Voltage divider circuit for arduino
how can I display battery percentage of my 12v battery using arduino? Can anyone provide the voltage divider circuit with appropriate resistors and code?
I am using rechargeable 12v Li-ion battery.
have you googled for "voltage devider" and inserted the numbers to get the highly sophisticated 2 resistor values?
:rofl:
Try reading arduino/reference and look for analog reading.
Forum is not a free giveaway shop. If You w at learning and growing in coding, forum can be useful.
There are no 12V Li-ion batteries. Do you mean an 11.1V or a 14.8V?
@amalpv798 ,
Your topic was moved to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Thank you
Hi, @amalpv798
Google;
arduino battery voltage monitor
This will give you some info on how its done.
Tom.. :grinning: :+1: :coffee: :australia:
3S? (4.2 per cell)
https://www.amazon.com/Anmbest-Charger-Protection-Lithium-Battery/dp/B07DYS6RJJ
Make sure the battery is not connected if the Arduino is not powered
