a schottky diode? how would that help? Shottky diodes are very cheap, too - like, 20-for-$1.29-shipped cheap - so i find it hard to belive that they're out of your price range. Did you mean something else?
A micro-power comparator driving a p-MOSFET would be one way, but you'll find there are
chips dedicated to "battery management" out there which might be simpler to use. The
comparator approach would need a reference like a zener to compare to a voltage-divided
version of the battery voltage. Some hysteresis would be needed to stop it oscillating.
If that's Arduino controlled, then the Arduino can measure the battery and cut the load.
Maybe it's wise to monitor each cell, so that it cuts off when ONE cell is below e.g. 3volts.
Post project and code if you want detailed help.
Leo..
raschemmel:
FYI, in case you have no experience with 7.4V LIPO, that's called a "2S" battery and 7.4V is the DISCHARGED VOLTAGE. The CHARGED voltage is 8.4V !
7.4V is the nominal voltage -- not the discharged voltage. Either that or the link you re-provided is a deficient product.
Also, your overuse of bold and capitalized letters makes your post look like a Zippy the Pinhead comic.
