I am working on a project for my car, a 2009 Volkswagen.
My goal is to achieve two things:
RGB Ambient lighting
CAN-Bus decoding to achieve functions like automatically folding mirrors.
This thread will focus on the CAN-part of the project.
I have got the UNO, the CAN shield and a set of CAN wires, but I am struggling with initial decoding of my CAN network to find the correct CAN-Bus messages.
First and foremost I want to find:
The message ID and bit that activates the folding mirror motor (This is activated by a knob in the door)
Something that tells me if the engine is running
Something that tells me if the doors are locked or unlocked
Using the arduino to filter out and find these messages is way out of my league, so I was hoping I could use my PC and USB-OBDII adapter to hook up to the OBDII port of my car, and filter out the packages easily from the PC.
Any ideas? I did all the searching I could. Sorry if violating forum rules here!
A proper VAGCOM cable and a copy of VCDS from RossTech will be invaluable for custom programming your VW.
I'm cheap, I used an ebay VAGCOM cable and got it working, and using the free version of VCDS does all I need, but the full version is worth it if you need more.
I have proper VCDS and cable - But these functions are limited by the comfort module in the car. The mirror folds, but not automatically. No Passat B6 does this
How do your mirrors fold? Rotary knob near A pillar that also controls heated mirrors or some manual input? Just looking for an automated knob replacement tied to ignition then? That's not a canbus issue if it's not already electronically controlled.
You are correct. The knob sets a CAN-bus variable. I can also manipulate this from the test/diagnostics of the VCDS.
I can, however, not program the mirrors through the RossTech interface to automatically fold.
This is the function I want to achieve - But I need to find out what bit on which message ID on the CAN-Bus is activated by the knob in the door near the A-pillar
So you're sure the knob is just a signal and not actually routing power to the mirror motors with a separate signal to canbus? Because if the knob is actually physically breaking the power to the mirrors, no amount of programming can overcome that.
I'm sure - Because I can enter with the VCDS software, and go to the testing routines of each control module (I'm not sure if you're aware of this - But I think you are given your knowledge on the subject).
From here, I can run windscreen wipers, horn, high beams, dynamic headlamps, hazards etc. Including folding mirrors.
I am absolutely sure, that this is a programmable project. The PC does, after all, do all of this magic over the very same CAN-interface I plan on using
Hello.
I have a Volksgem and am trying to access data from comfort ids, like lights, etc. Have you been able to find and identify these signs in your project?
