destructor, or type conversion before '(' token
distanceMusic:11:3: error: 'Serial' does not name a type
distanceMusic:12:10: error: expected constructor, destructor, or type conversion before '(' token
distanceMusic:13:1: error: expected declaration before '}' token
exit status 1
option enabled in File -> Preferences.
You need parenthesis after setup in order to make it a function definition instead of a variable definition:
You're already using the correct syntax for loop()...
@gablos are you deliberately ignoring the advice to use code tags when posting code and error messages ?
