I have put together a project to monitor the temperature of our fridge and freezer. The fritzing schematics (sorry) are attached to this message.
It will calculate average temp, trends and a whole lot of other things. If the temperature is out of acceptable limits then it will sound an alarm and repeatedly blink the LCD backlight. One button is for silencing the alarm via an interrupt and the other one is to manually turn on the LCD backlight should one want to see the screen in the dark.
In other words, it is an over-engineered thermometer.
The problem I am having is that my temperature sensors are analog. Thus they need a constant voltage to return accurate and calibrated values.
This is not the case however. Voltage varies a lot:
When I power the whole thing up with a 5V 2A AC adapter, voltage on the 5V pin and the Vin pin is 4.55ish.
When the screen is blinking/the backlight is on, it drops to around 4.30V
If I plug in both the AC and the USB, the 5V and Vin pins are around 4.67V
It drops to around 4.40V when there is backlight activity.
I checked the output of the AC at the plug and it's 5.39V
Where does my problem stem from? Is my whole “system” using more that 2A? It seems like a rather hugh value doesn't it?
How can I make the 5V deliver 5V so that I don't have to tweak the code every time I change the way it's powered?
I plan on moving everything to a PCB once these problems are ironed out powered by a standalone atmega328 without a USB serial interface. I was thinking I could power it with AA batteries. Is it feasible or is it using too much juice?
I'm not very experienced to all things electric/electronic so please be patient and detailed in your answers.
Thanks for your help!
--edit: A more readable image size than what the forum offers
Oh wait. Are you plugging the 5V adapter into the Arduino's power jack? Or to the Vin pin? (Same thing really.) If so that's the trouble. Like Nick says, 7-12 volts are needed there.
If it's a decent, regulated 5V adapter, it can be connected to the Arduino's 5V pin. I've got some 5V wall warts around here, usually they run a little closer to 5V even open circuit, usually within 0.1V. So 5.39 sounds a bit high, but it could be ok.
And you probably want the Arduino's 5V pin hooked to the breadboard power rail, not Vin as shown in the picture.
Plus, the ADC can reference an internal 1.1V reference. That would be more reliable probably than the fluctuation you might get on the 5V line. You might need a voltage divider so that you don't input more than 1.1V on the analog pin, if you choose to use that.
I changed the wire so the power rail is fed from the 5V.
I checked the power rail once fed from the 5V pin and it does output the same as Vin, that is to say around 4.55/4.65 depending on the USB/DC jack combinations stated in the first post.
Nothing gets hot and the wallwart is the one I got from Adafruit with the thermal printer. It works fine with the printer + ethernet shield.
You can configure the ADC to have a different voltage reference. If you set it to 1.1V then you would need to ensure that you don't input more than 1.1V. However since that is an internal reference it shouldn't fluctuate.
hfp777:
If you are supplying 7+V to the power input jack you should have 5V on the 5V pin and not some other voltage.
When I power the whole thing up with a 5V 2A AC adapter ...
My LCD has a resistor built in the backlight so I don't have to put one.
However, the Arduino is a cheap Chinese knock off. How can I know the regulator's specs? Is there a way to see just looking at it?
It says AMS 1117 on the regulator and outputs 5.15V without any load.
On my genuine Arduino it outputs 5.00V without load.
I was thinking that maybe I should make a separate power line for the buzzer and the LCD backlight as they are drawing too much current? Or maybe put the two sensors on their own 5V regulator and all the rest on a separate 5V regulator?
Would that solve the problem? What about the ground lines, does it matter if I power the sensors from a separate 5V regulator but ground them to the Arduino's pin?
I have read your comments as you mentioned that you put together to monitor the temperature of your fridge and freezer. It might seems that it may take so much power due to which voltage fluctuation is so high. If you are facing this issue continuous then you should contact to a residential HVAC system maintenance professional immediately to fix issue.
