Hi guys,
I used the code from Salvatore Fancello to create a Webserver to control some lamps. You can find the project here: https://wiznetmuseum.cafe24.com/portfolio-items/3-controlling-home-devices-with-arduino-and-ethernet-shield-via-webserver/
I will also add the code at the end of this post.
The only difference I made is, that I used an Arduino Nano and not an Uno. After some irregular time the Webserver always goes offline. You are not be able to access the website and also not be able to ping the arduino. The power LED of the Arduino is still lightning and the LEDs of the W5500 are still flashing. Have you any ideas why the Webserver goes offline?
Here is the code:
Created by Salvatore Fancello
Visit: http://progettiarduino.com for more arduino projects
Arduino Uno with Ethernet Shield Webserver
#include <SPI.h>
#include <Ethernet.h>
int led1 = 2; //relay1
int led2 = 3; //relay2
int led3 = 4; //relay3
int led4 = 5; //relay4
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // mac address
byte ip[] = { 192, 168, 1, 89 }; // configurate il vostro IP a vostra scelta("192.168.1.89")
byte gateway[] = { 192, 168, 1, 1 }; // internet access router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
// Apro la comunicazione seriale:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
//Imposto i pin come OUTPUT
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
// Inizio la comunicazione Ethernet con il server:
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
// Creo una connessione al client
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//Leggo i caratteri da HTTP
if (readString.length() < 100) {
//Inserisco i caratteri nella stringa
readString += c;
//Serial.print(c);
//Se la richiesta HTTP è andata a buon fine
if (c == '\n') {
Serial.println(readString); //scrivi sul monitor seriale per debugging
client.println("HTTP/1.1 200 OK"); //Invio nuova pagina
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<meta name='apple-mobile-web-app-capable' content='yes' />");
client.println("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />");
client.println("<link rel='stylesheet' type='text/css' href='http://www.progettiarduino.com/uploads/8/1/0/8/81088074/style3.css' />");
client.println("<TITLE>Controllo Dispositivi da Remoto</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Controllo Dispositivi da Remoto</H1>");
client.println("<hr />");
client.println("
client.println("<H2>Arduino UNO con Ethernet Shield</H2>");
client.println("
client.println("<a href=\"/?button1on\"\">Accendi LED 1</a>"); //Modifica a tuo piacimento:"Accendi LED 1"
client.println("<a href=\"/?button1off\"\">Spegni LED 1</a>
"); //Modifica a tuo piacimento:"Spegni LED 1"
client.println("
client.println("
client.println("<a href=\"/?button2on\"\">Accendi LED 2</a>"); //Modifica a tuo piacimento:"Accendi LED 2"
client.println("<a href=\"/?button2off\"\">Spegni LED 2</a>
"); //Modifica a tuo piacimento:"Spegni LED 2"
client.println("
client.println("
client.println("<a href=\"/?button3on\"\">Accendi LED 3</a>"); //Modifica a tuo piacimento:"Accendi LED 3"
client.println("<a href=\"/?button3off\"\">Spegni LED 3</a>
"); //Modifica a tuo piacimento:"Spegni LED 3"
client.println("
client.println("
client.println("<a href=\"/?button4on\"\">Accendi LED 4</a>"); //Modifica a tuo piacimento:"Accendi LED 4"
client.println("<a href=\"/?button4off\"\">Spegni LED 4</a>
"); //Modifica a tuo piacimento:"Spegni LED 4"
client.println("
client.println("<p>Creato da Salvatore Fancello. Visita http://progettiarduino.com per altri progetti!</p>");
//Sostieni il blog visita: http://www.progettiarduino.com/sostieni-il-blog.html
client.println("
client.println("</BODY>");
client.println("</HTML>");
delay(1);
client.stop();
//Controlli su Arduino: Se è stato premuto il pulsante sul webserver
if (readString.indexOf("?button1on") >0){
digitalWrite(led1, HIGH);
if (readString.indexOf("?button1off") >0){
digitalWrite(led1, LOW);
if (readString.indexOf("?button2on") >0){
digitalWrite(led2, HIGH);
if (readString.indexOf("?button2off") >0){
digitalWrite(led2, LOW);
if (readString.indexOf("?button3on") >0){
digitalWrite(led3, HIGH);
if (readString.indexOf("?button3off") >0){
digitalWrite(led3, LOW);
if (readString.indexOf("?button4on") >0){
digitalWrite(led4, HIGH);
if (readString.indexOf("?button4off") >0){
digitalWrite(led4, LOW);
//Cancella la stringa una volta letta
readString="";
