W5500 Lite Problem in ESP32(SOLVED)
Good day, I want to use w5500 lite ethernet module with mqtt using esp32. However, I get the error Could not configure Ethernet using DHCP. The code and module links I used are attached.
#include <Ethernet.h>
#include <PubSubClient.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
EthernetClient net;
PubSubClient client;
unsigned long lastMillis = 0;
void connect() {
  Serial.print("connecting...");
  while (!client.connect("arduino32")) {
  Serial.println("\nconnected!");
  client.subscribe("/hello");
  // client.unsubscribe("/hello");
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.begin(57600);
  Serial.println("Start Setup");
if (Ethernet.begin(mac)==0){
  Serial.println("Failed to configure Ethernet using DHCP");
  for(;;)
  Ethernet.begin(mac, Ethernet.localIP());
 Serial.println("Start MQTT");
  client.setKeepAlive(90);
  client.setClient(net);
  client.setServer("xx.xxx.xxx.xxx", 1883);
  client.setCallback(callback);
  connect();
  if (!client.connected()) {
    connect();
  // publish a message roughly every second.
  if (millis() - lastMillis >5000) {
    lastMillis = millis();
    client.publish("/hello", "world");
  client.loop();
buy a LAN8720 module and see the ETH_LAN8720 example of the WiFi library
I want to use w5500 because the dimensions are ideal, I drew the PCB circuit :frowning:
but the esp32 already has a MAC peripheral a TCP/IP stack and Arduino networking library and you duplicate this all with a W5500 and Ethernet library
Isn't it possible to use it with W5500 esp32?
Which pin are you using for chip select?
ESP32 / W5500
23 ------> MO
19 ------> MI
18 ------> SCK
5 ------> CS
Have a look inside the library to see what it is using by default. On the Uno it's pin 10 but I have no idea what it uses on the ESP32.
default pins i wrote
try Ethernet.init(5); before Ethernet.begin
and it should be PubSubClient client(net);
Thank you very much i was researching this problem for 2 days you saved me from a big mess.
