I am new in this field of Arduino and my knowledge just a little electronica, I believe that the program gives me something better and am slowly doing some other things.
I have a question, aver if you can guide me a bit.
I have an Arduino UNO board, and I want to regulate a DC voltage across one of the output (PWM) Arduino. My problem is that this regulation from 0 to 5 volts.
Is there any possibility of regulating through one of the outputs (PWM) from 0 to 10 volts?
And if possible with a feeding plate 9 volts?
INC_VK:
No it does not... It switches between 0v and 5V, nothing in between... After a RC-filter you can have 0-5V.
INC_VK:
RC-filter it to get 0-5V and feed it to an opamp with gain 2.
INC_VK:
Feeding plate? Is it dinner time already? Do you mean supply voltage? If you just have 9V and want 10V you first have to fix that. It's a different problem at all. But I would use a DC-DC boost converter.
But all in all, XY-problem. What are you planning on driving?
What you are referring to is NOT called REGULATION.
It is called DIGITAL to ANALOG output, which requires a DAC.
The arduino UNO does NOT have a DAC, but you can get one for $5
You need to research DACS and their associated parameters, (such as RESOLUTION)
I just wanted to be able to regulate (control) from an output (PWM) of the Arduino UNO
from 0 to 10 volts, with analogWrite (pin9, 0/255); = 0/10 volts.
Aarg ... thanks and I saw a link to the page, I'll see if I prepare the circuit and test it,
I will tell aver that such .... Thanks.
INC_VK:
This makes me think that you don't fuly understand what PWM is.
It is NOT a voltage.
It's a digital signal that constantly switches between ground and the MCU supply (5volt for the Uno).
You can however smooth it into a constant voltage with a resistor and a capacitor.
Question is what you want to do with the signal.
Maybe your "device" is happy with straight PWM.
That only requires two resistors and a transistor.
But maybe your "device" needs a smooth voltage.
Then you need an RC filter and an opamp.
Tell us what you want to control.
Leo..
That's a vacuum tube term. I don't think there is any vacuum tubes in this post but it could be a backward obsolete electronics term from a 3rd world country.
